I am using an ESP32 to send data from Bluetooth. My problem is that the device does appear in the Android Bluetooth list, but it does not appear in iOS. Can you help me?
I am following the instructions on this page:
My code is:
#include <BluetoothSerial.h>
#define ledPIN 2
BluetoothSerial SerialBT;
byte BTData;
/* Check if Bluetooth configurations are enabled in the SDK */
#if !defined(CONFIG_BT_ENABLED) || !defined(CONFIG_BLUEDROID_ENABLED)
#error Bluetooth is not enabled! Please run `make menuconfig` to and enable it
#endif
pinMode(ledPIN, OUTPUT);
SerialBT.begin("ESP32");
Serial.println("Bluetooth Started! Ready to pair...");
if(SerialBT.available())
BTData = SerialBT.read();
Serial.write(BTData);
/* If received Character is 1, then turn ON the LED */
/* You can also compare the received data with decimal equivalent */
/* 48 for 0 and 49 for 1 */
/* if(BTData == 48) or if(BTData == 49) */
if(BTData == '1')
digitalWrite(ledPIN, HIGH);
/* If received Character is 0, then turn OFF the LED */
if(BTData == '0')
digitalWrite(ledPIN, LOW);
Video: https://www.youtube.com/watch?v=oCMOYS71NIU
Based on Neil Kolban example for IDF: https://github.com/nkolban/esp32-snippets/blob/master/cpp_utils/tests/BLE%20Tests/SampleNotify.cpp
Ported to Arduino ESP32 by Evandro Copercini
Create a BLE server that, once we receive a connection, will send periodic notifications.
The service advertises itself as: 6E400001-B5A3-F393-E0A9-E50E24DCCA9E
Has a characteristic of: 6E400002-B5A3-F393-E0A9-E50E24DCCA9E - used for receiving data with "WRITE"
Has a characteristic of: 6E400003-B5A3-F393-E0A9-E50E24DCCA9E - used to send data with "NOTIFY"
The design of creating the BLE server is:
1. Create a BLE Server
2. Create a BLE Service
3. Create a BLE Characteristic on the Service
4. Create a BLE Descriptor on the characteristic
5. Start the service.
6. Start advertising.
In this example rxValue is the data received (only accessible inside that function).
And txValue is the data to be sent, in this example just a byte incremented every second.
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
BLECharacteristic *pCharacteristic;
bool deviceConnected = false;
float txValue = 0;
const int readPin = 32; // Use GPIO number. See ESP32 board pinouts
const int LED = 2; // Could be different depending on the dev board. I used the DOIT ESP32 dev board.
//std::string rxValue; // Could also make this a global var to access it in loop()
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "6E400001-B5A3-F393-E0A9-E50E24DCCA9E" // UART service UUID
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
#define CHARACTERISTIC_UUID_TX "6E400003-B5A3-F393-E0A9-E50E24DCCA9E"
class MyServerCallbacks: public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
deviceConnected = true;
void onDisconnect(BLEServer* pServer) {
class MyCallbacks: public BLECharacteristicCallbacks {
void onWrite(BLECharacteristic *pCharacteristic) {
std::string rxValue = pCharacteristic->getValue();
if (rxValue.length() > 0) {
Serial.println("*********");
Serial.print("Received Value: ");
for (int i = 0; i < rxValue.length(); i++) {
Serial.print(rxValue[i]);
// Do stuff based on the command received from the app
if (rxValue.find("A") != -1) {
Serial.println("Turning ON!");
digitalWrite(LED, HIGH);
else if (rxValue.find("B") != -1) {
Serial.println("Turning OFF!");
digitalWrite(LED, LOW);
pinMode(LED, OUTPUT);
// Create the BLE Device
BLEDevice::init("ESP32 UART Test"); // Give it a name
// Create the BLE Server
BLEServer *pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
// Create the BLE Service
BLEService *pService = pServer->createService(SERVICE_UUID);
// Create a BLE Characteristic
pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_TX,
BLECharacteristic::PROPERTY_NOTIFY
pCharacteristic->addDescriptor(new BLE2902());
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_RX,
BLECharacteristic::PROPERTY_WRITE
pCharacteristic->setCallbacks(new MyCallbacks());
// Start the service
pService->start();
// Start advertising
pServer->getAdvertising()->start();
Serial.println("Waiting a client connection to notify...");
if (deviceConnected) {
// Fabricate some arbitrary junk for now...
txValue = analogRead(readPin) / 3.456; // This could be an actual sensor reading!
// Let's convert the value to a char array:
char txString[8]; // make sure this is big enuffz
dtostrf(txValue, 1, 2, txString); // float_val, min_width, digits_after_decimal, char_buffer
// pCharacteristic->setValue(&txValue, 1); // To send the integer value
// pCharacteristic->setValue("Hello!"); // Sending a test message
pCharacteristic->setValue(txString);
pCharacteristic->notify(); // Send the value to the app!
Serial.print("*** Sent Value: ");
Serial.print(txString);
Serial.println(" ***");
// You can add the rxValue checks down here instead
// if you set "rxValue" as a global var at the top!
// Note you will have to delete "std::string" declaration
// of "rxValue" in the callback function.
// if (rxValue.find("A") != -1) {
// Serial.println("Turning ON!");
// digitalWrite(LED, HIGH);
// else if (rxValue.find("B") != -1) {
// Serial.println("Turning OFF!");
// digitalWrite(LED, LOW);
That code sends and receives the data. Below you can see an attached image of my terminal from my smartphone, the 1st receives (read only) and the 2nd sends (read and write).
My question is:
I plan to program with React Native, Flutter or some similar framework. When I am programming to send and receive the data, will I be able to easily connect to those CHARACTERISTIC_UUID_RX and CHARACTERISTIC_UUID_TX. How do you imagine it would be? (so I have an idea, I am very new with this technology and any information will be of value).
