Hi all,
at the beginning, I am trying to initialise the spi bus
I have the following error, can you please tell me what I am doing wrong :
about the structure :
sorry, unimplemented: non-trivial designated initializers not supported
#include<Arduino.h>
#include "driver/spi_master.h"// spi
#include "driver/gpio.h"// matrice
// Definition of macros
// setting SPI properties // HSPI_HOST
#definepin_num_mosi23 //// mis là pour le test avec analyse logique
#definepin_num_miso18 ////
#definepin_num_clk19
// Definition of global constants
//Initialize the SPI bus
////esp_err_t ret;
spi_bus_config_t buscfg={
.miso_io_num = pin_num_miso,
.mosi_io_num = pin_num_mosi,
.sclk_io_num = pin_num_clk,
.quadwp_io_num = -1,
.quadhd_io_num = -1,
.max_transfer_sz = 32,
spi_bus_initialize(HSPI_HOST, &buscfg, 0); // DMA_CHAN = 0
////ESP_ERROR_CHECK(ret);
// Main control loop ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
/* un petit main qui fait travailler l'esp32 : */
digitalWrite(LED_BUILTIN,HIGH);
PieterP
February 12, 2021, 11:58am
2
You're trying to compile C code using a C++ compiler. You need C++20 for designated initializers to work in C++.
Why not simply use the SPI library? arduino-esp32/libraries/SPI at master · espressif/arduino-esp32 · GitHub
Here's what I use for driving 74HC595s over SPI: Arduino Helpers: 1.SPI-Blink.ino
Please use [code] tags when posting code.
Pieter
ESP32 using the SPI API under the Arduino IDE.
#include "ESP32_SPI_API.h"
uint8_t txData[2] = { };
uint8_t rxData[25] = { };
uint8_t low;
int8_t high;
uint8_t GetLowBits()
return low;
int8_t GetHighBits()
return high;
int fInitializeSPI_Channel( int spiCLK, int spiMOSI, int spiMISO, spi_host_device_t SPI_Host, bool EnableDMA)
esp_err_t intError;
spi_bus_config_t bus_config = { };
bus_config.sclk_io_num = spiCLK; // CLK
bus_config.mosi_io_num = spiMOSI; // MOSI
bus_config.miso_io_num = spiMISO; // MISO
bus_config.quadwp_io_num = -1; // Not used
bus_config.quadhd_io_num = -1; // Not used
intError = spi_bus_initialize( HSPI_HOST, &bus_config, EnableDMA) ;
return intError;
int fInitializeSPI_Devices( spi_device_handle_t &h, int csPin)
esp_err_t intError;
spi_device_interface_config_t dev_config = { }; // initializes all field to 0
dev_config.address_bits = 0;
dev_config.command_bits = 0;
dev_config.dummy_bits = 0;
dev_config.mode = 3 ;
dev_config.duty_cycle_pos = 0;
dev_config.cs_ena_posttrans = 0;
dev_config.cs_ena_pretrans = 0;
dev_config.clock_speed_hz = 5000000;
dev_config.spics_io_num = csPin;
dev_config.flags = 0;
dev_config.queue_size = 1;
dev_config.pre_cb = NULL;
dev_config.post_cb = NULL;
spi_bus_add_device(HSPI_HOST, &dev_config, &h);
// return intError;
// return h;
} // void fInitializeSPI_Devices()
int fReadSPIdata16bits( spi_device_handle_t &h, int _address )
uint8_t address = _address;
esp_err_t intError = 0;
low=0; high=0;
spi_transaction_t trans_desc;
trans_desc = { };
trans_desc.addr = 0;
trans_desc.cmd = 0;
trans_desc.flags = 0;
trans_desc.length = (8 * 3); // total data bits
trans_desc.tx_buffer = txData;
trans_desc.rxlength = 8 * 2 ; // Number of bits NOT number of bytes
trans_desc.rx_buffer = rxData;
txData[0] = address | 0x80;
intError = spi_device_transmit( h, &trans_desc);
low = rxData[0]; high = rxData[1];
// if ( intError != 0 )
// Serial.print( " WHO I am LSM9DS1. Transmitting error = ");
// Serial.println ( esp_err_to_name(intError) );
return intError;
} // void fSendSPI( uint8_t count, uint8_t address, uint8_t DataToSend)
int fWriteSPIdata8bits( spi_device_handle_t &h, int _address, int _sendData )
uint8_t sendData = _sendData;
esp_err_t intError;
trans_desc = { };
trans_desc.cmd = 0;
trans_desc.length = (8 * 2); // total data bits
trans_desc.rxlength = 0 ; // Number of bits NOT number of bytes
trans_desc.rx_buffer = NULL;
txData[0] = address & 0x7F;
txData[1] = sendData;
return intError;
// // if ( intError != 0 )
// // Serial.print( " LSM9DS1_REGISTER_CTRL_REG6_XL. Transmitting error = ");
// // Serial.println ( esp_err_to_name(intError) );
} // void fWriteSPIdata8bits( spi_device_handle_t &h, uint8_t address, uint8_t sendData )
Using the SPI API is way more advantageous than using the Arduino IDE ESP32 core.
The OP should be able to see that under the Arduino IDE to initialize the SPI configuration structures it needs to be done a bit differently than in the examples.
Hi guys, thanks, I will try SPI
#include "ESP32_SPI_API.c"
please where to find ?
gfvalvo
February 13, 2021, 1:08pm
7
trimarco232:
Good question. It does not seem to be part of the standard ESP32 core installed by Arduino IDE.
Perhaps @Idahowalker will be so kind to explain.
EDIT:
As far as I could tell, it's @Idahowalker 's creation: ESP32 SPI API under the Ardino IDE - #2 by Idahowalker - Introductory Tutorials - Arduino Forum
You NEVER #include a .c or .cpp file.
I have picked up the files here
and put ESP32_SPI_API.c in my scr repository
now I have the following error, in the ESP32_SPI_API.h file :
include/ESP32_SPI_API.h:16:50: error: expected ';', ',' or ')' before '&' token
int fInitializeSPI_Devices( spi_device_handle_t &h, int csPin);
trimarco232:
I wrote them. Is that what the OP wants to do write to use the ESP32 SPI API directly?
ESP32_SPI_API.h
#include <driver/spi_master.h>
#include "sdkconfig.h"
#include "esp_system.h" //This inclusion configures the peripherals in the ESP system.
//#define MAGTYPE true
//#define XGTYPE false
uint8_t GetLowBits();
int8_t GetHighBits();
int fReadSPIdata16bits( spi_device_handle_t &h, int address );
int fWriteSPIdata8bits( spi_device_handle_t &h, int address, int sendData );
// spi_device_handle_t fInitializeSPI_Devices( int csPin);
int fInitializeSPI_Channel( int spiCLK, int spiMOSI, int spiMISO, spi_host_device_t SPI_Host, bool EnableDMA);
PieterP
February 13, 2021, 2:26pm
11
trimarco232:
because just for me, simple and easy do not have the same meaning, yet I will follow your advice, thanks !
Then please post your definitions of simple and easy.
In my opinion, the SPI library is orders of magnitude simpler and easier than ESP32_SPI_API.c:
#include <SPI.h>
const uint8_t latchpin = 5;
const SPISettings settings{8000000, MSBFIRST, SPI_MODE0};
SPI.begin();
pinMode(latchpin, OUTPUT);
digitalWrite(latchpin, HIGH);
void setShiftRegValue(uint8_t value) {
SPI.beginTransaction(settings);
digitalWrite(latchpin, LOW);
SPI.transfer(value);
SPI.endTransaction();
setShiftRegValue(0x55);
delay(150);
setShiftRegValue(0xAA);
delay(150);
trimarco232:
but its ugly because of the colors ...
Don't post it with colors, use CTRL+SHIFT+V to paste without markup.
ESP32_SPI_API.cpp
uint8_t low;
int8_t high;
return low;
return high;
esp_err_t intError;
return intError;
esp_err_t intError;
// return intError;
// return h;
low=0; high=0;
trans_desc = { };
trans_desc.cmd = 0;
return intError;
esp_err_t intError;
trans_desc = { };
trans_desc.cmd = 0;
return intError;
PieterP:
For the average user with a ESP32 the ESP32 SPI Arduino Core is wonderful.
Also, the Arduino IDE ESP32 SPI core is chained down with default settings.
PieterP:
imho :
simple :
SBI led_port, led_pin
easy :
#include strata of libraries
digital_write(led_pin, HIGH);
gfvalvo
February 13, 2021, 3:23pm
15
trimarco232:
imho :
simple :
easy :
So, what are you looking for with this thread?
I showed the OP how to use ESP32 API structures under the Arduino IDE by posting an example of usage.
gfvalvo:
to try to program hardware spi as close as possible to the api, in an easy way
(I have done it with the ledc api, it was ok)
because some times I want to do custom settings like a transmission baudrate that is not part of the proposed values
but may be spi api is still above my programming skills, so I'll have to go back to the spi library, and hope it will fit my needs
in this case I will try PieterP's example
but before let's give @Idahowalker a chance
gfvalvo
February 13, 2021, 4:04pm
18
trimarco232:
but before let's give Idahowalker a chance
OK, then go with @Idahowalker 's example code, modifying as necessary for your application.
Idahowalker:
I am under platformio IDE, may this cause problems with this ?
