ESP32/ESP8266 connect to localhost server using WiFi
Hi, I have made a simple local server to receive the data from ESP and put it in data base
the server is working fine as I tested it using postman. the server is listening to port 127.0.0.1:3000
my problem is that client.connect(host,port) returns false.
#include "Arduino.h"
#include "WiFi.h"
WiFiClient client;
const IPAddress server(192,168,1,10);
const int httpPort = 3000;
const char* ssid = "******";
const char* password =  "********";
  Serial.println("Booted");
  Serial.println("Connecting to Wi-Fi");
  WiFi.begin (ssid, password);
  WiFi.mode(WIFI_STA);
    Serial.print(".");
    yield();
  Serial.println("WiFi connected");
 if (client.connect(server,httpPort )){
 Serial.println("Client Connected");
 else{
     Serial.println("No Connection");
// The loop function is called in an endless loop
//Add your repeated code here
firewall?
Juraj:
firewall?
Disabled
use #include <ESP8266WiFi.h>
and remove those arduino includes
Juraj:
This is ESP32 WiFi library not Arduino WiFi library
I have removed the doubled "Arduino.h" the problem is not there
from esp8266 arduino core 2.3?
Juraj:
I have tested the provided example on ESP32 and ESP8266 on both platforms the connection to the localhost failed
for sure when I am switching the platforms for testing I change the WiFi library
WiFi.h for ESP32
ESP8266WiFi.h for ESP8266
I am using esp8266 core 2.2.0 and the latest for ESP32 core
ok. I understand.
the examples work? WiFiClient example?
Juraj:
ok. I understand.
Yes I can connect to any online host like "script.google.com" or sparkfun
the IP address is correct? in post text you have the loopback address and in sketch a real address.
Juraj:
IPv4 Address. . . . . . . . . . . : 192.168.1.10
Subnet Mask . . . . . . . . . . . : 255.255.255.0
I was disparate so I reset it manually :smiley: yes its correct
eahabissac:
it is the server address, right? not the esp address?
the server is http or https?
Juraj:
yes, my pc IP address which runs the local server
the postman url, if you test it from browser is http or https? why port 3000? it is unusual
Juraj:
its http
3000 No reason,
its working fine with postman
UPDATE: I used Port Listener v1.03, to listen to port 3000 and the client connected successfully, but I still cant see why when I listen from the server I can not connect
I was out of ideas. So something with nonstandard port?
This sounds like a web server configuration problem. Can a web browser running on a computer different access the web server? If not, the web server may be configured to only allow access from the computer running the web server. Check the web server docs. In some systems, configuring the web server IP as 127.0.0.1 will cause the web server to reject connections from all computers except the computer running the web server.
When I used AMMPS a long time ago, it did not like non-standard port numbers, that is, anything other than 80 and 8080. I would give port 80 try just in case this issue exists with the web server.
gdsports:
Thank you, it worked now I reconfigured my local server with 0.0.0.0 IP instead of 27.0.0.1
