The proper way to interface a ESC to a Arduino is using the servo library commands, not analogWrite PWM commands. ESCs are built to emulate acting just like a servo from a control point of view. Also you will need to find out the proper ‘arming’ commands to activate the ESC from the arduino. Arming is a safety feature on ESC that’s prevents them from starting off when first powering on. Usually it’s a sequence of 100% signal for one second or so, 0% for one second or so, and wait for ESC to beep signifying it’s ready to accept servo speed commands. Yours may have a different sequence so read the operators manual for the ESC.
hi Lefty
Thanks for replying.
Ok, servo lib will be used then. I just think i noticed ,for the motor, said 8k PWM.
Never touched into r/c esc tuning before. It describes tuning process seen thowards a finished rc-system. I have no idea howto realize that thowards a arduino output.
Ive seen some esc tuning kits, wonder if they ease up the settings of asc, eliminating use of rc-unit?
regards
retrolefty:
The proper way to interface a ESC to a Arduino is using the servo library commands, not analogWrite PWM commands. ESCs are built to emulate acting just like a servo from a control point of view. Also you will need to find out the proper 'arming' commands to activate the ESC from the arduino. Arming is a safety feature on ESC that's prevents them from starting off when first powering on. Usually it's a sequence of 100% signal for one second or so, 0% for one second or so, and wait for ESC to beep signifying it's ready to accept servo speed commands. Yours may have a different sequence so read the operators manual for the ESC.
If you look under the files tab, (in the link you provided) you can find the manual.
As far as I can see the only arming process required is that you should make a loop lasting a couple of seconds while
writing 0 or 180 using the servoLib (that should correspond to throttle stick set at 0.)
Servo test code you can try with the ESC. Send a 0, wait a couple of seconds, then send a 90 to see if the ESC arms (or what ever arming sequence is used with the ESC).
// zoomkat 10-22-11 serial servo test
// type servo position 0 to 180 in serial monitor
// or for writeMicroseconds, use a value like 1500
// for IDE 0022 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(7); //the pin for the servo control
Serial.println("servo-test-22-dual-input"); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
readString=""; //empty for next input
Erni:
Hi thanks for answer.
The inputs to uC are comming from thumbpotentiometer. Well see to it that the informations input to the servp is of values 0-180 using the thumbpot.
I hope the servolib manages upto 4 diffrent servoes. Thats something Ill have to checkout.
zoomkat:
// Powering a servo from the arduino usually DOES NOT WORK.
String readString; #include <Servo.h>
Serial.println(“servo-test-22-dual-input”); // so I can keep track of what is loaded
One hint that might help with arming - don't expect an ESC to respond to a sudden discontinuous change in command angle -
it may assume this is due to co-channel interference and simply cut-out. Ramp the servo.write () values up and down
smoothly (its also a lot safer, RC brushless motors are extremely high power - if connected to a propeller they can cut a finger
to the bone without the slightest problem - this is why an arming sequence is used and why it beeps before starting).
If the motor is spinning anything like a prop then goggles and gloves are strongly advised.
