Error when uploading [SOLVED]
The error I got is:
Sketch uses 2254 bytes (6%) of program storage space. Maximum is 32256 bytes.
Global variables use 107 bytes (5%) of dynamic memory, leaving 1941 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "/dev/cu.usbmodem1101": No such file or directory
Failed uploading: uploading error: exit status 1
I have not changed any files. All I added was these few lines of code:
lcd.clear();
lcd.setCursor(0, 0);
My full code is:
// include the library code:
#include <LiquidCrystal.h>
// I2C library:
//#include <LiquidCrystal_I2C.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
// I2C: use the line below
// Parameters: LCD address, number of columns = 16, and the number of rows = 2
//LiquidCrystal lcd(0x3F, 16, 2);
  // Normal begin statement for LCD requiring the number of columns and rows:
  lcd.begin(16, 2);                     // Direct wire statement
  // I2C begin statement:
  //lcd.begin();                        // I2C statement
  // I2C: Turn on the blacklight
  //lcd.backlight();
  // Print a message to the LCD.
  lcd.print("Hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  int count = millis() / 1000;
  lcd.print(count);
  if (count == 20) {
    lcd.clear();
    lcd.print("The countdown has");
    lcd.print("ended!");
    lcd.clear();
    lcd.print("YAY!");
    lcd.println("This is cool!");
Can anyone help?
Yes, I have selected the correct port.
I got it to work
Can you share the solution for other readers?
