I have a simple task running on ESP32 that reads an I2C A/D, and updates an array with the data it reads, so other tasks can access the data. It all works perfectly, UNTIL I implement a critical section around the writes to the array, at which point it starts throwing exceptions.
Here is the function in question:
void readADC(void *parameter)
for(;;)
switch(curADCChannel)
case 0:
// Read mode ADC
modeADCValue = analogRead(MODE_ADC_PIN);
// Start conversion of first channel
ADS1015.readADC_SingleEnded(curADCChannel, false);
curADCChannel++;
case 1:
case 2:
case 3:
case 4:
// Read result from last channel
int readchan = curADCChannel - 1;
portMUX_TYPE myMutex = portMUX_INITIALIZER_UNLOCKED;
taskENTER_CRITICAL(&myMutex);
ADCValues[readchan] = ADS1015.getLastConversionResults(false);
taskEXIT_CRITICAL(&myMutex);
if (curADCChannel < 4)
// Start conversion of next channel
curADCChannel++;
curADCChannel = 0;
vTaskDelay(2 / portTICK_PERIOD_MS);
If I simply comment out the calls to taskENTER_CRITICAL and taskEXIT_CRITICAL, then it works perfectly.
The task is created by this:
xTaskCreate(
readADC, // Function that should be called
"readADC", // Name of the task (for debugging)
1000, // Stack size (bytes)
NULL, // Parameter to pass
1, // Task priority
NULL // Task handle
PC: 0x40089f25: vTaskEnterCritical at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/portmux_impl.inc.h line 88
EXCVADDR: 0x00000000
Decoding stack results
0x400888ed: xQueueGenericSend at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/queue.c line 734
0x40083705: ipc_task at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/esp32/ipc.c line 64
0x40088f15: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c line 143
I2C relies on interrupts to work correctly, when you enter a critical section all interrupts are disabled.
You don't need a critical section to write to a shared array. Use an array of type std::atomic (or use an std::mutex) to guard your shared data, not a critical section.
Critical Sections & Disabling Interrupts: In ESP-IDF FreeRTOS, critical sections are implemented using mutexes. Entering critical sections involve taking a mutex, then disabling the scheduler and interrupts of the calling core. However the other core is left unaffected. If the other core attemps to take same mutex, it will spin until the calling core has released the mutex by exiting the critical section.
6v6gt:
Are you attempting to enclose an I2C transaction in a critical section? I’d assume that would not work unless I found evidence to the contrary.
Please look at the code I posted! The critical section surrounds ONLY a single write to a global variable. It has NOTHING to do with I2C. The I2C portion of the code works perfectly.
PieterP:
Pieter
That is not the way it's done on the ESP32, which has two processors. The taskCRITICAL functions are specifically designed for the ESP32 multi-processor environment.
Idahowalker:
I am curious why the task has such a low priority
Because what it's doing is not terribly important? It should make no difference, since the code works perfectly WITHOUT any protection on the critical section, and the two processors are both lightly-loaded, so there is plenty of bandwidth to go around.
Which is exactly where I got the example that I used for implementing the critical section that crashes the program....
RayLivingston:
Well, it wasn’t very clear from that code snippet you posted and you don’t appear to be very grateful for the responses you’ve received. Post a link to that ADS1015 library if you want someone to look at it for you.
RayLivingston:
6v6gt is correct, and there's no reason for the hostile tone. Your code is doing I2C communication in the critical section, just have a look at the Adafruit_ADS1015::getLastConversionResults() function you're using.
RayLivingston:
I have plenty of experience with the ESP32 and thread-safe programming. Atomic variables and mutexes are also specifically for multi-processor environments.
taskENTER_CRITICAL disables interrupts and stops the scheduler, which is totally overkill for protecting shared data, it uses locks, disables interrupts, and stops scheduling, all of those are unnecessary. You're just writing a single integer, you don't need a lock, just an std::atomic, you're not accessing the shared data inside of an ISR, so disabling interrupts is pointless, and there's nothing to be gained from disabling the scheduler either.
Just use atomic variables to share the data between tasks.
PieterP:
taskENTER_CRITICAL disables interrupts and stops the scheduler, which is totally overkill for protecting shared data, it uses locks, disables interrupts, and stops scheduling....
My reading of the docs says that's true. But, it can only disable interrupts and stop scheduling on the Core that calls taskENTER_CRITICAL(). In order for the scheme to work, the OTHER Core must play by the rules. Meaning it can't try to access the resources being protected by the critical section unless it obtains the lock (mutex). To do so, it must also call taskENTER_CRITICAL() using the same portMUX_TYPE * variable. This is different than a critical section in a single-core environment. There you just need to disable interrupts and stop scheduling. That's enough to assure you that that the protected resources will only be accessed by the code/task in the critical section.
My Reasoning:
6v6gt:
From the library link supplied by @peterp, it also appears that methods has a delay() statement in it which I guess relies on a timer interrupt.
