Hello,
As part of a project I want to connect 10 sensors based on an ESP32 to another ESP32 which serves as a control unit. I used the ESP-NOW protocol to connect the sensors to the control unit and it works well. However, I would like to be able to retrieve the mesures of all my sensors at once by connecting my control panel to my PC in wifi. I can connect to my control panel with my PC however the control panel no longer receives the values of the sensors.
So I would like to know if it is possible to use the ESP-NOW protocol at the same time as being connected to my wifi network to use my control panel as a server. If this is not possible, what solution would be viable for my project.
Sensor Code :
#include <esp_now.h>
#include <WiFi.h>
// REPLACE WITH YOUR RECEIVER MAC Address
uint8_t broadcastAddress[] = {The sensor mac adress};
// Structure example to send data
// Must match the receiver structure
typedef struct struct_message {
int numcapteur;
int etat;
} struct_message;
// Create a struct_message called myData
struct_message myData;
esp_now_peer_info_t peerInfo;
// callback when data is sent
void OnDataSent(const uint8_t *mac_addr, esp_now_send_status_t status) {
Serial.print("\r\nLast Packet Send Status:\t");
Serial.println(status == ESP_NOW_SEND_SUCCESS ? "Delivery Success" : "Delivery Fail");
// Init Serial Monitor
pinMode(33, INPUT);
// Set device as a Wi-Fi Station
WiFi.mode(WIFI_STA);
// Init ESP-NOW
if (esp_now_init() != ESP_OK) {
Serial.println("Error initializing ESP-NOW");
ESP.restart();
return;
// Once ESPNow is successfully Init, we will register for Send CB to
// get the status of Trasnmitted packet
esp_now_register_send_cb(OnDataSent);
// Register peer
memcpy(peerInfo.peer_addr, broadcastAddress, 6);
peerInfo.channel = 0;
peerInfo.encrypt = false;
// Add peer
if (esp_now_add_peer(&peerInfo) != ESP_OK){
Serial.println("Failed to add peer");
return;
// Set values to send
if (digitalRead(33)==HIGH){
myData.etat = 1 ;}
else{myData.etat = 0 ;}
myData.numcapteur = 1;
// Send message via ESP-NOW
esp_err_t result = esp_now_send(broadcastAddress, (uint8_t *) &myData, sizeof(myData));
if (result == ESP_OK) {
Serial.println("Sent with success");
else {
Serial.println("Error sending the data");
delay(2000);
Contrôle unit
#include <WiFi.h>
// Structure example to receive data
// Must match the sender structure
int numcapteur;
int etat;
} struct_message;
// callback function that will be executed when data is received
void OnDataRecv(const uint8_t * mac, const uint8_t *incomingData, int len) {
memcpy(&myData, incomingData, sizeof(myData));
Serial.print("Capteur: ");
Serial.println(myData.numcapteur);
Serial.print("Etat: ");
Serial.println(myData.etat);
//serveur wifi
const char* ssid = "........";
const char* password = "...........";
WiFiServer server(80);
// Initialize Serial Monitor
delay(10);
// We start by connecting to a WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected.");
Serial.println("IP address: ");
server.begin();
// Init ESP-NOW
return;
// Once ESPNow is successfully Init, we will register for recv CB to
// get recv packer info
esp_now_register_recv_cb(OnDataRecv);
void loop(){
WiFiClient client = server.available(); // listen for incoming clients
if (client) { // if you get a client,
Serial.println("New Client."); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// the content of the HTTP response follows the header:
client.print("<p>Capteur: ");
client.print(myData.numcapteur);
client.println("</p>");
client.print("<p>Etat: ");
client.print(myData.etat);
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
} else { // if you got a newline, then clear currentLine:
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
// close the connection:
client.stop();
Serial.println("Client Disconnected.");
