I use ESP32 BLE to connect with bluetooth devices. The problem is that when I exit the app it doesn't disconnect and when I try to search for the Blueetooh device again, it doesn't appear.
My code is the following:
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
BLECharacteristic *pCharacteristic;
bool deviceConnected = false;
float txValue = 0;
const int readPin = 32; // Use GPIO number. See ESP32 board pinouts
const int LED = 2; // Could be different depending on the dev board. I used the DOIT ESP32 dev board.
//std::string rxValue; // Could also make this a global var to access it in loop()
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E" // UART service UUID
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
class MyServerCallbacks: public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
deviceConnected = true;
void onDisconnect(BLEServer* pServer) {
class MyCallbacks: public BLECharacteristicCallbacks {
void onWrite(BLECharacteristic *pCharacteristic) {
std::string rxValue = pCharacteristic->getValue();
if (rxValue.length() > 0) {
Serial.println("*********");
Serial.print("Received Value: ");
for (int i = 0; i < rxValue.length(); i++) {
Serial.print(rxValue[i]);
// Do stuff based on the command received from the app
if (rxValue.find("1") != -1) {
Serial.println("Turning ON!");
digitalWrite(LED, HIGH);
else if (rxValue.find("0") != -1) {
Serial.println("Turning OFF!");
digitalWrite(LED, LOW);
pinMode(LED, OUTPUT);
// Create the BLE Device
BLEDevice::init("ESP32"); // Give it a name
// Create the BLE Server
BLEServer *pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
// Create the BLE Service
BLEService *pService = pServer->createService(SERVICE_UUID);
// Create a BLE Characteristic
pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_TX,
BLECharacteristic::PROPERTY_NOTIFY
pCharacteristic->addDescriptor(new BLE2902());
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_RX,
BLECharacteristic::PROPERTY_WRITE
pCharacteristic->setCallbacks(new MyCallbacks());
// Start the service
pService->start();
// Start advertising
pServer->getAdvertising()->start();
Serial.println("Waiting a client connection to notify...");
if (deviceConnected) {
String dataExample1 = "DATA1";
String dataExample2 = "DATA2";
txValue = analogRead(readPin) / 3.456; // This could be an actual sensor reading!
//convert float txvalue to string
char txString[8]; // make sure this is big enuffz
dtostrf(txValue, 1, 2, txString);
String str = "";
str += txString;
str += ",";
str += dataExample1;
str += ",";
str += dataExample2;
pCharacteristic->setValue((char*)str.c_str());
pCharacteristic->notify(); // Send the value to the app!
Serial.print("*** Sent Value: ");
Serial.print(str);
Serial.println(" ***");
I'm new to this technology and I don't know if there is a way that if it detects that it's not connected to anything it will reboot or something, I don't know.
But, what I do want is for it to stay connected even if I have the screen closed (it works like this right now). My only problem is that when I close the app and reopen it, the device no longer appears.
I use the bluettoh terminal app with Android. Although it works the same with any other:
I'm not exactly certain of what you are asking, but try this modified version of your code to see if it reconnects as you want.
BLEServer declaration is now global similar to you did with BLECharacteristic. I have added a function checkToReconnect() which manages the reconnection in loop.
BLEServer *pServer = NULL;//added
bool oldDeviceConnected = false;//added
float txValue = 0;
void checkToReconnect() //added
// disconnected so advertise
if (!deviceConnected && oldDeviceConnected) {
delay(500); // give the bluetooth stack the chance to get things ready
pServer->startAdvertising(); // restart advertising
Serial.println("Disconnected: start advertising");
oldDeviceConnected = deviceConnected;
// connected so reset boolean control
if (deviceConnected && !oldDeviceConnected) {
// do stuff here on connecting
Serial.println("Reconnected");
pService->start();
checkToReconnect();
String str = "";
str += txString;
str += ",";
str += ",";
Serial.print(str);
Thanks for the kind words and I'm glad the code does what you want.
The important thing to realize, is that when a peripheral device is connected it stops advertising. A central device, like a phone, can only find and connect to an advertising peripheral.
If you want the central to reconnect without the peripheral going through a reset and repeat of setup(), then the peripheral needs to start advertising somewhere else than in setup().
Because advertising starts with this pServer function pServer->startAdvertising();
it means that you need global scope for the initial declaration for pServer BLEServer *pServer
I don't know if you can help me, but I will still ask the question:
I am trying to notify and read the data from my app in Flutter. Sending data to ESP32 with the buttons to turn it on and off is fine, my problem is with reading the data that the Arduino sends.
I will share the code snippets below:
Arduino:
checkToReconnect();
float dataExample1 = 0.4;
float dataExample2 = 0.5;
String str = "";
str += txString;
str += ",";
str += ",";
Serial.print(str);
Flutter:
Container(
child: StreamBuilder<List<int>>(
stream: stream,
builder: (BuildContext context,
AsyncSnapshot<List<int>> snapshot) {
if (snapshot.hasError)
return Text('Error: ${snapshot.error}');
if (snapshot.connectionState == ConnectionState.active) {
var data = snapshot.data as List<int>;
var currentValue = _dataParser(data);
print("REAL_DATA_1: $data");
// _temphumidata = currentValue.split(",");
//_charge = double.parse('${_temphumidata[0]}');
//_data_1 = double.parse('${_temphumidata[1]}');
It appears blank. You should have the information sent... but it doesn't happen like that. A friend tell me that it is a problem with my Arduino code.
The previous code posted in reply #2 worked with the Kai Morich Bluetooth Serial Terminal as the receiver. I replaced the if(device connected) section with your new snippet and all is received correctly.
There is no new line in the sending, so the format is a little confusing, but all the data is correct and separated by a terminal timestamp.
I'd be happy to work with you change the Arduino code to work with Flutter, instead of the Serial Bluetooth Terminal app, but your friend will have to tell us what to do.
