Hi.
I´m using a ESP8266 Node MCU and the NRF24L01+PA+LNA and I´m trying to use the example sketch for client and server from the RadioHead library example folder to stablish a connection between two identical setups to pass some data from one point to another.
The problem is that in the serial monitor i´m not getting nothing but nonsense characters
I hope someone can help me, and thanks in advance
This is the code for the client
#include <SPI.h>
#include <RH_NRF24.h>
// Singleton instance of the radio driver
RH_NRF24 nrf24;
// RH_NRF24 nrf24(8, 7); // use this to be electrically compatible with Mirf
// RH_NRF24 nrf24(8, 10);// For Leonardo, need explicit SS pin
// RH_NRF24 nrf24(8, 7); // For RFM73 on Anarduino Mini
while (!Serial)
; // wait for serial port to connect. Needed for Leonardo only
if (!nrf24.init())
Serial.println("init failed");
// Defaults after init are 2.402 GHz (channel 2), 2Mbps, 0dBm
if (!nrf24.setChannel(1))
Serial.println("setChannel failed");
if (!nrf24.setRF(RH_NRF24::DataRate2Mbps, RH_NRF24::TransmitPower0dBm))
Serial.println("setRF failed");
Serial.println("Sending to nrf24_server");
// Send a message to nrf24_server
uint8_t data[] = "Hello World!";
nrf24.send(data, sizeof(data));
nrf24.waitPacketSent();
// Now wait for a reply
uint8_t buf[RH_NRF24_MAX_MESSAGE_LEN];
uint8_t len = sizeof(buf);
if (nrf24.waitAvailableTimeout(500))
// Should be a reply message for us now
if (nrf24.recv(buf, &len))
Serial.print("got reply: ");
Serial.println((char*)buf);
Serial.println("recv failed");
Serial.println("No reply, is nrf24_server running?");
delay(400);
And this is the code for the server
#include <SPI.h>
RH_NRF24 nrf24;
while (!Serial)
if (!nrf24.init())
if (nrf24.available())
// Should be a message for us now
// NRF24::printBuffer("request: ", buf, len);
Serial.print("got request: ");
// Send a reply
uint8_t data[] = "And hello back to you";
Serial.println("Sent a reply");
