I cannot compiled any sketch including Ethernet.h.
I tried this, some hours without a solution.
All others examples sketch compile fine.
Have you an idea to fix this ?
Regards.
The sketch :
#include <SPI.h> #include <Ethernet.h>
// the media access control (ethernet hardware) address for the shield:
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
//the IP address for the shield:
byte ip[] = { 10, 0, 0, 177 };
Ethernet.begin(mac, ip);
void loop () {}
The errors :
/usr/share/arduino/libraries/Ethernet/Ethernet.cpp: In member function ‘void EthernetClass::begin(uint8_t*, IPAddress, IPAddress, IPAddress, IPAddress)’:
/usr/share/arduino/libraries/Ethernet/Ethernet.cpp:64:39: error: no matching function for call to ‘W5100Class::setIPAddress(IPAddress::&)’
/usr/share/arduino/libraries/Ethernet/Ethernet.cpp:64:39: note: candidate is:
In file included from /usr/share/arduino/libraries/Ethernet/Ethernet.cpp:1:0:
/usr/share/arduino/libraries/Ethernet/utility/w5100.h:392:6: note: void W5100Class::setIPAddress(uint8_t*)
/usr/share/arduino/libraries/Ethernet/utility/w5100.h:392:6: note: no known conversion for argument 1 from ‘IPAddress::’ to ‘uint8_t* {aka unsigned char*}’
/usr/share/arduino/libraries/Ethernet/Ethernet.cpp:65:38: error: no matching function for call to ‘W5100Class::setGatewayIp(IPAddress::&)’
/usr/share/arduino/libraries/Ethernet/Ethernet.cpp:65:38: note: candidate is:
/usr/share/arduino/libraries/Ethernet/utility/w5100.h:368:6: note: void W5100Class::setGatewayIp(uint8_t*)
/usr/share/arduino/libraries/Ethernet/utility/w5100.h:368:6: note: no known conversion for argument 1 from ‘IPAddress::’ to ‘uint8_t* {aka unsigned char*}’
/usr/share/arduino/libraries/Ethernet/Ethernet.cpp:66:38: error: no matching function for call to ‘W5100Class::setSubnetMask(IPAddress::&)’
/usr/share/arduino/libraries/Ethernet/Ethernet.cpp:66:38: note: candidate is:
/usr/share/arduino/libraries/Ethernet/utility/w5100.h:376:6: note: void W5100Class::setSubnetMask(uint8_t*)
/usr/share/arduino/libraries/Ethernet/utility/w5100.h:376:6: note: no known conversion for argument 1 from ‘IPAddress::’ to ‘uint8_t* {aka unsigned char*}’
Arduino program release 1.0.1 from Debian Testing on a Debian Squeeze base. This distribution works very fine and is stable for me.
$ avr-gcc --version
avr-gcc (GCC) 4.7.0
Yes ! Thank you very much, this is fixing the problem.
I installed the official arduino in an owned directory. I had give the rights to launch the script arduino and all rocks !
But to understand and to try to fix the Debian package (a few mixed release distribution), I investigate a little.
I see with official package :
Experimental: JNI_OnLoad called.
Stable Library
Native lib Version = RXTX-2.1-7
Java lib Version = RXTX-2.1-7
The unstable librxtx-java package Debian that I used, is the 2.2pre2-11. The stable is 2.2pre2-2.
Do you think that is the origin of the issue ?
Another track is a possible problem of rights in the Debian package ? Where are put the .o files or other temporary files ?
I will guess it is something in the Debian version of Ethernet.cpp.
/usr/share/arduino/libraries/Ethernet/Ethernet.cpp: In member function ‘void EthernetClass::begin(uint8_t*, IPAddress, IPAddress, IPAddress, IPAddress)’: /usr/share/arduino/libraries/Ethernet/Ethernet.cpp:64:39: error: no matching function for call to ‘W5100Class::setIPAddress(IPAddress::&)’
I'm running Arduino 1.0.1 on Ubuntu 11.10 and have what looks like the same problem ...
So... I had a careful look at the code and the lines that are wrong are about #64, where the IPAddress union _address is used when the method raw_address() is needed, as shown below ...
Insure you are running v1.0.1. I downloaded it from the Arduino website and unpacked it in a local directory. The I run the arduino shell script in that directory. It doesn't use the IDE in /usr/share/arduino/.
