ESP32 BLE Compile Error - BLEServer.h No Such file file or directory
I have installed the ESP32_New_Blynk_Lib_BLE_WF using the IDE library manager. I select the ESP32 Dev Board (but the problem show up with other ESP32 boards as well), and then attempt to compile an example sketch that uses this library...I get the error BLEServer.h No such file or directory. I have search many forums, tried differing libraries, and cut the code down to the minimum as you can see below.
Here is the code cut down to just the header and "new sketch" The balance of the actual code seems to make no difference.
[color=#1d2228]#include <BlynkSimpleEsp32_BLE_WF.h>[/color]
[color=#1d2228]#include <BlynkSimpleEsp32_WF.h>[/color]
[color=#1d2228]//#include <BLEDevice.h>[/color]
[color=#1d2228]//#include <BLEServer.h>[/color]
[color=#1d2228]BlynkTimer timer;[/color]
[color=#1d2228][/color]
[color=#1d2228]void setup() {[/color]
[color=#1d2228]  // put your setup code here, to run once:[/color]
[color=#1d2228]}[/color]
[color=#1d2228]void loop() {[/color]
[color=#1d2228]  // put your main code here, to run repeatedly:[/color]
Commenting out or leaving BLEDevice.h and BLEServer uncommented does not change the error during compilation.
Any help is greatly appreciated.... I have spent that last few days attempting to track this down... tried other libraries, etc. no luck, always the same problem.
Thanks!
