Esp-Now problem
I am totally green to all this and no nothing about coding I asked before but apparently didn't ask correctly so I'll try again and maybe will find someone willing to help. I am trying to make a simple connection between 2 esp32 boards using esp-now with a simple button on one, and when pressed it will light the led on the other. I have watched the videos and copied the code given and still get errors. So I am trying to use the examples in Arduino ide to make something but as I said I know nothing about coding. Here is what I have and I would like to know which lines are wrong.
Thank You.
**Master**
#include <esp_now.h>
#include <WiFi.h>
#include <esp_wifi.h> // only for esp_wifi_set_channel()
#define BUTTON_PIN 2 // Assuming you connect the button to GPIO 2
// Structure to hold the data being sent
typedef struct {
  bool buttonState;
} MyData;
// Create an instance of the MyData structure
MyData myData;
#define CHANNEL 1
/** This is all the data about the peer**/
esp_now_peer_info_t slave;
/** Init ESP Now **/
void InitESPNow() {
  esp_now_init();
/** Scan for slaves in AP mode and add as peer if found **/
void ScanForSlave() {
  int16_t scanResults = WiFi.scanNetworks(false, false, false, 300, CHANNEL); // Scan only on one channel
     for (int i = 0; i < scanResults; ++i) {
        String SSID = WiFi.SSID(i);
      String BSSIDstr = WiFi.BSSIDstr(i);
      if (SSID.indexOf("RX") == 0) {
        int mac[6];
        if ( 6 == sscanf(BSSIDstr.c_str(), "%x:%x:%x:%x:%x:%x",  &mac[0], &mac[1], &mac[2], &mac[3], &mac[4], &mac[5] ) ) {
          for (int ii = 0; ii < 6; ++ii ) {
            slave.peer_addr[ii] = (uint8_t) mac[ii];
        slave.channel = CHANNEL; // pick a channel
        slave.encrypt = 0; // no encryption
/** Pair the slave with master **/
bool manageSlave() {
  esp_err_t addStatus = esp_now_add_peer(&slave);
  return true;
/** The all important data! **/
uint8_t data = 0;
// send data
void sendData() {
  data++;
  const uint8_t *peer_addr = slave.peer_addr;
  Serial.print("Sending: "); Serial.println(data);
  esp_err_t result = esp_now_send(peer_addr, &data, sizeof(data));
/** callback when data is sent from Master to Slave **/
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
  Serial.print("I sent my data ->");
  // Initialize the button pin
  pinMode(BUTTON_PIN, INPUT);
  WiFi.mode(WIFI_STA);
  Serial.print("STA MAC: "); Serial.println(WiFi.macAddress());
  InitESPNow();
  esp_now_register_send_cb(OnDataSent);
  ScanForSlave();
  manageSlave();
  // Read button state
  bool buttonState = digitalRead(BUTTON_PIN);
  // Check if button state has changed
  if (buttonState != myData.buttonState) {
    myData.buttonState = buttonState;
  sendData();
  delay(3000);
**And Slave**
   ESPNOW - Basic communication - Slave
   Date: 26th September 2017
   Author: Arvind Ravulavaru <https://github.com/arvindr21>
   Purpose: ESPNow Communication between a Master ESP32 and a Slave ESP32
   Description: This sketch consists of the code for the Slave module.
   Resources: (A bit outdated)
   a. https://espressif.com/sites/default/files/documentation/esp-now_user_guide_en.pdf
   b. http://www.esploradores.com/practica-6-conexion-esp-now/
   << This Device Slave >>
   Flow: Master
   Step 1 : ESPNow Init on Master and set it in STA mode
   Step 2 : Start scanning for Slave ESP32 (we have added a prefix of `slave` to the SSID of slave for an easy setup)
   Step 3 : Once found, add Slave as peer
   Step 4 : Register for send callback
   Step 5 : Start Transmitting data from Master to Slave
   Flow: Slave
   Step 1 : ESPNow Init on Slave
   Step 2 : Update the SSID of Slave with a prefix of `slave`
   Step 3 : Set Slave in AP mode
   Step 4 : Register for receive callback and wait for data
   Step 5 : Once data arrives, print it in the serial monitor
   Note: Master and Slave have been defined to easily understand the setup.
         Based on the ESPNOW API, there is no concept of Master and Slave.
         Any devices can act as master or salve.
#include <WiFi.h>
const int ledPin = LED_BUILTIN;
#define CHANNEL 1
// Init ESP Now with fallback
void InitESPNow() {
  WiFi.disconnect();
  if (esp_now_init() == ESP_OK) {
    Serial.println("ESPNow Init Success");
  else {
    Serial.println("ESPNow Init Failed");
    // Retry InitESPNow, add a counte and then restart?
    // InitESPNow();
    // or Simply Restart
    ESP.restart();
// config AP SSID
void configDeviceAP() {
  const char *SSID = "Slave_1";
  bool result = WiFi.softAP(SSID, "Slave_1_Password", CHANNEL, 0);
  if (!result) {
    Serial.println("AP Config failed.");
    Serial.println("AP Config Success. Broadcasting with AP: " + String(SSID));
    Serial.print("AP CHANNEL "); Serial.println(WiFi.channel());
  Serial.println("ESPNow/Basic/Slave Example");
  //Set device in AP mode to begin with
  WiFi.mode(WIFI_AP);
  // configure device AP mode
  configDeviceAP();
  // This is the mac address of the Slave in AP Mode
  Serial.print("AP MAC: "); Serial.println(WiFi.softAPmacAddress());
  // Init ESPNow with a fallback logic
  InitESPNow();
  // Once ESPNow is successfully Init, we will register for recv CB to
  // get recv packer info.
  esp_now_register_recv_cb(OnDataRecv);
// callback when data is recv from Master
void OnDataRecv(const esp_now_recv_info_t * info, const uint8_t *data, int data_len) {
  char macStr[18];
  snprintf(macStr, sizeof(macStr), "%02x:%02x:%02x:%02x:%02x:%02x",
           info->src_addr[0], info->src_addr[1], info->src_addr[2], info->src_addr[3], info->src_addr[4], info->src_addr[5]);
  Serial.print("Last Packet Recv from: "); Serial.println(macStr);
  Serial.print("Last Packet Recv Data: "); Serial.println(*data);
  Serial.println("");
// read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
  // check if the pushbutton is pressed. If it is, the buttonState is HIGH:
  if (buttonState == HIGH) {
    // turn LED on:
    digitalWrite(ledPin, HIGH);
    // turn LED off:
    digitalWrite(ledPin, LOW);
It would be useful if you posted the errors.
Assuming that you still get errors, please post them.
I know nothing about esp-now and ESP32 boards so more than likely can't help further.
Note just in case: please use code tags when posting the errors.
Things will become much easier to resolve if you know the basics
Take a look into this tutorial:
Arduino Programming Course
It is easy to understand and has a good mixture between explaining important concepts and example-codes to get you going. So give it a try and report your opinion about this tutorial.
Dronebotworkshop does a good job of stepping through the ESP-Now network...
This is actually one of the sites I was trying to get working, when I used his code.
```cpp
  ESP-NOW Multi Unit Demo
  esp-now-multi.ino
  Broadcasts control messages to all devices in network
  Load script on multiple devices
  DroneBot Workshop 2022
  https://dronebotworkshop.com
// Include Libraries
#include <WiFi.h>
// Define LED and pushbutton state booleans
bool buttonDown = false;
bool ledOn = false;
// Define LED and pushbutton pins
#define STATUS_LED 15
#define STATUS_BUTTON 5
void formatMacAddress(const uint8_t *macAddr, char *buffer, int maxLength)
// Formats MAC Address
  snprintf(buffer, maxLength, "%02x:%02x:%02x:%02x:%02x:%02x", macAddr[0], macAddr[1], macAddr[2], macAddr[3], macAddr[4], macAddr[5]);
void receiveCallback(const uint8_t *macAddr, const uint8_t *data, int dataLen)
// Called when data is received
  // Only allow a maximum of 250 characters in the message + a null terminating byte
  char buffer[ESP_NOW_MAX_DATA_LEN + 1];
  int msgLen = min(ESP_NOW_MAX_DATA_LEN, dataLen);
  strncpy(buffer, (const char *)data, msgLen);
  // Make sure we are null terminated
  buffer[msgLen] = 0;
  // Format the MAC address
  char macStr[18];
  formatMacAddress(macAddr, macStr, 18);
  // Send Debug log message to the serial port
  Serial.printf("Received message from: %s - %s\n", macStr, buffer);
  // Check switch status
  if (strcmp("on", buffer) == 0)
    ledOn = true;
    ledOn = false;
  digitalWrite(STATUS_LED, ledOn);
void sentCallback(const uint8_t *macAddr, esp_now_send_status_t status)
// Called when data is sent
  char macStr[18];
  Serial.print("Last Packet Sent to: ");
  Serial.print("Last Packet Send Status: ");
  Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
void broadcast(const String &message)
// Emulates a broadcast
  // Broadcast a message to every device in range
  uint8_t broadcastAddress[] = {0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF};
  esp_now_peer_info_t peerInfo = {};
  memcpy(&peerInfo.peer_addr, broadcastAddress, 6);
  if (!esp_now_is_peer_exist(broadcastAddress))
    esp_now_add_peer(&peerInfo);
  // Send message
  esp_err_t result = esp_now_send(broadcastAddress, (const uint8_t *)message.c_str(), message.length());
  // Print results to serial monitor
  if (result == ESP_OK)
    Serial.println("Broadcast message success");
  else if (result == ESP_ERR_ESPNOW_NOT_INIT)
    Serial.println("ESP-NOW not Init.");
  else if (result == ESP_ERR_ESPNOW_ARG)
    Serial.println("Invalid Argument");
  else if (result == ESP_ERR_ESPNOW_INTERNAL)
    Serial.println("Internal Error");
  else if (result == ESP_ERR_ESPNOW_NO_MEM)
    Serial.println("ESP_ERR_ESPNOW_NO_MEM");
  else if (result == ESP_ERR_ESPNOW_NOT_FOUND)
    Serial.println("Peer not found.");
    Serial.println("Unknown error");
  // Set up Serial Monitor
  // Set ESP32 in STA mode to begin with
  Serial.println("ESP-NOW Broadcast Demo");
  // Print MAC address
  Serial.print("MAC Address: ");
  // Disconnect from WiFi
  WiFi.disconnect();
  // Initialize ESP-NOW
    Serial.println("ESP-NOW Init Success");
    esp_now_register_recv_cb(receiveCallback);
    esp_now_register_send_cb(sentCallback);
    Serial.println("ESP-NOW Init Failed");
    delay(3000);
    ESP.restart();
  // Pushbutton uses built-in pullup resistor
  pinMode(STATUS_BUTTON, INPUT_PULLUP);
  // LED Output
  pinMode(STATUS_LED, OUTPUT);
  if (digitalRead(STATUS_BUTTON))
    // Detect the transition from low to high
    if (!buttonDown)
      buttonDown = true;
      // Toggle the LED state
      ledOn = !ledOn;
      // Send a message to all devices
      if (ledOn)
        broadcast("on");
        broadcast("off");
    // Delay to avoid bouncing
    // Reset the button state
    buttonDown = false;
I get the error message
Compilation error: invalid conversion from 'void (*)(const uint8_t*, const uint8_t*, int)' {aka 'void (*)(const unsigned char*, const unsigned char*, int)'} to 'esp_now_recv_cb_t' {aka 'void (*)(const esp_now_recv_info*, const unsigned char*, int)'} [-fpermissive]
The master I don't get an error, each time I press the button it responds in the serial monitor "sending 1". Then "I sent my data ->1. and counts up each time I press the button.
The slave get error,
Compilation error: 'buttonState' was not declared in this scope
I took your code that you posted in post # 6
I copy back from my ardiuno-ide into this code-section
  esp-now-multi.ino
#include <WiFi.h>
bool ledOn = false;
  buffer[msgLen] = 0;
  char macStr[18];
    ledOn = true;
    ledOn = false;
  char macStr[18];
  // Send message
  WiFi.disconnect();
    delay(3000);
    ESP.restart();
  // LED Output
    if (!buttonDown)
      buttonDown = true;
      ledOn = !ledOn;
      if (ledOn)
        broadcast("on");
        broadcast("off");
    buttonDown = false;
This code compiles.
If you want really help you should follow this tutorial to provide all details of your compiling process
Thank you!
That led me to a solution.
I looked back at the original video from Dronebotworkshop and realized he was running the 1.8 version so I downloaded and tried it again using the 1.8, and it worked, then I tried running it on a different PC using the 2.3.2, and it also worked so there is obviously something wrong with my installation on my main PC. So I will do a reinstall and hopefully all will be resolved.
