Hi, I'm having a problem like this: ESP32 + built-in CanBus -> doesn't work - Using Arduino / General Electronics - Arduino Forum.
I'm using :
- 2 ESP32 (board NodeMCU-32S)
- 2 TJA1050 module
Each module has a 120ohms resistor.
I've tried powering the module with 5V and 3.3V, but I've had no results.
ESP32 stops appearing on the terminal.
I'm testing with 125kbps and 500kbps.
I'm testing with a short cable (6 cm) and a long cable (approx. 1 m) to connect the CAN modules.
Code to ESP1:
// Copyright (c) Sandeep Mistry. All rights reserved.
// Licensed under the MIT license. See LICENSE file in the project root for full license information.
#include <CAN.h>
while (!Serial);
Serial.println("CAN Receiver");
// start the CAN bus at 500 kbps
if (!CAN.begin(125000)) { //500E3
Serial.println("Starting CAN failed!");
while (1);
// try to parse packet
int packetSize = CAN.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received ");
if (CAN.packetExtended()) {
Serial.print("extended ");
if (CAN.packetRtr()) {
// Remote transmission request, packet contains no data
Serial.print("RTR ");
Serial.print("packet with id 0x");
Serial.print(CAN.packetId(), HEX);
Serial.print(" and requested length ");
Serial.println(CAN.packetDlc());
Serial.print(" and length ");
Serial.println(packetSize);
// only print packet data for non-RTR packets
while (CAN.available()) {
Serial.print((char)CAN.read());
Code to ESP2:
#include <CAN.h>
while (!Serial);
Serial.println("CAN Sender");
if (!CAN.begin(125000)) {//500E3
while (1);
// send packet: id is 11 bits, packet can contain up to 8 bytes of data
Serial.print("Sending packet ... ");
CAN.beginPacket(0x12);
CAN.write('h');
CAN.write('e');
CAN.write('l');
CAN.write('l');
CAN.write('o');
CAN.endPacket();
Serial.println("done");
// send extended packet: id is 29 bits, packet can contain up to 8 bytes of data
Serial.print("Sending extended packet ... ");
CAN.beginExtendedPacket(0xabcdef);
CAN.write('w');
CAN.write('o');
CAN.write('r');
CAN.write('l');
CAN.write('d');
CAN.endPacket();
