Hello team, I am trying to make my first project with Alexa and my ESP-01. Alexa is able to see the device, is able to turn on or off (I can see it in the serial monitor) but the builtin led doesn't turn on or off. What am I doing wrong?
#include <Arduino.h>
#if defined(ESP8266)
#include <ESP8266WiFi.h>
#elif defined(ESP32)
#include <WiFi.h>
#endif
#include <ESPAsyncWebServer.h>
#include "fauxmoESP.h"
// Rename the credentials.sample.h file to credentials.h and
// edit it according to your router configuration
#define WIFI_SSID "mywifinetwork"
#define WIFI_PASS "password"
fauxmoESP fauxmo;
AsyncWebServer server(80);
#define SERIAL_BAUDRATE 115200
#define LED_BUILTIN 2
// Wifi
void wifiSetup() {
// Set WIFI module to STA mode
WiFi.mode(WIFI_STA);
// Connect
Serial.printf("[WIFI] Connecting to %s ", WIFI_SSID);
WiFi.begin(WIFI_SSID, WIFI_PASS);
// Wait
Serial.print(".");
delay(100);
// Connected!
Serial.printf("[WIFI] STATION Mode, SSID: %s, IP address: %s\n", WiFi.SSID().c_str(), WiFi.localIP().toString().c_str());
void serverSetup() {
// Custom entry point (not required by the library, here just as an example)
server.on("/index.html", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(200, "text/plain", "Hello, world");
// These two callbacks are required for gen1 and gen3 compatibility
server.onRequestBody([](AsyncWebServerRequest *request, uint8_t *data, size_t len, size_t index, size_t total) {
if (fauxmo.process(request->client(), request->method() == HTTP_GET, request->url(), String((char *)data))) return;
// Handle any other body request here...
server.onNotFound([](AsyncWebServerRequest *request) {
String body = (request->hasParam("body", true)) ? request->getParam("body", true)->value() : String();
if (fauxmo.process(request->client(), request->method() == HTTP_GET, request->url(), body)) return;
// Handle not found request here...
// Start the server
server.begin();
// Init serial port and clean garbage
Serial.begin(SERIAL_BAUDRATE);
// LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH); // Our LED_BUILTIN has inverse logic (high for OFF, low for ON)
// Wifi
wifiSetup();
// Web server
serverSetup();
// Set fauxmoESP to not create an internal TCP server and redirect requests to the server on the defined port
// The TCP port must be 80 for gen3 devices (default is 1901)
// This has to be done before the call to enable()
fauxmo.createServer(false);
fauxmo.setPort(80); // This is required for gen3 devices
// You have to call enable(true) once you have a WiFi connection
// You can enable or disable the library at any moment
// Disabling it will prevent the devices from being discovered and switched
fauxmo.enable(true);
// You can use different ways to invoke alexa to modify the devices state:
// "Alexa, turn kitchen on" ("kitchen" is the name of the first device below)
// "Alexa, turn on kitchen"
// "Alexa, set kitchen to fifty" (50 means 50% of brightness)
// Add virtual devices
// fauxmo.addDevice("kitchen");
fauxmo.addDevice("luce");
// You can add more devices
//fauxmo.addDevice("light 3");
//fauxmo.addDevice("light 4");
//fauxmo.addDevice("light 5");
//fauxmo.addDevice("light 6");
//fauxmo.addDevice("light 7");
//fauxmo.addDevice("light 8");
fauxmo.onSetState([](unsigned char device_id, const char * device_name, bool state, unsigned char value) {
// Callback when a command from Alexa is received.
// You can use device_id or device_name to choose the element to perform an action onto (relay, LED_BUILTIN,...)
// State is a boolean (ON/OFF) and value a number from 0 to 255 (if you say "set kitchen light to 50%" you will receive a 128 here).
// Just remember not to delay too much here, this is a callback, exit as soon as possible.
// If you have to do something more involved here set a flag and process it in your main loop.
// if (0 == device_id) digitalWrite(RELAY1_PIN, state);
// if (1 == device_id) digitalWrite(RELAY2_PIN, state);
// if (2 == device_id) analogWrite(LED_BUILTIN1_PIN, value);
Serial.printf("[MAIN] Device #%d (%s) state: %s value: %d\n", device_id, device_name, state ? "ON" : "OFF", value);
// For the example we are turning the same LED_BUILTIN on and off regardless fo the device triggered or the value
// digitalWrite(LED_BUILTIN, !state); // we are nor-ing the state because our LED_BUILTIN has inverse logic.
if (state==1) {
Serial.printf("accendo\n");
digitalWrite(LED_BUILTIN, LOW);
delay(4000);
else if (state==0) {
Serial.printf("spengo");
delay(2000);
// fauxmoESP uses an async TCP server but a sync UDP server
// Therefore, we have to manually poll for UDP packets
fauxmo.handle();
// This is a sample code to output free heap every 5 seconds
// This is a cheap way to detect memory leaks
static unsigned long last = millis();
if (millis() - last > 5000) {
last = millis();
//Serial.printf("[MAIN] Free heap: %d bytes\n", ESP.getFreeHeap());
