Hello everyone. I need help regarding an error when trying to open a file.
The SD card was successfully initialized at setup and the file was already created.
In the main loop, I have a function where I read sensors reading and save them to the same filename when initialized in Setup. The problem here is that usually when the first few times it opens the file to write into it, everything is ok. But then the next few times it opened, it was unable to open the file, then sometimes it managed to open again.
I have about 96 sensors connected to 6 multiplexers (16 each), so the read and write to sd is inside another loop since I need to go through each channel in the multiplexers.
This Arduino project also has a 12v exhaust fan connected to it so I use the 12V adapter to power the exhaust fan and then let it go through a buck converter 12V-5V to power the rest of the components, i.e. Arduino, dht22 sensors, multiplexers, sd module and so on.
When I run the Arduino powered through my laptop, without the exhaust fan, the SD card is was able to open the file without error even once. However, when I unplug it from my laptop and only powers it through the 12v, the problem I addressed above came up.
I also like mention that, previously, the first time I tested and collected my data for a day, the SD file was able to open and write everything. Then the following day, this problem happened.
My full code is here:
#include <SPI.h> // for sdcard
//SD Card Declaration
char fileName[13];
int pinCS = 53;
#include "RTClib.h" //for rtc and lcd
#include <Wire.h> //for rtc and lcd
#include <LiquidCrystal_I2C.h> //for rtc and lcd
//I2C LCD and RTC
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE);
RTC_DS3231 rtc;
int button1Pin = 2; //button S1
int redled_button1 = 12;
#define exhaustFan_1 48 // pin that on/off exhaust fan 1
#define exhaustFan_2 49
#include "DHT.h"
#define DHTTYPE DHT22
DHT dht_mux1(31 , DHTTYPE);
DHT dht_mux2(30 , DHTTYPE);
DHT dht_mux3(41 , DHTTYPE);
DHT dht_mux4(40 , DHTTYPE);
DHT dht_mux5(47 , DHTTYPE);
DHT dht_mux6(14, DHTTYPE);
DHT dht_mux7(5 , DHTTYPE);
int SIG1 = 31;
int S1[4] = {23,25,27,29};
int SIG2 = 30;
int S2[4] = {22,24,26,28};
int SIG3 = 41;
int S3[4] = {33,35,37,39};
int SIG4 = 40;
int S4[4] = {32,34,36,38};
int SIG5 = 47;
int S5[4] = {42,43,44,45};
int SIG6 = 14;
int S6[4] = {18,17,16,15};
int SIG7 = 5;
int S7[4] = {1,2,3,4};
//TRUTHTABLE S0,S1,S2,S3
int MUXtable[16][4]=
{0,0,0,0}, {1,0,0,0}, {0,1,0,0}, {1,1,0,0},
{0,0,1,0}, {1,0,1,0}, {0,1,1,0}, {1,1,1,0},
{0,0,0,1}, {1,0,0,1}, {0,1,0,1}, {1,1,0,1},
{0,0,1,1}, {1,0,1,1}, {0,1,1,1}, {1,1,1,1}
void setup() { //setuploop
pinMode(pinCS, OUTPUT);
lcd.begin(16,2);
lcd.backlight();
if (! rtc.begin()) {
while (1);
if (rtc.lostPower()) {
lcd.print("RTC lost power:");
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
delay(300);
lcd.clear();
if (SD.begin())
Serial.println("SD is Ready");
lcd.print("SD is Ready");
} else
lcd.print("SD Failed");
return;
lcd.setCursor(0,0);
DateTime now = rtc.now();
sprintf(fileName, "%d%d%02d.txt", now.year(), now.month(), now.day());
Serial.println(fileName);
File myFile;
myFile = SD.open(fileName, FILE_WRITE);
if (myFile) {
// Write to file
myFile.println("TIME,TRAY,POSITION,TEMPERATURE,AIR FLOW");
myFile.close(); // close the file
lcd.setCursor(0,1);
lcd.print("Header written!");
// if the file didn't open, print an error:
else {
lcd.setCursor(0,1);
lcd.print("cannot open");
pinMode(button1Pin, INPUT);
pinMode(redled_button1, OUTPUT);
pinMode(exhaustFan_1, OUTPUT);
pinMode(exhaustFan_2, OUTPUT);
digitalWrite(exhaustFan_1, LOW);
digitalWrite(exhaustFan_2, LOW);
pinMode(SIG1,INPUT);
pinMode(SIG2,INPUT);
pinMode(SIG3,INPUT);
pinMode(SIG4,INPUT);
pinMode(SIG5,INPUT);
pinMode(SIG6,INPUT);
pinMode(SIG7,INPUT);
for(int i=0; i<4; i++)
pinMode(S1[i],OUTPUT);
pinMode(S2[i],OUTPUT);
pinMode(S3[i],OUTPUT);
pinMode(S4[i],OUTPUT);
pinMode(S5[i],OUTPUT);
pinMode(S6[i],OUTPUT);
pinMode(S7[i],OUTPUT);
dht_mux1.begin();
dht_mux2.begin();
dht_mux3.begin();
dht_mux4.begin();
dht_mux5.begin();
dht_mux6.begin();
dht_mux7.begin();
//inmainloop
int mode = 1; //state airflow route
lcd_showroute(mode);
switch_exhaustfan(mode);
record_sensor(mode);
while(1) {
lcd.setCursor(0,1);
lcd.print("while-min ");
lcd.print(now.minute());
Serial.print("while-min ");
Serial.println(now.minute());
if(now.minute() == 0 || now.minute() == 30 || now.minute() == 20)
lcd.setCursor(0,1);
lcd.print("DONE!!");
delay(2000);
void switch_exhaustfan(int m)
if(m == 1){
digitalWrite(exhaustFan_1, HIGH);
lcd.setCursor(0,1);
lcd.print("Top Exhaust ON");
else if(m == 2){
digitalWrite(exhaustFan_2, HIGH);
lcd.setCursor(0,1);
lcd.print("Bottom Exhaust ON");
void lcd_showroute(int m){
char displaytime[10];
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Mode");
lcd.setCursor(5,0);
lcd.print(m);
lcd.setCursor(7,0);
sprintf(displaytime, "%d:%02d", now.hour(), now.minute()); //convert time object to string
lcd.print("<");
lcd.print(displaytime);
lcd.print(">");
Serial.print("Mode ");
Serial.print(m);
Serial.print(" <");
Serial.print(displaytime);
Serial.println(">");
void record_sensor(int m){
digitalWrite(redled_button1, HIGH);
for(int i=0; i<16; i++)
channel_selection(i);
read_sensor(i+1, m);
digitalWrite(redled_button1, LOW);
void channel_selection(int j)
digitalWrite(S1[0], MUXtable[j][0]);
digitalWrite(S1[1], MUXtable[j][1]);
digitalWrite(S1[2], MUXtable[j][2]);
digitalWrite(S1[3], MUXtable[j][3]);
digitalWrite(S2[0], MUXtable[j][0]);
digitalWrite(S2[1], MUXtable[j][1]);
digitalWrite(S2[2], MUXtable[j][2]);
digitalWrite(S2[3], MUXtable[j][3]);
digitalWrite(S3[0], MUXtable[j][0]);
digitalWrite(S3[1], MUXtable[j][1]);
digitalWrite(S3[2], MUXtable[j][2]);
digitalWrite(S3[3], MUXtable[j][3]);
digitalWrite(S4[0], MUXtable[j][0]);
digitalWrite(S4[1], MUXtable[j][1]);
digitalWrite(S4[2], MUXtable[j][2]);
digitalWrite(S4[3], MUXtable[j][3]);
digitalWrite(S5[0], MUXtable[j][0]);
digitalWrite(S5[1], MUXtable[j][1]);
digitalWrite(S5[2], MUXtable[j][2]);
digitalWrite(S5[3], MUXtable[j][3]);
digitalWrite(S6[0], MUXtable[j][0]);
digitalWrite(S6[1], MUXtable[j][1]);
digitalWrite(S6[2], MUXtable[j][2]);
digitalWrite(S6[3], MUXtable[j][3]);
digitalWrite(S7[0], MUXtable[j][0]);
digitalWrite(S7[1], MUXtable[j][1]);
digitalWrite(S7[2], MUXtable[j][2]);
digitalWrite(S7[3], MUXtable[j][3]);
void read_sensor(int k, int m)
float h[6];
float t[6];
File newFile;
newFile = SD.open(fileName, FILE_WRITE);
char timenow[10], write_line[40], temp[5];
float temporary[6];
h[0] = dht_mux1.readHumidity();
t[0] = dht_mux1.readTemperature();
h[1] = dht_mux2.readHumidity();
t[1] = dht_mux2.readTemperature();
h[2] = dht_mux3.readHumidity();
t[2] = dht_mux3.readTemperature();
h[3] = dht_mux4.readHumidity();
t[3] = dht_mux4.readTemperature();
h[4] = dht_mux5.readHumidity();
t[4] = dht_mux5.readTemperature();
h[5] = dht_mux6.readHumidity();
t[5] = dht_mux6.readTemperature();
for(int i=0; i<6; i++)
lcd.setCursor(0,1);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print("(");
lcd.print(k);
lcd.print(")");
lcd.setCursor(4,1);
lcd.print("T");
//lcd.setCursor(1,1);
lcd.print(i+1);
//lcd.setCursor(2,1);
lcd.print("CH");
//lcd.setCursor(5,1);
lcd.print(k);
if(!isnan(t[i]))
lcd.setCursor(11,1);
lcd.print("OK!");
lcd.print("FAIL!");
if (newFile) {
sprintf(timenow, "%d:%02d:%02d", now.hour(), now.minute(), now.second()); //convert time object to strin
//dtostrf(t[i], 3, 2, temp); //convert temperature float object to string
//sprintf(write_line, "%s,%d,%02d,%.2f,%d", timenow, i+1, k, t[i], m);
//newFile.println(write_line);
newFile.print(timenow);
newFile.print(",");
newFile.print(i+1);
newFile.print(",");
newFile.print(k);
newFile.print(",");
newFile.print(t[i]);
newFile.print(",");
newFile.println(m);
Serial.print(timenow);
Serial.print(",");
Serial.print(i+1);
Serial.print(",");
Serial.print(k);
Serial.print(",");
Serial.print(t[i]);
Serial.print(",");
Serial.println(m);
newFile.close(); // close the file
lcd.setCursor(0,1);
lcd.print("Data is now saved.");
Serial.println("Data is now saved.");
else {
lcd.setCursor(0,1);
lcd.print("Error opening file");
Serial.println("Error opening file");
type or paste code here
