I am using Serial Comms to communicate between two Arduinos. I read somewhere that its is better to transmit and receive using BYTE datatype and that is working fine. However, after some time, the receiver arduino crashes and the serial monitor freezes and the following error shows up.
Sketch uses 4,246 bytes (13%) of program storage space. Maximum is 30,720 bytes.
Global variables use 258 bytes (12%) of dynamic memory, leaving 1,790 bytes for local variables. Maximum is 2,048 bytes.
Exception in thread "EventThread COM5" Exception in thread "AWT-EventQueue-0" java.lang.OutOfMemoryError: Java heap space
at java.lang.StringCoding$StringDecoder.decode(Unknown Source)
at java.lang.StringCoding.decode(Unknown Source)
at java.lang.String.<init>(Unknown Source)
at processing.app.Serial.serialEvent(Unknown Source)
at jssc.SerialPort$EventThread.run(SerialPort.java:1112)
at javax.swing.text.GapContent.getPositionsInRange(Unknown Source)
at javax.swing.text.GapContent$RemoveUndo.<init>(Unknown Source)
at javax.swing.text.GapContent.remove(Unknown Source)
at javax.swing.text.AbstractDocument.handleRemove(Unknown Source)
at javax.swing.text.AbstractDocument.remove(Unknown Source)
at javax.swing.text.AbstractDocument.replace(Unknown Source)
at javax.swing.text.JTextComponent.setText(Unknown Source)
at processing.app.SerialMonitor.close(SerialMonitor.java:107)
at processing.app.AbstractMonitor$1.windowClosing(AbstractMonitor.java:57)
at java.awt.AWTEventMulticaster.windowClosing(Unknown Source)
at java.awt.Window.processWindowEvent(Unknown Source)
at javax.swing.JFrame.processWindowEvent(Unknown Source)
at java.awt.Window.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Window.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$200(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Source)
at java.awt.EventQueue$4.run(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
Exception in thread "cc.arduino.packages.discoverers.NetworkDiscovery timer" java.lang.OutOfMemoryError: Java heap space
Exception in thread "JmDNS(128-61-40-205.local.).Timer" java.lang.OutOfMemoryError: Java heap space
Exception in thread "AWT-EventQueue-0" Exception in thread "JmDNS(fe80:0:0:0:415a:a9fc:ac54:17cc%13.local.).Timer" java.lang.OutOfMemoryError: Java heap space
Without decreasing the amount of data being sent? How would that help? The comment was made to get you to at least consider reducing the amount of data being sent. Perhaps by only sending the data that has changed. Or by sending the data once per second or once per minute or once per day - whatever interval is appropriate. Continuously almost never is.
My application need data to be sent continuously. I am sending a stream of 6 numbers once every 20 ms. So you are saying that this method is not proper for such an application? Should I consider using some other technique.
Also the crashing of the serial monitor does not mean that the arduino has stopped transmitting data, or does it?
I thought that if you decrease the baud rate, the data will be sent at a slower rate and thus the cache will be given time to refresh. Is that not the case?
Once every 20 milliseconds and continuously are NOT the same thing.
Just for shits and giggles, try changing the interval to once every 20 seconds. If that works, then reduce the interval until it no longer works (reliably). Then, you'll know what the maximum rate is.
Sending 1, 2, and 3 as three of the 6 values that are always sent in the same order seems pointless.
If you're doing any serious work with serial comms to the computer, you should install a terminal emulator program on the computer and ditch the serial monitor. I use Tera Term.
PaulS:
I did that and if you decrease the time interval to less than 15ms, there is data loss in the channel and everything is not coming in order. BTW I decreased the baud rate to 19200.
PaulS:
I am sending the numbers so that I know where it is starting and where it is ending. Yeah I understand what you are saying. I can just put a marker at the beginning and then put three numbers. Will try that.
aarg:
Sure I will do that. But I wanted to know that the crashing of the Serial Monitor does not mean that the uP has stopped running the code, or does it?
bigwetfartman:
I see a Java error. Java errors only happen on your PC which suggests a problem communicating between a Arduino and a PC and NOT an error between two Arduinos.
I see code for one Arduino which seems just to send back to the Serial Monitor whatever is sent from the serial monitor.
I see no diagram showing how the two Arduinos are connected - I suspect that is where the problem lies.
Also I don't see any information about which is connected to the PC.
With proper code two Arduinos can communicate for ever.
I've used the below test code to communicate between two arduinos.
//zoomkat 3-5-12 simple delimited ',' string tx/rx
//from serial port input (via serial monitor)
//and print result out serial port
//Connect the sending arduino rx pin to the receiving arduino rx pin.
//Connect the arduino grounds together.
//What is sent to the tx arduino is received on the rx arduino.
//Open serial monitor on both arduinos to test
String readString;
Serial.println("serial delimit test 1.0"); // so I can keep track of what is loaded
//expect a string like wer,qwe rty,123 456,hyre kjhg,
//or like hello world,who are you?,bye!,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >0) {
Serial.print(readString); //prints string to serial port out
Serial.println(','); //prints delimiting ","
//do stuff with the captured readString
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
