ESP32 Compile - ESPTool looking in wrong location?
--> Running on Linux Mint 21.3
-- > virtual environment for python = arduino_env
--> pip says both esp_tool and pyserical are installed
--> IDE preference has
sketchbook location: /home/micromint/arduino_env
additional board manager URLs: https://dl.espressif.com/dl/package_esp32_index.json,https://raw.githubusercontent.com/espressif/arduino-esp32/gh-pages/package_esp32_index.json
--> cannot compile example sketch -- see error output log below:
FQBN: esp32:esp32:esp32cam
Using board 'esp32cam' from platform in folder: /home/micromint/.arduino15/packages/esp32/hardware/esp32/3.0.1
Using core 'esp32' from platform in folder: /home/micromint/.arduino15/packages/esp32/hardware/esp32/3.0.1
/usr/bin/env bash -c "[ ! -f \"/home/micromint/Arduino/sketch_jun22a\"/partitions.csv ] || cp -f \"/home/micromint/Arduino/sketch_jun22a\"/partitions.csv \"/tmp/arduino/sketches/AF64743174CC360DBD402068C18BE957\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/tmp/arduino/sketches/AF64743174CC360DBD402068C18BE957\"/partitions.csv ] || [ ! -f \"/home/micromint/.arduino15/packages/esp32/hardware/esp32/3.0.1/variants/esp32\"/partitions.csv ] || cp \"/home/micromint/.arduino15/packages/esp32/hardware/esp32/3.0.1/variants/esp32\"/partitions.csv \"/tmp/arduino/sketches/AF64743174CC360DBD402068C18BE957\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/tmp/arduino/sketches/AF64743174CC360DBD402068C18BE957\"/partitions.csv ] || cp \"/home/micromint/.arduino15/packages/esp32/hardware/esp32/3.0.1\"/tools/partitions/huge_app.csv \"/tmp/arduino/sketches/AF64743174CC360DBD402068C18BE957\"/partitions.csv"
/usr/bin/env bash -c "[ -f \"/home/micromint/Arduino/sketch_jun22a\"/bootloader.bin ] && cp -f \"/home/micromint/Arduino/sketch_jun22a\"/bootloader.bin \"/tmp/arduino/sketches/AF64743174CC360DBD402068C18BE957\"/sketch_jun22a.ino.bootloader.bin || ( [ -f \"/home/micromint/.arduino15/packages/esp32/hardware/esp32/3.0.1/variants/esp32\"/bootloader.bin ] && cp \"/home/micromint/.arduino15/packages/esp32/hardware/esp32/3.0.1/variants/esp32\"/bootloader.bin \"/tmp/arduino/sketches/AF64743174CC360DBD402068C18BE957\"/sketch_jun22a.ino.bootloader.bin || python3 \"/home/micromint/.arduino15/packages/esp32/tools/esptool_py/4.6\"/esptool.py --chip esp32 elf2image --flash_mode dio --flash_freq 80m --flash_size 4MB -o \"/tmp/arduino/sketches/AF64743174CC360DBD402068C18BE957\"/sketch_jun22a.ino.bootloader.bin \"/home/micromint/.arduino15/packages/esp32/tools/esp32-arduino-libs/idf-release_v5.1-442a798083/esp32\"/bin/bootloader_qio_80m.elf )"
Traceback (most recent call last):
  File "/home/micromint/.arduino15/packages/esp32/tools/esptool_py/4.6/esptool.py", line 34, in <module>
    import esptool
Pyserial is not installed for /usr/bin/python3. Check the README for installation instructions.
  File "/home/micromint/.arduino15/packages/esp32/tools/esptool_py/4.6/esptool/__init__.py", line 41, in <module>
    from esptool.cmds import (
  File "/home/micromint/.arduino15/packages/esp32/tools/esptool_py/4.6/esptool/cmds.py", line 14, in <module>
    from .bin_image import ELFFile, ImageSegment, LoadFirmwareImage
  File "/home/micromint/.arduino15/packages/esp32/tools/esptool_py/4.6/esptool/bin_image.py", line 14, in <module>
    from .loader import ESPLoader
  File "/home/micromint/.arduino15/packages/esp32/tools/esptool_py/4.6/esptool/loader.py", line 30, in <module>
    import serial
ModuleNotFoundError: No module named 'serial'
exit status 1
Compilation error: exit status 1
--> Thank you for any assistance!
--> BTW had to do much searching to discover that brltty had to be removed to clear the TTY port for the board to even be accessible....wow! pita ....maybe worth a section in a FAQ to help Linux/Unix users to get up and running more effortlessly? The IDE did not have an install script either - a good place for that to be removed by the installer?? IMHO
pip or pip3?
Need install with pip3 'cause is for python 3.x
Thank you for the help!
..tried pip3... still same error
pip3 install esptool
Requirement already satisfied: esptool in ./arduino_env/lib/python3.10/site-packages (4.7.0)
Requirement already satisfied: PyYAML>=5.1 in ./arduino_env/lib/python3.10/site-packages (from esptool) (6.0.1)
Requirement already satisfied: bitstring>=3.1.6 in ./arduino_env/lib/python3.10/site-packages (from esptool) (4.2.3)
Requirement already satisfied: cryptography>=2.1.4 in ./arduino_env/lib/python3.10/site-packages (from esptool) (42.0.8)
Requirement already satisfied: ecdsa>=0.16.0 in ./arduino_env/lib/python3.10/site-packages (from esptool) (0.19.0)
Requirement already satisfied: intelhex in ./arduino_env/lib/python3.10/site-packages (from esptool) (2.3.0)
Requirement already satisfied: pyserial>=3.0 in ./arduino_env/lib/python3.10/site-packages (from esptool) (3.5)
Requirement already satisfied: reedsolo<1.8,>=1.5.3 in ./arduino_env/lib/python3.10/site-packages (from esptool) (1.7.0)
Requirement already satisfied: bitarray<3.0.0,>=2.9.0 in ./arduino_env/lib/python3.10/site-packages (from bitstring>=3.1.6->esptool) (2.9.2)
Requirement already satisfied: cffi>=1.12 in ./arduino_env/lib/python3.10/site-packages (from cryptography>=2.1.4->esptool) (1.16.0)
Requirement already satisfied: six>=1.9.0 in ./arduino_env/lib/python3.10/site-packages (from ecdsa>=0.16.0->esptool) (1.16.0)
Requirement already satisfied: pycparser in ./arduino_env/lib/python3.10/site-packages (from cffi>=1.12->cryptography>=2.1.4->esptool) (2.22)
(arduino_env) micromint@master-micro:~$ pip3 install pyserial
Requirement already satisfied: pyserial in ./arduino_env/lib/python3.10/site-packages (3.5)
    import esptool
    import serial
exit status 1
