ESC.writeMicroseconds only works in for-loops
Hi everyone.
I am using the Servo.h library to control some ESC's, but I'm running into some problems. For some reason, ESC.writeMicroseconds() will ONLY work in a for loop.
The following code is copied from an online example. Does NOT WORK.
#include <Servo.h>
Servo ESC;     // create servo object to control the ESC
int test = 1250;
  ESC.attach(6,1000,2000); // (pin, min pulse width, max pulse width in microseconds)
  delay(6000);
  Serial.println(test);
  Serial.println(millis());
  ESC.writeMicroseconds(test);
  delay(10);
Produces the following output:
1250 //"test"
6009 //millis()
1250
6021
1250
6031
The code with the corresponding for-loop (only the void loop() is changed. EVERYTHING else is identical)
   for (int i = 1000; i < 1300; i++) {
    ESC.writeMicroseconds(i);
    if (i> 1250)  {
      i -= 1;
    delay(10);
    Serial.println(i);
This (after having run through values 1000 to 1246) produces following output:
1247
8589
1248
8599
1249
8610
1250
I have no clue how to solve this, since the Servo.h examples for ESC's show, that you should be able to just use writeMicroseconds() in any loop.
I suspect the problem with your first (non-working) version is that you are printing too often and the Serial Output Buffer is getting choked.
Change delay(10) to delay(500) and see what happens.
...R
Trying to write a value every 10ms when the Servo.h output operates at 50Hz, i.e. 20ms period, seems a bit odd and certainly not anything I've tried. But the output seems to show that it's doing what you asked so what exactly do you mean by "does NOT WORK"?
Steve
Robin2 - Both versions print at the same frequency and the output proves it, so that should not change anything significant. If the buffer is getting choked on the non-working code, it should be choked on the working code
Slipstick - I see your point, but neither Serial.print() or the delay is responsible for the behavior. I have tested with various delays and with or without Serial.print. By "Does not work" I mean: Motor doesn't turn. ESC beeps identically to that of the working code, but the motor doesn't turn as opposed to the working code
If it's any help, this code works as well:
#include <Servo.h>
Servo ESC1;
int tempPWMvalue = 0;
int PWMvalue = 0; // actual value to be sent to the ESC (0-180)
  ESC1.attach(6, 1000, 2000); //D6, large breakout for test LEFT MOTOR, FIXED
  if (Serial.available())  {
    tempPWMvalue = Serial.parseInt();
    if (tempPWMvalue != 0)  {
      PWMvalue = tempPWMvalue;
    if (PWMvalue > 180)  {
      PWMvalue = 180;
    Serial.print("PWMvalue is: ");  Serial.print(PWMvalue); Serial.println("");
ESC1.write(PWMvalue);
Needs to be included since the Serial.available returns 0 after the time-out period. This is filtered so that only the values I enter are sent to the ESC
kristianslot:
Perhaps.
But did you try my suggestion?
...R
In your original code if you replace .writeMicroseconds() with the equivalent .write(45) does that work?
What ESC/motor are you using?
Steve
kristianslot:
If it's an ESC for a quadcopter, it has to be armed before it accepts commands. In the sketch that 'doesn't work', try putting this at the end of setup():
  ESC.writeMicroseconds(1000);
Perhaps that will be enough to arm the ESC.
Is the "i" in the if block the same as the "i" in the for loop?
Never mind.
