Hello , i have a problem with my code , and the problem is big error. I have an arduino uno.
Arduino: 1.6.7 (Windows 10), Vývojová deska: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
WARNING: Category '' in library ArduinoUnit is not valid. Setting to 'Uncategorized'
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp: In function 'bool recvRetNumber(uint32_t*, uint32_t)':
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:67:31: warning: left shift count >= width of type [enabled by default]
*number = (temp[4] << 24) | (temp[3] << 16) | (temp[2] << 8) | (temp[1]);
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:67:49: warning: left shift count >= width of type [enabled by default]
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:75:40: error: 'dbSerialPrint' was not declared in this scope
dbSerialPrint("recvRetNumber :");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:76:32: error: 'dbSerialPrintln' was not declared in this scope
dbSerialPrintln(*number);
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:80:44: error: 'dbSerialPrintln' was not declared in this scope
dbSerialPrintln("recvRetNumber err");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp: In function 'uint16_t recvRetString(char*, uint16_t, uint32_t)':
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:150:35: error: 'dbSerialPrint' was not declared in this scope
dbSerialPrint("recvRetString[");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:154:24: error: 'dbSerialPrintln' was not declared in this scope
dbSerialPrintln("]");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp: In function 'bool recvRetCommandFinished(uint32_t)':
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:209:52: error: 'dbSerialPrintln' was not declared in this scope
dbSerialPrintln("recvRetCommandFinished ok");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:213:53: error: 'dbSerialPrintln' was not declared in this scope
dbSerialPrintln("recvRetCommandFinished err");
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp: In function 'bool nexInit()':
C:\Users\mikul\Documents\Arduino\libraries\ITEADLIB_Arduino_Nextion-0.7.0\NexHardware.cpp:225:23: error: 'dbSerialBegin' was not declared in this scope
dbSerialBegin(9600);
exit status 1
Chyba kompilace.
Tento výpis by měl více informací s
"Zobrazit více informací během kompilace"
povoleno v Soubor > Vlastnosti
* @file NexConfig.h
* Options for user can be found here.
* @author Wu Pengfei (email:<pengfei.wu@itead.cc>)
* @date 2015/8/13
* @copyright
* Copyright (C) 2014-2015 ITEAD Intelligent Systems Co., Ltd. \n
* This program is free software; you can redistribute it and/or
* modify it under the terms of the GNU General Public License as
* published by the Free Software Foundation; either version 2 of
* the License, or (at your option) any later version.
#ifndef __NEXCONFIG_H__
#define __NEXCONFIG_H__
* @addtogroup Configuration
* Define DEBUG_SERIAL_ENABLE to enable debug serial.
* Comment it to disable debug serial.
#define DEBUG_SERIAL_ENABLE
* Define dbSerial for the output of debug messages.
#define dbSerial Serial
* Define nexSerial for communicate with Nextion touch panel.
#define nexSerial Serial3
#ifdef DEBUG_SERIAL_ENABLE
#define dbSerial2Print(a) dbSerial2.print(a)
#define dbSerial2Println(a) dbSerial2.println(a)
#define dbSerial2Begin(a) dbSerial2.begin(a)
#else
#define dbSerial2Print(a) do{}while(0)
#define dbSerial2Println(a) do{}while(0)
#define dbSerial2Begin(a) do{}while(0)
#endif
#endif /* #ifndef __NEXCONFIG_H__ */
exit status 1
