NKRT
August 19, 2019, 5:34pm
1
Hi!
I've tried to conect an ESP32 (https://www.aliexpress.com/item/32928267626.html )
with 3.5 TFT display (IL9486 driver) (Free Shipping! 3.5 Inch Tft Lcd Screen Module Ultra Hd 320x480 For Arduino Mega 2560 R3 Board - Lcd Modules - AliExpress
using TFT ESPI GitHub - Bodmer/TFT_eSPI: Arduino and PlatformIO IDE compatible TFT library optimised for the Raspberry Pi Pico (RP2040), STM32, ESP8266 and ESP32 that supports different driver chips
in two different ways: SPI and Parallel (once again using examples in TFT espi library)
but all I got is:
SPI - not working at all, blank display
Parallel - Display works but the only color is blue (in different shades) and sometimes Green appears.
Please help
Thanks in advance!
Your display has 8080-16 parallel interface.
It is designed as a Shield to plug into a MEGA2560 or DUE.
Bodmer's library only supports 8080-8 parallel
ESP32 has not got enough pins for 16-bit parallel.
David.
NKRT
August 19, 2019, 6:42pm
3
Thanks for your response!
As far as I understand - there is no way of connecting this display to the ESP32.
Can you please advise me what displays I can use with ESP32? (2.2inch+ with good resolution)
Thank you once again!
There a whole range of Chinese Red SPI displays e.g. 2.8 inch with Touch
I suggest 2.4 inch 240x320 or 3.5 inch 320x480
These are the displays that most people use with ESP8266 or ESP32
David.
NKRT
August 19, 2019, 7:55pm
5
240x320 is ILI9341
320x480 is ILI9488
Google for "Surenoo"
They have a wide range of displays.
David.
