ESP 32-S3-WROOM-1 not uploading
Hello, i am trying to upload a sketch to the ESP, but it always gives me errors once it starts connecting. this is what it states:
Sketch uses 289917 bytes (22%) of program storage space. Maximum is 1310720 bytes.
Global variables use 18376 bytes (5%) of dynamic memory, leaving 309304 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.6
Serial port /dev/cu.usbmodem54E20192131
Connecting....
Chip is ESP32-S3 (revision v0.2)
Features: WiFi, BLE
Crystal is 40MHz
MAC: 74:4d:bd:71:45:70
Uploading stub...
A fatal error occurred: Failed to write to target RAM (result was 01070000: Operation timed out)
Failed uploading: uploading error: exit status 2
In the arduino IDE it recognizes the module and i already downloaded and installed the CH34xVCPDriver.
I am on a macbook pro intel core (2017) OS12.0.1
The usb-c cable i am using is from a flash harddrive, so it does carry power and data in both directions.
This is my first try with both arduino or esp stuff, electronics in general...
Any ideas?
Thank you.
Are you are sure you have correct board selected?
I'm not mac user, have a look if this can help you:
I am on a Silicon Mac M3, and I have never seen that error even on my older Macs. Just for the heck of it, does that board have a button that needs to be pressed during the upload? Also have you checked the migration document, some things have been broke for S3 boards and V3 board config files. A quick check is to roll your boards back from 3.0.x to 2.0.17.
This is in the BOARDS, NOT library. NOT Arduino ESP32, just esp32
Tried this, but still not working. I already tried with pressing all the buttons and with another usb slot on my mac. I figured it can't be the slot as arduino recognizes there is a board connected to the port...
The fact it got your MAC address means the cable is good. The only thing I want you to try is when you see that message next attempt, press the button labelled BOOT and keep it pressed until the upload is done or it fails.
