Error when compiling esp_32
Hi everyone,
I'm quite new to all this, but hopefully someone can point me in the right direction as to how to remedy this situation.
I'm currently attempting this build: ESP32Marauder/old_README.md at master · justcallmekoko/ESP32Marauder · GitHub
To my knowledge I have followed this guide correctly. However I must have messed up somewhere, as when compiling it throws a lengthy error code:
Arduino: 1.8.19 (Windows 10), Board: "LOLIN D32, Minimal SPIFFS (Large APPS with OTA), 80MHz, 921600, None, Disabled"
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Buffer.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: multiple definition of `text_table4'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Buffer.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: multiple definition of `text_table3'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Buffer.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: multiple definition of `text_table2'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Buffer.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: multiple definition of `text_table1'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Buffer.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: multiple definition of `text_table0'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Display.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: multiple definition of `text_table4'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Display.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: multiple definition of `text_table3'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Display.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: multiple definition of `text_table2'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Display.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: multiple definition of `text_table1'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Display.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: multiple definition of `text_table0'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\MenuFunctions.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: multiple definition of `text_table4'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\MenuFunctions.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: multiple definition of `text_table3'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\MenuFunctions.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: multiple definition of `text_table2'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\MenuFunctions.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: multiple definition of `text_table1'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\MenuFunctions.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: multiple definition of `text_table0'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\SDInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: multiple definition of `text_table4'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\SDInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: multiple definition of `text_table3'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\SDInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: multiple definition of `text_table2'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\SDInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: multiple definition of `text_table1'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\SDInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: multiple definition of `text_table0'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Web.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: multiple definition of `text_table4'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Web.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: multiple definition of `text_table3'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Web.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: multiple definition of `text_table2'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Web.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: multiple definition of `text_table1'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\Web.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: multiple definition of `text_table0'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\WiFiScan.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: multiple definition of `text_table4'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\WiFiScan.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: multiple definition of `text_table1'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\WiFiScan.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: multiple definition of `text_table3'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\WiFiScan.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: multiple definition of `text_table2'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\WiFiScan.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: multiple definition of `text_table0'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\esp32_marauder.ino.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: multiple definition of `text_table4'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:186: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\esp32_marauder.ino.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: multiple definition of `text_table3'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:185: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\esp32_marauder.ino.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: multiple definition of `text_table2'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:184: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\esp32_marauder.ino.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: multiple definition of `text_table1'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:183: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: sketch\esp32_marauder.ino.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: multiple definition of `text_table0'; sketch\BatteryInterface.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/lang_var.h:182: first defined here
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Jack\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.6/tools/sdk/esp32/lib\libnet80211.a(ieee80211_output.o): in function `ieee80211_raw_frame_sanity_check':
(.text.ieee80211_raw_frame_sanity_check+0x5c): multiple definition of `ieee80211_raw_frame_sanity_check'; sketch\WiFiScan.cpp.o:C:\Users\Jack\Desktop\flipper project\ESP32Marauder\esp32_marauder/WiFiScan.cpp:13: first defined here
collect2.exe: error: ld returned 1 exit status
exit status 1
Error compiling for board LOLIN D32.
If you need anymore information, please let me know and I will provide it.
Thanks in advance to any who help.
Have you got the correct board selected in the Board Manager?
Hi red_car,
I have selected the esp_32 dev board option as well and it still throws the same error, as shown below:
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Dev Module, Disabled, Disabled, Minimal SPIFFS (1.9MB APP with OTA/190KB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, Core 1, Core 1, None, Disabled"
c:/users/jack/appdata/local/arduino15/packages/esp32/tools/xtensa-esp32-elf-gcc/gcc8_4_0-esp-2021r2-patch5/bin/../lib/gcc/xtensa-esp32-elf/8.4.0/../../../../xtensa-esp32-elf/bin/ld.exe: C:\Users\Jack\Documents\Arduino\hardware\espressif\esp32/tools/sdk/esp32/lib\libnet80211.a(ieee80211_output.o): in function `ieee80211_raw_frame_sanity_check':
exit status 1
Error compiling for board ESP32 Dev Module.
Looks like it doesn't like the definition of these variables, as they are already defined in one of the libraries. Can you call them something else?
Can you post your code.
Use Arduino IDE 2.0.3 (install all the dependencies that show up after the installation) and follow this guide Installing ESP32 Board in Arduino IDE 2.0 to setup your board properly.
Hi Dozie,
I'm unbale to use the latest version of Arduino IDE because it will not allow me to use ESP32 Spiffs Tool as it only works up to version 1.8 as the current version does not support the use of 3rd party tools.
Hi red_car,
The code from lang_var.h is as follows:
#ifndef lang_var_h
#define lang_var_h
#include "configs.h"
//Starting window texts
PROGMEM const char text0_0[] = "Giving room for HardwareSerial...";
PROGMEM const char text0_1[] = "Started Serial";
PROGMEM const char text0_2[] = "Checked RAM";
PROGMEM const char text0_3[] = "Initialized SD Card";
PROGMEM const char text0_4[] = "Failed to Initialize SD Card";
PROGMEM const char text0_5[] = "Checked battery configuration";
PROGMEM const char text0_6[] = "Initialized temperature interface";
PROGMEM const char text0_7[] = "Initialized LED Interface";
PROGMEM const char text0_8[] = "Starting...";
//Single library (action) texts/Often used
PROGMEM const char text00[] = "Battery Level changed: ";
PROGMEM const char text01[] = "file closed";
PROGMEM const char text02[] = "Failed to open file '";
PROGMEM const char text03[] = "ON";
PROGMEM const char text04[] = "OFF";
PROGMEM const char text05[] = "Load";
PROGMEM const char text06[] = "Save As";
PROGMEM const char text07[] = "Exit";
PROGMEM const char text08[] = "Settings";
PROGMEM const char text09[] = "Back";
PROGMEM const char text10[] = "Channel:";
PROGMEM const char text11[] = "Touch screen to exit";
PROGMEM const char text12[] = "Cancel";
PROGMEM const char text13[] = "Save";
PROGMEM const char text14[] = "Yes";
PROGMEM const char text15[] = "Opening /update.bin...";
PROGMEM const char text16[] = "Close";
PROGMEM const char text17[] = "FAIL";
PROGMEM const char text18[] = "packets/sec: ";
//Menufunctions.cpp texts
PROGMEM const char text1_0[] = "SSID List";
PROGMEM const char text1_1[] = "Add SSIDs";
PROGMEM const char text1_2[] = "SSID: ";
PROGMEM const char text1_3[] = "Password:";
PROGMEM const char text1_4[] = "Setting disabled";
PROGMEM const char text1_5[] = "Setting on";
PROGMEM const char text1_6[] = "ESP32 Marauder ";
PROGMEM const char text1_7[] = "WiFi ";
PROGMEM const char text1_8[] = "Bad USB ";
PROGMEM const char text1_9[] = "Device ";
PROGMEM const char text1_10[] = "General Apps ";
PROGMEM const char text1_11[] = "Updating... ";
PROGMEM const char text1_12[] = "Select Method ";
PROGMEM const char text1_13[] = "Confirm Update ";
PROGMEM const char text1_14[] = "ESP8266 Update ";
PROGMEM const char text1_15[] = "Update Firmware ";
PROGMEM const char text1_16[] = "Language ";
PROGMEM const char text1_17[] = "Device Info ";
PROGMEM const char text1_18[] = "Settings ";
PROGMEM const char text1_19[] = "Bluetooth ";
PROGMEM const char text1_20[] = "WiFi Sniffers ";
PROGMEM const char text1_21[] = "WiFi Attacks ";
PROGMEM const char text1_22[] = "WiFi General ";
PROGMEM const char text1_23[] = "Bluetooth Sniffers ";
PROGMEM const char text1_24[] = "Bluetooth General ";
PROGMEM const char text1_25[] = "Shutdown WiFi ";
PROGMEM const char text1_26[] = "Shutdown BLE ";
PROGMEM const char text1_27[] = "Generate SSIDs ";
PROGMEM const char text1_28[] = "Clear SSIDs ";
PROGMEM const char text1_29[] = "Clear APs ";
PROGMEM const char text1_30[] = "Reboot";
PROGMEM const char text1_31[] = "Sniffers";
PROGMEM const char text1_32[] = "Attacks";
PROGMEM const char text1_33[] = "General";
PROGMEM const char text1_34[] = "Bluetooth Sniffer";
PROGMEM const char text1_35[] = "Detect Card Skimmers";
PROGMEM const char text1_36[] = "Test BadUSB";
PROGMEM const char text1_37[] = "Run Ducky Script";
PROGMEM const char text1_38[] = "Draw";
PROGMEM const char text1_39[] = "Web Update";
PROGMEM const char text1_40[] = "SD Update";
PROGMEM const char text1_41[] = "ESP8266 Update";
PROGMEM const char text1_42[] = "Probe Request Sniff";
PROGMEM const char text1_43[] = "Beacon Sniff";
PROGMEM const char text1_44[] = "Deauth Sniff";
PROGMEM const char text1_45[] = "Packet Monitor";
PROGMEM const char text1_46[] = "EAPOL/PMKID Scan";
PROGMEM const char text1_47[] = "Detect Pwnagotchi";
PROGMEM const char text1_48[] = "Detect Espressif";
PROGMEM const char text1_49[] = "Scan APs";
PROGMEM const char text1_50[] = "Beacon Spam List";
PROGMEM const char text1_51[] = "Beacon Spam Random";
PROGMEM const char text1_52[] = "Rick Roll Beacon";
PROGMEM const char text1_53[] = "Probe Req Flood";
PROGMEM const char text1_54[] = "Deauth Flood";
PROGMEM const char text1_55[] = "Join WiFi";
PROGMEM const char text1_56[] = "Select APs";
PROGMEM const char text1_57[] = "AP Clone Spam";
PROGMEM const char text1_58[] = "Raw Capture";
PROGMEM const char text1_59[] = "Station Sniff";
PROGMEM const char text1_60[] = "Clear Stations";
PROGMEM const char text1_61[] = "Select Stations";
PROGMEM const char text1_62[] = "Deauth Targeted";
//SDInterface.cpp texts
PROGMEM const char text2_0[] = "Error, could not find update.bin";
PROGMEM const char text2_1[] = "Starting SD Update...";
PROGMEM const char text2_2[] = "Error, update.bin is empty";
PROGMEM const char text2_3[] = "\nRebooting...\n";
PROGMEM const char text2_4[] = "Could not load update.bin from /";
PROGMEM const char text2_5[] = "File size: ";
PROGMEM const char text2_6[] = "Writing file to partition...";
PROGMEM const char text2_7[] = "Written: ";
PROGMEM const char text2_8[] = "Written only : ";
PROGMEM const char text2_9[] = ". Retry?";
PROGMEM const char text2_10[] = " successfully";
PROGMEM const char text2_11[] = "Update complete";
PROGMEM const char text2_12[] = "Update could not complete";
PROGMEM const char text2_13[] = "Error Occurred. Error #: ";
PROGMEM const char text2_14[] = "Not enough space to begin OTA";
//Web.cpp texts
PROGMEM const char text3_0[] = "Configuring update server...\n\n";
PROGMEM const char text3_1[] = "IP address: ";
PROGMEM const char text3_2[] = "Update: ";
PROGMEM const char text3_3[] = "Bytes complete: ";
PROGMEM const char text3_4[] = "Update Success: ";
PROGMEM const char text3_5[] = "\nCompleted update server setup";
//WiFiScan.cpp texts
PROGMEM const char text4_0[] = " RSSI: ";
PROGMEM const char text4_1[] = "Potential Skimmer: ";
PROGMEM const char text4_2[] = "Already Connected";
PROGMEM const char text4_3[] = "Failed to connect";
PROGMEM const char text4_4[] = "Connected";
PROGMEM const char text4_5[] = "ForcePMKID";
PROGMEM const char text4_6[] = "ForceProbe";
PROGMEM const char text4_7[] = "SavePCAP";
PROGMEM const char text4_8[] = "Probe Flood";
PROGMEM const char text4_9[] = "Clearing APs...";
PROGMEM const char text4_10[] = "APs Cleared: ";
PROGMEM const char text4_11[] = "Clearing SSIDs...";
PROGMEM const char text4_12[] = "SSIDs Cleared: ";
PROGMEM const char text4_13[] = "Generating SSIDs...";
PROGMEM const char text4_14[] = "SSIDs Generated: "; //Add spaces before to match : [15]
PROGMEM const char text4_15[] = " Total SSIDs: "; //Add spaces beforer to match : [14]
PROGMEM const char text4_16[] = "Shutting down WiFi...";
PROGMEM const char text4_17[] = "WiFi not currently initialized";
PROGMEM const char text4_18[] = "Shutting down BLE...";
PROGMEM const char text4_19[] = "BLE not currently initialized";
PROGMEM const char text4_20[] = "Firmware: Marauder"; //From 20 to 35 add spaces so : is in line like it is now
PROGMEM const char text4_21[] = "Version: ";
PROGMEM const char text4_22[] = "ESP-IDF: ";
PROGMEM const char text4_23[] = "WSL Bypass: enabled";
PROGMEM const char text4_24[] = "WSL Bypass: disabled";
PROGMEM const char text4_25[] = "Station MAC: ";
PROGMEM const char text4_26[] = "AP MAC: ";
PROGMEM const char text4_27[] = "";
PROGMEM const char text4_28[] = "SD Card: Connected";
PROGMEM const char text4_29[] = "SD Card Size: ";
PROGMEM const char text4_30[] = "SD Card: Not Connected";
PROGMEM const char text4_31[] = "SD Card Size: 0";
PROGMEM const char text4_32[] = "IP5306 I2C: supported";
PROGMEM const char text4_33[] = "Battery Lvl: ";
PROGMEM const char text4_34[] = "IP5306 I2C: not supported";
PROGMEM const char text4_35[] = "Internal temp: ";
PROGMEM const char text4_36[] = " Detect Espressif ";
PROGMEM const char text4_37[] = " Detect Pwnagotchi ";
PROGMEM const char text4_38[] = " Beacon Sniffer ";
PROGMEM const char text4_39[] = " Deauthentication Sniffer ";
PROGMEM const char text4_40[] = " Probe Request Sniffer ";
PROGMEM const char text4_41[] = " Bluetooth Sniff ";
PROGMEM const char text4_42[] = " Detect Card Skimmers ";
PROGMEM const char text4_43[] = "Scanning for\nBluetooth-enabled skimmers\nHC-03, HC-05, and HC-06...";
PROGMEM const char text4_44[] = " AP Scan ";
PROGMEM const char text4_45[] = "Clearing Stations...";
PROGMEM const char text4_46[] = "Stations Cleared: ";
PROGMEM const char text4_47[] = "Targeted Deauth";
//Making tables
PROGMEM const char *text_table0[] = {text0_0,text0_1, text0_2, text0_3, text0_4, text0_5, text0_6, text0_7, text0_8};
PROGMEM const char *text_table1[] = {text1_0,text1_1,text1_2,text1_3,text1_4,text1_5,text1_6,text1_7,text1_8,text1_9,text1_10,text1_11,text1_12,text1_13,text1_14,text1_15,text1_16,text1_17,text1_18,text1_19,text1_20,text1_21,text1_22,text1_23,text1_24,text1_25,text1_26,text1_27,text1_28,text1_29,text1_30,text1_31,text1_32,text1_33,text1_34,text1_35,text1_36,text1_37,text1_38,text1_39,text1_40,text1_41,text1_42,text1_43,text1_44,text1_45,text1_46,text1_47,text1_48,text1_49,text1_50,text1_51,text1_52,text1_53,text1_54,text1_55,text1_56,text1_57,text1_58,text1_59,text1_60,text1_61,text1_62};
PROGMEM const char *text_table2[] = {text2_0,text2_1,text2_2,text2_3,text2_4,text2_5,text2_6,text2_7,text2_8,text2_9,text2_10,text2_11,text2_12,text2_13,text2_14};
PROGMEM const char *text_table3[] = {text3_0,text3_1,text3_2,text3_3,text3_4,text3_5};
PROGMEM const char *text_table4[] = {text4_0,text4_1,text4_2,text4_3,text4_4,text4_5,text4_6,text4_7,text1_54,text4_9,text4_10,text4_11,text4_12,text4_13,text4_14,text4_15,text4_16,text4_17,text4_18,text4_19,text4_20,text4_21,text4_22,text4_23,text4_24,text4_25,text4_26,text4_27,text4_28,text4_29,text4_30,text4_31,text4_32,text4_33,text4_34,text4_35,text4_36,text4_37,text4_38,text4_39,text4_40,text4_41,text4_42,text4_43,text4_44,text4_45,text4_46,text4_47};
#endif
Not sure how useful the code from ld.exe would be but I can post it if needed.
I had the same problem a moment ago,
it compiled me by updating the arduino ide.
My current version is 2.1.0
Make sure to follow these steps, worked for me:
With any text editor, open %localappdata%\Arduino15\packages\esp32\hardware\esp32\2.0.3\platform.txt
Add -w to the following compiler settings
build.extra_flags.esp32
build.extra_flags.esp32s2
build.extra_flags.esp32s3
build.extra_flags.esp32c3
Add -zmuldefs to the following compiler settings
compiler.c.elf.libs.esp32
compiler.c.elf.libs.esp32s2
compiler.c.elf.libs.esp32s3
compiler.c.elf.libs.esp32c3
