Hi there
I have a Waveshare ESP32-S3-Zero on which i run the following program below. Its not my final program but i just wantet to test the Library. It is named mod because i made a modification to i because of an error which occured due to conversions.
I can connect to the ESP with my I-Pad for example but if i watch the serial monitor it always connects and disconnects. Has someone have a similar Problem?
Thanks for helping!
/* TO DO
- Led auf board nutzen um zu zeigen ob connected ist
- Batteriestand auslesen und anpassen
#include <BleKeyboard_mod.h>
// Pins für Rechts-/Linkspedale
#define LEFT_PEDAL_PIN 12
#define RIGHT_PEDAL_PIN 14
BleKeyboard bleKeyboard("ESP32", "Me", 100);
Serial.println("BLE gestartet!");
bleKeyboard.begin();
// Pedal Pins mit Pull-Up Resistor initialisieren
pinMode(LEFT_PEDAL_PIN, INPUT_PULLUP);
pinMode(RIGHT_PEDAL_PIN, INPUT_PULLUP);
if(bleKeyboard.isConnected()) {
Serial.println("BLE Connected");
//prüfen ob Pedale gedrückt werden
if(!digitalRead(LEFT_PEDAL_PIN)){
Serial.println("Linkes Pedal gedrückt");
bleKeyboard.write(KEY_LEFT_ARROW);
if(!digitalRead(RIGHT_PEDAL_PIN)){
Serial.println("Rechtes Pedal gedrückt");
bleKeyboard.write(KEY_RIGHT_ARROW);
delay(50);
Serial.println("Waiting for connection ...");
