ESP32-C3 Mini C1166 not detected on Linux but another ESP32-C3 works
I have two ESP32-C3 Mini boards. One of them works perfectly on my Linux PC, but the other one is not detected at all.
Working board: ESP32-C3 Mini HW-4694
Not detected board: ESP32-C3 Mini C1166
When I plug the working one, it shows up normally as a serial device, but the C1166 board does not appear.
Does anyone know why this could happen or if these boards use different USB chips?
Thanks.
Linux usually does not care about the chips. I do not have the board so this is a SWAG: It appears you may have a bad board, does it do anything when powered up? Does the power led light if there is one?
have you tried to:
  • connect the “undetected board”
  • press and hold the “boot” button down
  • press and release the “reset” button
  • release the “boot” button
some boards need this to connect to USB
Yes, the red LED turns on when I plug it in, so it is getting power. However, it is not detected at all by my Linux PC (no serial device appears).
Yes, I already tried that.
I actually had the same issue before with another board, and using the boot + reset method fixed it. But in this case it still doesn’t get detected on my PC even after doing that.
Check if it shows up in /dev, sorted by time. Before plugging in
$ ls -lt /dev | head
total 0
crw-rw-rw-  1 root tty         5,     2 Mar  6 21:39 ptmx
drwxrwxrwt  2 root root              40 Mar  6 21:39 shm
drwxr-xr-x  2 root root            4920 Mar  6 21:38 char
crw-------  1 root root      239,     0 Mar  6 21:38 hidraw0
crw-------  1 root root      239,     1 Mar  6 21:38 hidraw1
and then right after
total 0
crw-rw-rw-  1 root tty         5,     2 Mar  6 21:40 ptmx
drwxrwxrwt  2 root root              40 Mar  6 21:40 shm
drwxr-xr-x  2 root root            4960 Mar  6 21:40 char
drwxr-xr-x  4 root root              80 Mar  6 21:40 serial
crw-rw----  1 root dialout   166,     0 Mar  6 21:40 ttyACM0
Notice ttyACM0, part of the dialout group
