ESP13 WIFI SHEILD
Kind a hustle to find any useful info in regard to using the ESP8266 Web Sever Serial WiFi Shield Module Board With ESP-13, however allow me to let u know that using this sheild is as easy as ABC.
What is required of you to get going is
  1. background basics about the sheild found at
    Introduction | ESP8266-Based Serial WiFi Shield for Arduino----User Manual
    the most important thing here is the IP address, configurations and wiring. The contend u really need on this site is found on section 4-Quick Start. Default Wifi Address is 192.168.4.1, The SSID is "DoitWiFi_Config", baud rate 9600.
    About wiring under interface defination section 3, (Normal run:TX > RX0; RX>TX0; Switch (SW1) ON position ONLY say with arduino UNO)(when programing SW1 OFF, D0>ground then reset )
  2. U dont need any Librares, u dont use any AT commands with this board
  3. for TCP/IP Client terminal (similar to "Telnet") TCP/IP Server "terminal" UDP "terminal" m using Hercules Software Hercules SETUP utility | HW-group.com
  4. On the terminal setup the port no 9000 n the address 192.168.4.1 with the module as server yo machine as client....
  5. with your arduino ide, arduino board u r then good to go
    5 to test the sheild u can upload a simple code to transimt anything via arduino serial u will note that u will recieve on the terminal there after u can create whatever u want
