I have 2 modbus slaves and the Opta on the RS-485 network.
If I add one of the slaves at a time to the PLC application then it works OK.
When I have both of the slaves in the PLC app I start to get errors.
I've tried creating definitions for the Modbus slaves under the Opta->RS-485 SerialPort branch in Resources. These work better, sometimes the reads from both slaves work, but then I will get a run (5mins) of failures, then they start working again.
If I read them using the API's sysMbMRtu_FC03 etc, then the failure rates are higher - but I still occationally get good reads from both of them, most of the time I get the error MbRqErr_MsgResponseInvalid.
I've got a serial sniffer on the RS-485 bus and the trafic is exactly as I would expect, no corruption, no missing responses, it looks like its all working.
Has anyone else had issues communicating with multiple modbus slaves, any thoughts???
