ESP32 e sensore temperatura AHT10
Buonasera a tutti.
Come da titolo ho collegato la scheda ESP32-WROOM-32D al sensore tempeatura AHT10 con connessione I2C.
Nell'IDE di Arduino ho usato l'opzione "ESP32 Dev Module" come tipo di scheda e caricando lo sketch funziona ma poi l'output nel monitor seriale non compare, o meglio esce un errore "AHT1x not connected or fail to load calibration coefficient".
Lo sketch è quanto segue:
   This is an Arduino example for Aosong ASAIR AHT10/AHT15/AHT20/AHT21/AHT25/AM2301B/AM2311B
   Digital Humidity & Temperature Sensor
   written by : enjoyneering
   sourse code: https://github.com/enjoyneering/
   Aosong ASAIR AHT1x/AHT2x features:
   - AHT1x +1.8v..+3.6v, AHT2x +2.2v..+5.5v
   - AHT1x 0.25uA..320uA, AHT2x 0.25uA..980uA
   - temperature range -40C..+85C
   - humidity range 0%..100%
   - typical accuracy T +-0.3C, RH +-2%
   - typical resolution T 0.01C, RH 0.024%
   - normal operating range T -20C..+60C, RH 10%..80%
   - maximum operating rage T -40C..+80C, RH 0%..100%
   - response time 8..30sec*
   - I2C bus speed 100KHz..400KHz, 10KHz recommended minimum
     *measurement with high frequency leads to heating of the
      sensor, interval must be > 1 second to keep self-heating below 0.1C
   This device uses I2C bus to communicate, specials pins are required to interface
   Board                                     SDA              SCL              Level
   Uno, Mini, Pro, ATmega168, ATmega328..... A4               A5               5v
   Mega2560................................. 20               21               5v
   Due, SAM3X8E............................. 20               21               3.3v
   MKR Zero, XIAO SAMD21, SAMD21xx.......... PA08             PA09             3.3v
   Leonardo, Micro, ATmega32U4.............. 2                3                5v
   Digistump, Trinket, Gemma, ATtiny85...... PB0/D0           PB2/D2           3.3v/5v
   Blue Pill*, STM32F103xxxx boards*........ PB7/PB9          PB6/PB8          3.3v/5v
   ESP8266 ESP-01**......................... GPIO0            GPIO2            3.3v/5v
   NodeMCU 1.0**, WeMos D1 Mini**........... GPIO4/D2         GPIO5/D1         3.3v/5v
   ESP32***................................. GPIO21/D21       GPIO22/D22       3.3v
                                             GPIO16/D16       GPIO17/D17       3.3v
                                            *hardware I2C Wire mapped to Wire1 in stm32duino
                                             see https://github.com/stm32duino/wiki/wiki/API#I2C
                                           **most boards has 10K..12K pullup-up resistor
                                             on GPIO0/D3, GPIO2/D4/LED & pullup-down on
                                             GPIO15/D8 for flash & boot
                                          ***hardware I2C Wire mapped to TwoWire(0) aka GPIO21/GPIO22 in Arduino ESP32
   Supported frameworks:
   Arduino Core - https://github.com/arduino/Arduino/tree/master/hardware
   ATtiny  Core - https://github.com/SpenceKonde/ATTinyCore
   ESP8266 Core - https://github.com/esp8266/Arduino
   ESP32   Core - https://github.com/espressif/arduino-esp32
   STM32   Core - https://github.com/stm32duino/Arduino_Core_STM32
   SAMD    Core - https://github.com/arduino/ArduinoCore-samd
   GNU GPL license, all text above must be included in any redistribution,
   see link for details - https://www.gnu.org/licenses/licenses.html
#include <Wire.h>
#include <AHTxx.h>
#if defined(ESP8266)
#include <ESP8266WiFi.h>
#endif
float ahtValue;                               //to store T/RH result
AHTxx aht10(AHTXX_ADDRESS_X38, AHT1x_SENSOR); //sensor address, sensor type
    setup()
    Main setup
  WiFi.persistent(false);  //disable saving wifi config into SDK flash area
  WiFi.forceSleepBegin();  //disable AP & station by calling "WiFi.mode(WIFI_OFF)" & put modem to sleep
  #endif
  while (aht10.begin() != true) //for ESP-01 use aht10.begin(0, 2);
    Serial.println(F("AHT1x not connected or fail to load calibration coefficient")); //(F()) save string to flash & keeps dynamic memory free
    delay(5000);
  Serial.println(F("AHT10 OK"));
  //Wire.setClock(400000); //experimental I2C speed! 400KHz, default 100KHz
    loop()
     Main loop
  /* DEMO - 1, every temperature or humidity call will read 6-bytes over I2C, total 12-bytes */
  Serial.println(F("DEMO 1: read 12-bytes"));
  ahtValue = aht10.readTemperature(); //read 6-bytes via I2C, takes 80 milliseconds
  Serial.print(F("Temperature...: "));
  if (ahtValue != AHTXX_ERROR) //AHTXX_ERROR = 255, library returns 255 if error occurs
    Serial.print(ahtValue);
    Serial.println(F(" +-0.3C"));
    printStatus(); //print temperature command status
    if   (aht10.softReset() == true) Serial.println(F("reset success")); //as the last chance to make it alive
    else                             Serial.println(F("reset failed"));
  delay(2000); //measurement with high frequency leads to heating of the sensor, see NOTE
  ahtValue = aht10.readHumidity(); //read another 6-bytes via I2C, takes 80 milliseconds
  Serial.print(F("Humidity......: "));
    Serial.println(F(" +-2%"));
    printStatus(); //print humidity command status
  /* DEMO - 2, temperature call will read 6-bytes via I2C, humidity will use same 6-bytes */
  Serial.println(F("DEMO 2: read 6-byte"));
  Serial.print(F("Temperature: "));
  ahtValue = aht10.readHumidity(AHTXX_USE_READ_DATA); //use 6-bytes from temperature reading, takes zero milliseconds!!!
  Serial.print(F("Humidity...: "));
    printStatus(); //print temperature command status not humidity!!! RH measurement use same 6-bytes from T measurement
  delay(10000); //recomended polling frequency 8sec..30sec
    printStatus()
    Print last command status
void printStatus()
  switch (aht10.getStatus())
    case AHTXX_NO_ERROR:
      Serial.println(F("no error"));
    case AHTXX_BUSY_ERROR:
      Serial.println(F("sensor busy, increase polling time"));
    case AHTXX_ACK_ERROR:
      Serial.println(F("sensor didn't return ACK, not connected, broken, long wires (reduce speed), bus locked by slave (increase stretch limit)"));
    case AHTXX_DATA_ERROR:
      Serial.println(F("received data smaller than expected, not connected, broken, long wires (reduce speed), bus locked by slave (increase stretch limit)"));
    case AHTXX_CRC8_ERROR:
      Serial.println(F("computed CRC8 not match received CRC8, this feature supported only by AHT2x sensors"));
    default:
      Serial.println(F("unknown status"));
Lo stesso codice caricato su Arduino Nano funziona alla grande.
Collegamenti giusti, alimentazione a 3.3V ma purtroppo non va.
Cerco idee anche perchè è la mia prima esperienza con ESP32 se non fosse per qualche prova con led e comunque prove semplici.
Grazie anticipatamente
Alberto
Mi pare che manchi un Wire.begin() nel setup(), prova ad aggiungerlo, non è detto che funzioni ma tentare non nuoce. Hai provato se l'i2c_scanner lo trova? Le resistenze di pullup ci sono?
Ciao, Ale.
I2C scanner lo trova all'indirizzo 0X38 com'è giusto che sia.
Le resistenze di pull up da 10k da SCL e SDA ai 3.3V positivi ci sono ma se le tolgo non cambia nulla e comunque con il nano funziona anche senza.
Proverò Wire.begin() ma come scritto precedentemente con il nano funziona così com'è.
Grazie delle indicazioni comunque.
Il Nano ha dei pin pre-assegnati per l'I2C e non è possibile cambiarli in alcun modo.
Con l'ESP32 invece tutte le periferiche hardware (compreso quindi l'I2C) possono essere assegnate quasi ad ogni pin disponibile, per questo è necessario chiamare comunque il Wire.begin() che va ad inizilizzare la periferica con i pin assegnati di default (che dipendono dalla scheda specifica che hai selezionato).
static const uint8_t SDA = 21;
static const uint8_t SCL = 22;
Ad ogni modo, se hai necessità di collegarli in modo diverso puoi farlo e poi con l'istruzione Wire.begin() passi i parametri sda e scl (ed eventualmente il clock del bus che di default è 100 Khz)
bool begin(int sda, int scl, uint32_t frequency = 0);  // returns true, if successful init of i2c bus
Anzi, probabilmente ti conviene farlo direttamente con il metodo della libreria, che poi fa tutto il resto con Wire
#elif defined  (ARDUINO_ARCH_ESP32)
bool AHTxx::begin(int32_t sda, int32_t scl, uint32_t speed, uint32_t stretch) //"int32_t" for Master SDA & SCL, "uint8_t" for Slave SDA & SCL
  if (Wire.begin(sda, scl, speed) != true) {return false;} //experimental! ESP32 I2C bus speed ???kHz..400kHz, default 100000Hz
Risolto con l'aggiunta di Wire.begin() e senza assegnare i pin I2C da sketch come quoto qui di seguito.
Tra l'altro questa assegnazione dei pin per il collegamento I2C non funziona, mi da errore.
Proverò a studiarmi il sistema della libreria consigliato da "cotestatnt" perchè messo così nel post mi è poco poco chiaro.
PS le resistene di pull-up in realtà ci sono... nascoste ma le ho messe.
Grazie delle dritte.
A.
