ESP32-CAM wont connect
I am trying to get my ESP32-Cam up and going. This is my first time ever using one of these. I have installed everything I believe I need. When I upload the program on my Arduino Uno or through a FTDI programmer (i think that is what its called), I keep getting the same message. I dont know if it means that Its just not connecting to my WIFI or something else. Any help anyone can give would be greatly appreciated.
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6352
entry 0x400806b8
Using the FTDI connected to the ESP32cam and using 5V to power the ESP32CAM. With the IDE open plug in the ESP32cam. Did the PC make a connection sound? Does the ESO32CAM show up as a port in the IDE? Did you select the port, open monitor, short the programing pins, press the reset button, does the screen display a message waiting for upload?
Did you try to upload a sketch, remove the programing pin short, and press the reset button?
Yes, I have done all of that. After it uploads and I open my serial monitor, what I posted is that shows up on there. I have double checked to make sure my wiring is right.
Did you follow the order I posted? Looks like you are opening the serial monitor after the good stuff has displayed. You should have the serial monitor open for the entire process. You should see the words ready for upload after pressing the rest button and putting the jumper in place, do you see those words of ready to upload?
post your code. If you have uploaded the ESP32CAM example a web address should show up so you can view the cam's things. From the looks of your posted boot information, your example code is not working. Post your well formatted code in code tags.
What do you mean code tags? I'm kinda new to all of this stuff. Sorry!
ESP32cam code in code tags:
#include "sdkconfig.h" // used for log printing
#include "esp_system.h"
#include "freertos/FreeRTOS.h" //freeRTOS items to be used
#include "freertos/task.h"
#include "certs.h"
#include "esp_camera.h"
#include "soc/soc.h"           // Disable brownout problems
#include "soc/rtc_cntl_reg.h"  // Disable brownout problems
#include "driver/rtc_io.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include "ESP32_FTPClient.h"
#include <PubSubClient.h>
#include <ESP32Time.h>
WiFiClient      wifiClient; // do the WiFi instantiation thing
PubSubClient    MQTTclient( mqtt_server, mqtt_port, wifiClient ); //do the MQTT instantiation thing
ESP32_FTPClient ftp (ftp_server, ftp_user, ftp_pass, 5000, 2);
ESP32Time       rtc;
//#define evtDoMQTTParse  ( 1 << 0 ) // declare an event
//EventGroupHandle_t eg; // variable for the event group handle
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK;
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 300;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
int  mqttOK = 0;
bool TimeSet = false;
bool FlashMode = false;
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
      log_i("Connected to WiFi access point");
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', payloadSize );
  x_message.topic = ""; //clear string buffer
  x_message.topic = topic;
  int i = 0;
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  pinMode( GPIO_NUM_4, OUTPUT);
  digitalWrite( GPIO_NUM_4, LOW);
  WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
  //eg = xEventGroupCreate(); // get an event group handle
  x_message.topic.reserve( payloadSize );
  xQ_Message  = xQueueCreate( 1, sizeof(stu_message) );
  sema_mqttOK    =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 7000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 9000, NULL, 4, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 2, NULL, 1 );
  if ( configInitCamera() )
    log_i("        start camera task" );
    xTaskCreatePinnedToCore( capturePhoto_sendFTP, "capturePhoto_sendFTP", 60000, NULL, 6, NULL, 1 );
    log_i( "       camera failed to initilize, rebooting in 5." );
    vTaskDelay( 2000 );
    ESP.restart();
} // void setup()
void capturePhoto_sendFTP( void *pvParameters )
  TickType_t xLastWakeTime    = xTaskGetTickCount();
  const TickType_t xFrequency = 1000 * 15; //delay for mS
  //!!!!!Must wait for MQTT connection and proper setup of the sema_MQTT_KeepAlive!!!!
  while ( !MQTTclient.connected() )
    vTaskDelay( 500 );
  for (;;)
    log_i( "tick");
    xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      camera_fb_t * fb = NULL; // pointer
      if( FlashMode )
        digitalWrite( GPIO_NUM_4, HIGH );
        vTaskDelay( 20 );
      fb = esp_camera_fb_get();
      digitalWrite( GPIO_NUM_4, LOW );
      if (!fb)
        log_i( "Camera capture failed" );
        esp_camera_fb_return(fb);
      } else
        ftp.OpenConnection(); // try open FTP
        if ( ftp.isConnected() )
          //try send file ftp
          ftp.ChangeWorkDir( ftp_path );
          ftp.DeleteFile( ftp_file_name );
          ftp.InitFile( ftp_file_type ); //"Type I"
          ftp.NewFile( ftp_file_name );
          ftp.WriteData( (unsigned char *)fb->buf, fb->len );
          ftp.CloseFile();
          ftp.CloseConnection();
        esp_camera_fb_return(fb); //return the frame buffer back to the driver for reuse
    xSemaphoreGive( sema_MQTT_KeepAlive );
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
  vTaskDelete( NULL );
} //void capturePhoto_sendFTP( void *pvParameters )
void configureCameraSettings_grpE( int _lenC, int _Hmirror, int _Vflip, int _dcw, int _colorbar )
  sensor_t * s = esp_camera_sensor_get();
  s->set_lenc(s, _lenC);         // 0 = disable , 1 = enable
  s->set_hmirror(s, _Hmirror);   // 0 = disable , 1 = enable
  s->set_vflip(s, _Vflip);       // 0 = disable , 1 = enable
  s->set_dcw(s, _dcw);           // 0 = disable , 1 = enable
  ////s->set_colorbar(s, _colorbar); // 0 = disable , 1 = enable
void configureCameraSettings_grpD( int _gc, int _agc, int _celing, int _bpc, int _wpc, int _gma )
  s->set_gain_ctrl(s, _gc); // 0 = disable , 1 = enable
  s->set_agc_gain(s, _agc); // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)_celing);  // 0 to 6
  s->set_bpc(s, _bpc);      // 0 = disable , 1 = enable
  s->set_wpc(s, _wpc);      // 0 = disable , 1 = enable
  s->set_raw_gma(s, _gma);  // 0 = disable , 1 = enable
void configureCameraSettings_grpC( int _exctl, int _aec2, int _ae, int _aec )
  s->set_exposure_ctrl(s, _exctl); // 0 = disable , 1 = enable
  s->set_aec2(s, _aec2);           // 0 = disable , 1 = enable
  s->set_ae_level(s, _ae);         // -2 to 2
  ////s->set_aec_value(s, _aec);       // 0 to 1200 CAUSES BLACK IMAGE????
void configureCameraSettings_grpB( int se, int wb, int awb, int wbmode )
  s->set_special_effect(s, se); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, wb);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, awb);      // 0 = disable , 1 = enable
  s->set_wb_mode(s, wbmode);    // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
void configureCameraSettings_grpA(int brightness, int contrast, int saturation )
  if ( ((brightness > -3) && (brightness < 3)) && ((contrast > -3) && (contrast < 3)) && ((saturation > -3) && (saturation < 3)) )
    s->set_brightness( s, brightness ); // -2 to 2
    s->set_contrast( s, contrast );    // -2 to 2
    s->set_saturation( s, saturation );  // -2 to 2
} //void configureCameraSettings()
  sensor_t * s = esp_camera_sensor_get(); //see certs.h for more info
  s->set_brightness(s, -1);     // -2 to 2 **************************
  s->set_contrast(s, 0);       // -2 to 2
  s->set_saturation(s, 0);     // -2 to 2
  s->set_special_effect(s, 0); // 0 to 6 (0 - No Effect, 1 - Negative, 2 - Grayscale, 3 - Red Tint, 4 - Green Tint, 5 - Blue Tint, 6 - Sepia)
  s->set_whitebal(s, 1);       // 0 = disable , 1 = enable
  s->set_awb_gain(s, 1);       // 0 = disable , 1 = enable
  s->set_wb_mode(s, 0);        // 0 to 4 - if awb_gain enabled (0 - Auto, 1 - Sunny, 2 - Cloudy, 3 - Office, 4 - Home)
  s->set_exposure_ctrl(s, 1);  // 0 = disable , 1 = enable
  s->set_aec2(s, 0);           // 0 = disable , 1 = enable
  s->set_ae_level(s, 0);       // -2 to 2
  s->set_aec_value(s, 300);    // 0 to 1200
  s->set_gain_ctrl(s, 1);      // 0 = disable , 1 = enable
  s->set_agc_gain(s, 0);       // 0 to 30
  s->set_gainceiling(s, (gainceiling_t)0);  // 0 to 6
  s->set_bpc(s, 0);            // 0 = disable , 1 = enable
  s->set_wpc(s, 1);            // 0 = disable , 1 = enable
  s->set_raw_gma(s, 1);        // 0 = disable , 1 = enable
  s->set_lenc(s, 1);           // 0 = disable , 1 = enable
  s->set_hmirror(s, 0);        // 0 = disable , 1 = enable
  s->set_vflip(s, 0);          // 0 = disable , 1 = enable
  s->set_dcw(s, 1);            // 0 = disable , 1 = enable
  s->set_colorbar(s, 0);       // 0 = disable , 1 = enable
bool configInitCamera()
  camera_config_t config = {}; // Stores the camera configuration parameters
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer   = LEDC_TIMER_0;
  config.pin_d0       = GPIO_NUM_5; //Y2
  config.pin_d1       = GPIO_NUM_18; //Y3
  config.pin_d2       = GPIO_NUM_19; //Y4
  config.pin_d3       = GPIO_NUM_21; //Y5
  config.pin_d4       = GPIO_NUM_36; //Y6
  config.pin_d5       = GPIO_NUM_39; //Y7
  config.pin_d6       = GPIO_NUM_34; //Y8
  config.pin_d7       = GPIO_NUM_35; // Y9
  config.pin_xclk     = GPIO_NUM_0; //XCLK
  config.pin_pclk     = GPIO_NUM_22; //PCLK
  config.pin_vsync    = GPIO_NUM_25; //VSSYNC
  config.pin_href     = GPIO_NUM_23; // HREF
  config.pin_sscb_sda = GPIO_NUM_26; //SIOD
  config.pin_sscb_scl = GPIO_NUM_27; //SIOC
  config.pin_pwdn     = GPIO_NUM_32; //PWDN
  config.pin_reset    = -1; //RESET
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG; //assuming default is has PSRAM
  config.frame_size = FRAMESIZE_UXGA; // FRAMESIZE_ + QVGA|CIF|VGA|SVGA|XGA|SXGA|UXGA
  config.jpeg_quality = 10; //0-63 lower number means higher quality
  config.fb_count = 2;
  // Initialize the Camera
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    log_i("Camera init failed with error %d", err );
    return false;
    configureCameraSettings();
    return true;
} //void configInitCamera()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 2500 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; //delay for ms
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // !!!!!whiles MQTTlient.loop() is running no other mqtt operations should be in process!!!!!
      MQTTclient.loop();
    else {
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
  vTaskDelete ( NULL );
void connectToMQTT()
  byte mac[5]; // create client ID from mac address
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
  MQTTclient.subscribe( topicGrpA );
  MQTTclient.subscribe( topicGrpB );
  MQTTclient.subscribe( topicGrpC );
  MQTTclient.subscribe( topicGrpD );
  MQTTclient.subscribe( topicGrpE );
  MQTTclient.subscribe( topicFlash );
} //void connectToMQTT()
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 3;
  const TickType_t xFrequency = 60000; //delay for mS
  for (;;)
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      log_i( "mqtt watchdog rest" );
      vTaskDelay( 200 );
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
} //void fmqttWatchDog( void * paramater )
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      mqttOK = 0;
      if ( !TimeSet)
        if ( String(px_message.topic) == topicOK )
          String temp = "";
          temp        = px_message.payload[0];
          temp        += px_message.payload[1];
          temp        += px_message.payload[2];
          temp        += px_message.payload[3];
          int year    =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[5];
          temp        += px_message.payload[6];
          int month   =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[8];
          temp        += px_message.payload[9];
          int day     =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[11];
          temp        += px_message.payload[12];
          int hour    =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[14];
          temp        += px_message.payload[15];
          int min     =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "%s   rtc  %s ", px_message.payload, rtc.getTime() );
          TimeSet     = true;
      if ( String(px_message.topic) == topicGrpA )
        //finding first letter
        String sTmp = String( px_message.payload );
        int commaIndex = sTmp.indexOf(',');
        if ( sTmp.substring(0, commaIndex) == "a" );
          int brt =  (sTmp.substring(0, commaIndex)).toInt();
          sTmp.remove( 0, (commaIndex + 1) );
          int ctrast = (sTmp.substring(0, commaIndex)).toInt();
          sTmp.remove( 0, (commaIndex + 1) ); // chop off begining of message
          int sat = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpA( brt, ctrast, sat );
      if ( String(px_message.topic) == topicGrpB )
        if ( sTmp.substring(0, commaIndex) == "b" );
          int se =  (sTmp.substring(0, commaIndex)).toInt();
          int wbb = (sTmp.substring(0, commaIndex)).toInt();
          int wba = (sTmp.substring(0, commaIndex)).toInt();
          int wbm = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpB( se, wbb, wba, wbm );
      if ( String(px_message.topic) == topicGrpC )
        if ( sTmp.substring(0, commaIndex) == "c" );
          int ex =  (sTmp.substring(0, commaIndex)).toInt();
          int aec2 = (sTmp.substring(0, commaIndex)).toInt();
          int ae = (sTmp.substring(0, commaIndex)).toInt();
          int aec = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpC( ex, aec2, ae, aec );
      if ( String(px_message.topic) == topicGrpD )
        if ( sTmp.substring(0, commaIndex) == "d" );
          int gc =  (sTmp.substring(0, commaIndex)).toInt();
          int agc = (sTmp.substring(0, commaIndex)).toInt();
          int celing = (sTmp.substring(0, commaIndex)).toInt();
          int bpc = (sTmp.substring(0, commaIndex)).toInt();
          int wpc = (sTmp.substring(0, commaIndex)).toInt();
          int gma = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpD( gc, agc, celing, bpc, wpc, gma );
      if ( String(px_message.topic) == topicGrpE )
        if ( sTmp.substring(0, commaIndex) == "e" );
          int lenC =  (sTmp.substring(0, commaIndex)).toInt();
          int Hmirror = (sTmp.substring(0, commaIndex)).toInt();
          int Vflip = (sTmp.substring(0, commaIndex)).toInt();
          int dcw = (sTmp.substring(0, commaIndex)).toInt();
          int colorbar = (sTmp.substring(0, commaIndex)).toInt();
          configureCameraSettings_grpE( lenC, Hmirror, Vflip, dcw, colorbar );
      if( String(px_message.topic) == topicFlash )
        FlashMode = !FlashMode;
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
//Disable Example for now
#if 0
#include <WiFi.h>
// WARNING!!! PSRAM IC required for UXGA resolution and high JPEG quality
// Ensure ESP32 Wrover Module or other board with PSRAM is selected
// Partial images will be transmitted if image exceeds buffer size
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_V2_PSRAM // M5Camera version B Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_ESP32CAM // No PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
#include "camera_pins.h"
const char* ssid = "********";
const char* password = "**********";
void startCameraServer();
Serial.setDebugOutput(true);
camera_config_t config;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
// if PSRAM IC present, init with UXGA resolution and higher JPEG quality
// for larger pre-allocated frame buffer.
if(psramFound()){
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
pinMode(13, INPUT_PULLUP);
pinMode(14, INPUT_PULLUP);
#endif
// camera init
Serial.printf("Camera init failed with error 0x%x", err);
return;
// initial sensors are flipped vertically and colors are a bit saturated
if (s->id.PID == OV3660_PID) {
s->set_vflip(s, 1); // flip it back
s->set_brightness(s, 1); // up the brightness just a bit
s->set_saturation(s, -2); // lower the saturation
// drop down frame size for higher initial frame rate
s->set_framesize(s, FRAMESIZE_QVGA);
#if defined(CAMERA_MODEL_M5STACK_WIDE) || defined(CAMERA_MODEL_M5STACK_ESP32CAM)
s->set_vflip(s, 1);
s->set_hmirror(s, 1);
#endif
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.print("Camera Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
delay(10000);
#else
void setup(){}
void loop(){}
#endif
Please use code tags when posting code. Instructions on how to use this site are on this site, use search.
That looks pretty butchered.
Try this:
#include <WiFi.h>
const char* ssid     = "enter your stuff"; error
const char* password = "yup your stuff goes here"; error
  if(psramFound()){
#endif
  // camera init
    return;
  s->set_vflip(s, 1);
#endif
    Serial.print(".");
  Serial.println("");
  delay(10000);
#if 0
#include <WiFi.h>
const char* ssid = "NETGEAR09";
const char* password = "excitedrabbit534";
  if (psramFound()) {
#endif
  // camera init
    return;
  s->set_vflip(s, 1);
#endif
    Serial.print(".");
  Serial.println("");
  delay(10000);
#else
void setup() {}
void loop() {}
#endif
Sorry, I kept trying to send it the way you asked for it, but it kept saying that "akismet has temporarily hidden your post."
Maybe I just need a different camera. I have literally tried everything that i could. I have tried watching various videos and tutorials. That message that I got was on my Serial monitor, even after I would push the reset button and take out the GND and GI0 pins. So I have no clue what else to do. I do appreciate you trying to help me though.
Did you try post number 9?
Yes I did. When I tried it it kept saying " could not connect to AI thinker ESP-32" I also tried to cause the driver model board to see if that one would work and it did not.
Sorry, it says "error compiling for AI Thinker ESP32-Cam."
This other video I just watched, i did exactly as he did, and the code I get on my serial monitor is almost exactly like his, mine just is not connecting to wifi for some reason. I am trying to connect it to my 2.4MHz signal and not the 5. So I am lost on what else to do.
To a newbee such a short answer with no explanation does not help at all
this is the reason why I programmed autohotkey. Whenever I type "postcode" autohotkey removes this word "postcode" an replaces it with:
You should post code by using code-tags
There is an automatic function for doing this in the Arduino-IDE
just three steps
  1. press Ctrl-T for autoformatting your code
  2. do a rightclick with the mouse and choose "copy for forum"
  3. paste clipboard into write-window of a posting
best regards Stefan
This is too less information to analyse anything.
when you compiled the code the Arduino-IDE wrote a lot of messaging while compiling.
If the compiler finishes with any kind of error there is a button copy error messages on the bottom right.
Click on that
"copy-error-messages-button"
to copy the all the text into your PC's clipboard
then change to the forum
Click on that button
To create a code-section. Make sure to not hit any key and not clicking anywhere
directly after clicking the code-tags-button
then press Ctrl-V to insert the clipboard-content
This will put all the compilermessages into a code-section to keep it small
best regards Stefan
Have you tried to use ESP32 WROVER Module. Tinkercam did not work for me.
And sharing these things would be a good idea.
And. Because this happens a lot, there should be a link that posts this information when ever this needs be explained. One of those buttons could be a how to post code link that paste all the info into the reply.
I was like, ok I mention it and someone will come along and make the proper postings with all the images and stuff but if there was a button I'd do it to.
Where did you get your code?
Tom... :smiley: :+1: :coffee: :australia:
