ESP32 and APA 102
Hello everyone ,
My name Martien and i live in The Netherlands in Europe.
This is a video with an example that i like to use in my project.
And this is the code; (for a NodeMCU and a ESP8266 ledstrip)
#include "NeoPixelBus.h" // Library to control Pixel Stick
#include <WiFi.h> //"ESP8266WiFi.h" // WiFi Library
#define PixelCount 8 // Number of leds on stick
// I wil change it later on to 60 leds.
#define PixelPin 2
// NodeMCU pin 2 (RX) connected to Digital In of Pixel Stick
const char* ssid = "xxxxxxx"; // Name of WiFi Network
const char* password = "xxxxxxx"; // Password of WiFi Network
int firstrun = 0; // Check if system was just powered on
int buttonpressed = 5; // To hold which button was pressed on Web Page
// Initialize Library
//NeoPixelBus<NeoGrbFeature, Neo800KbpsMethod> strip(PixelCount, PixelPin);
// Define Arrays for colors
long switchled00[] =
0x0E5219, 0x52160E, 0x0E5219, 0x52160E,0x0E5219,0x52160E,0x0E5219,0x52160E
long switchled01[] =
0x19257B, 0x7B7A19, 0x19257B, 0x7B7A19, 0x19257B, 0x7B7A19, 0x19257B, 0x7B7A19
WiFiServer server(80); // Define Web Server Port
delay(10);
//strip.Begin(); // Init of Pixel Stick
//strip.Show(); // Clears any lit up Leds
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
// Wait until connected to WiFi
delay(250);
Serial.print(".");
// Confirmation that WiFi is connected
Serial.println("");
Serial.println("WiFi connected");
// Start the Web Server
server.begin();
Serial.println("Web Server Started");
// Display IP address
Serial.print("You can connect to the Server here: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
// Check if someone is connected
WiFiClient client = server.available();
if (!client) {
return;
// Read which button was pressed on the Web Page
String request = client.readStringUntil('\r');
// Light Up leds based on the button pressed
if (request.indexOf("/REDGREEN=1") != -1) {
for (int led = 0; led < 8; led++) {
//strip.SetPixelColor(led, HtmlColor(switchled00[led]));
//strip.Show();
buttonpressed = LOW;
firstrun=1;
if (request.indexOf("/BLUEYELLOW=1") != -1) {
//strip.SetPixelColor(led, HtmlColor(switchled01[led]));
//strip.Show();
buttonpressed = HIGH;
firstrun=1;
// Create Web Page
client.println("HTTP/1.1 200 OK"); // HTML Header
client.println("Content-Type: text/html");
client.println("");
client.println("");
client.println(""); // Start of HTML
client.println("");
client.println("body {background-color: #ACAEAD;}"); // Set Background Color
client.println("");
if (firstrun == 0) {
client.print("Please Click a Button ");
else {
client.print("Last Button Pressed was ");
if(buttonpressed == LOW) {
client.print("Red & Green");
if (buttonpressed == HIGH){
client.print("Blue & Yellow");
client.println("
client.println("<a href="/REDGREEN=1"">Red & Green ");
client.println("<a href="/BLUEYELLOW=1"">Blue & Yellow
client.println("");
delay(10);
I have a ESP 32 board and a APA 102 ledstrip with 4 wires instead of 3.
That's why i have to change the code for a APA 102.
I also want to directly access the 'webpage' of the ESP 32 without the external router in my house.
This can also be done with; WiFi.softAP (ssid, password). (I believe....)
To controle the leds i use a android device,trough WiFi.
In this example, the LEDs light up in Red / Green and Yellow / Blue.
That part of the code can remain the same (if possible) because i want to add more colors later on.
I also want the same design as the Arrays.
The layout of the webpage may also be the same.
(also both if possible)
I can also program a little bit myself, but not enough to do the whole thing.
At this moment i don’t have the time to learn it because i want to use it as soon as possible. (for a photography project this summer in 2018)
Your input is therefore more than welcome.
Thanks in advance !
Martien.
picturemaker:
You want it now, but can't be bothered to learn how to do it yourself? Good luck with that. Sounds like you need to hire a programmer and pay them money to do what you want.
There are multiple libraries for the APA102 that provide a similar interface to the neopixel/WS2812 libraries. Google will find them for you. It should be a simple matter to switch to one of these libraries. Of course, that presumes basic familiarity with Arduino and C - if you don't have that, you should plan to pay someone to write your code for you.
Remember that you can't power more than a few of those LEDs directly from Arduino power supply (at least at full brightness) - 8 is already pushing it. (this is true regardless of which kind of RGB led you're using - at 20mA per channel you hit the 500mA limit pretty fast; this limit is lower if using the barrel jack to power it, due to the regulator overheating).
