I remember using ICs of that vintage.
The date code could easily be confused with the part number - 7444 vs 7404
The base metal is always steel to give stiffness and strength to the pins. I was shocked to learn a vast majority of leaded components use steel. Diodes in particular.
Yeah, a magnet identifies those with ferrous content.
In my case, the bags are taking the role of the small drawers. Each bag contains a specific part model (e.g., 5% 1/4 W 1000 ohm through hole resistors) and those bags are all inside a bin that contains a general part type (e.g., resistors).
This is less convenient to use than a storage system like yours that has a dedicated drawer for each part model, since I have to spend some time rummaging through the bin to find the bag for the specific part I need. However, the cost of my storage system is significantly less (at least for a reasonably comprehensive collection of parts), especially when making an "apples to apples" comparison of the cost of my system compared to that of drawers that are ESD safe out of the box.
That's what I have used too so far except for capacitors. Bins, boxes, I'm looking forward to get rid of them. Some foam sheets, labels and it'll be
I don't know if it will be a problem for the drawers, but I found that the adhesive labels and sheets I had did not adhere well and permanently to the plastic of the bags. They would start peeling off after a while. I purchased an assortment of adhesive paper sheets (I prefer these to the pre-cut labels as they allow me to make labels of any size an shape instead of being constrained to predefined dimensions) and tested them all. I found this model has excellent adhesive for my application:
The drawers I got have a small pocket, holder, at front where you can insert a square label, meaning no adhesive directly onto the drawers. Maybe I'll just number the drawers, and make an index.. that's actually a great idea. A whole drawer = number, a drawer with compartments = number + a letter (a,b,c) for every compartment. The index can be used in a spreadsheet, over all the components...
Thanks everyone for the inspiration!
I recognize those types of IC's at the right column. From the 70's and 80's, when there were 8-bit computers. What architecture?
It's mostly Z80 and 8080 stuff in that section. But there's one or two of a whole lot of families. 8085, 1802, 6502, 6809, 2650, 8051, 8088, early PICs, you name it. Some salvaged from PCBs, some bought for pennies as obsolete/going out of business stock, and some bought when it was leading edge stuff.
And out of frame in a slightly more modern section, there is a whole drawer of ATmega and ATtiny chips.
That brings back some memories — are there any good uses for these in modern projects (in case I'm inspired to take a trip down memory lane)?
