#include <ESP32Servo.h>
#include <WiFi.h>
#include <WebSocketsServer.h>
#define TRIG_PIN 32
#define ECHO_PIN 33
#define BUZZER_PIN 15
#define SERVO_PIN 18
const char* ssid = "Yotam’s iPhone";
const char* password = "12345678";
Servo myServo;
WebSocketsServer webSocket(81);
float distanceArray[181] = {0};
pinMode(TRIG_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(BUZZER_PIN, OUTPUT);
connectWiFi();
webSocket.begin();
Serial.println("WebSocket server started on port 81");
webSocket.onEvent(webSocketEvent);
myServo.setPeriodHertz(50);
myServo.attach(SERVO_PIN, 1000, 2000);
myServo.write(90);
testSensor();
testServo();
Serial.print("ESP32 IP Address: ");
void connectWiFi() {
// Static IP configuration - tailored for phone hotspot
IPAddress local_IP(172, 20, 10, 6); // This will be the ESP32's IP on the hotspot
IPAddress gateway(172, 20, 10, 1); // Most phones use this gateway for hotspots
IPAddress subnet(255, 255, 255, 0); // Standard subnet mask
Serial.print("Connecting to WiFi: ");
Serial.println(ssid);
// Apply static IP configuration
if (!WiFi.config(local_IP, gateway, subnet)) {
Serial.println("⚠️ Failed to configure Static IP!");
WiFi.begin(ssid, password);
int retry = 0;
while (WiFi.status() != WL_CONNECTED && retry < 30) {
Serial.print(".");
retry++;
if (WiFi.status() == WL_CONNECTED) {
Serial.println("\n✅ WiFi Connected!");
Serial.print("📡 ESP32 Static IP: ");
Serial.println("\n❌ WiFi Connection Failed. Restarting...");
delay(2000);
ESP.restart();
void testSensor() {
Serial.println("Testing ultrasonic sensor...");
for (int i = 0; i < 5; i++) {
float dist = getDistance();
Serial.print("Distance: ");
Serial.println(dist);
void testServo() {
Serial.println("Testing servo...");
myServo.write(90);
myServo.write(0);
myServo.write(180);
myServo.write(90);
float getDistance() {
digitalWrite(TRIG_PIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIG_PIN, HIGH);
delayMicroseconds(10);
long duration = pulseIn(ECHO_PIN, HIGH, 60000);
if (duration == 0) {
Serial.println("Sensor timeout");
return 999;
float distance = duration * 0.0343 / 2;
return distance;
float newDistanceArray[181] = {0};
webSocket.loop();
for (int pos = 0; pos <= 180; pos += 5) {
myServo.write(pos);
delay(300);
if (dist != 999) {
newDistanceArray[pos] = dist;
sendWebData(pos, dist);
for (int pos = 180; pos >= 0; pos -= 5) {
myServo.write(pos);
delay(300);
if (dist != 999) {
for (int i = 0; i <= 180; i += 5) {
if (abs(newDistanceArray[i] - distanceArray[i]) > 20 && newDistanceArray[i] < 999) {
Serial.println("INTRUDER DETECTED!");
digitalWrite(BUZZER_PIN, HIGH);
digitalWrite(BUZZER_PIN, LOW);
memcpy(distanceArray, newDistanceArray, sizeof(distanceArray));
delay(2000);
void sendWebData(int angle, float distance) {
String message = "{\"angle\": " + String(angle) + ", \"distance\": " + String(distance) + "}";
Serial.println("Sending data: " + message);
webSocket.broadcastTXT(message);
void webSocketEvent(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
if (type == WStype_CONNECTED) {
Serial.println("Client Connected!");
} else if (type == WStype_TEXT) {
Serial.print("Received: ");
Serial.println((char*)payload);
the output is always ❌ WiFi Connection Failed. Restarting..., does anyone know why?
