ESP32 HTTPS request not working
I'm trying to use the ESP32 HTTPS request exemple, but i keep recinv the same error: "connection refused".
I also tryied this with other URLs, but since this is an oficial exemple, what could i've been doing wrong?
This is the exemple code:
   BasicHTTPSClient.ino
    Created on: 14.10.2018
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiMulti.h>
#include <HTTPClient.h>
#include <WiFiClientSecure.h>
// This is GandiStandardSSLCA2.pem, the root Certificate Authority that signed
// the server certifcate for the demo server https://jigsaw.w3.org in this
// example. This certificate is valid until Sep 11 23:59:59 2024 GMT
const char* rootCACertificate = \
"-----BEGIN CERTIFICATE-----\n" \
"MIIF6TCCA9GgAwIBAgIQBeTcO5Q4qzuFl8umoZhQ4zANBgkqhkiG9w0BAQwFADCB\n" \
"iDELMAkGA1UEBhMCVVMxEzARBgNVBAgTCk5ldyBKZXJzZXkxFDASBgNVBAcTC0pl\n" \
"cnNleSBDaXR5MR4wHAYDVQQKExVUaGUgVVNFUlRSVVNUIE5ldHdvcmsxLjAsBgNV\n" \
"BAMTJVVTRVJUcnVzdCBSU0EgQ2VydGlmaWNhdGlvbiBBdXRob3JpdHkwHhcNMTQw\n" \
"OTEyMDAwMDAwWhcNMjQwOTExMjM1OTU5WjBfMQswCQYDVQQGEwJGUjEOMAwGA1UE\n" \
"CBMFUGFyaXMxDjAMBgNVBAcTBVBhcmlzMQ4wDAYDVQQKEwVHYW5kaTEgMB4GA1UE\n" \
"AxMXR2FuZGkgU3RhbmRhcmQgU1NMIENBIDIwggEiMA0GCSqGSIb3DQEBAQUAA4IB\n" \
"DwAwggEKAoIBAQCUBC2meZV0/9UAPPWu2JSxKXzAjwsLibmCg5duNyj1ohrP0pIL\n" \
"m6jTh5RzhBCf3DXLwi2SrCG5yzv8QMHBgyHwv/j2nPqcghDA0I5O5Q1MsJFckLSk\n" \
"QFEW2uSEEi0FXKEfFxkkUap66uEHG4aNAXLy59SDIzme4OFMH2sio7QQZrDtgpbX\n" \
"bmq08j+1QvzdirWrui0dOnWbMdw+naxb00ENbLAb9Tr1eeohovj0M1JLJC0epJmx\n" \
"bUi8uBL+cnB89/sCdfSN3tbawKAyGlLfOGsuRTg/PwSWAP2h9KK71RfWJ3wbWFmV\n" \
"XooS/ZyrgT5SKEhRhWvzkbKGPym1bgNi7tYFAgMBAAGjggF1MIIBcTAfBgNVHSME\n" \
"GDAWgBRTeb9aqitKz1SA4dibwJ3ysgNmyzAdBgNVHQ4EFgQUs5Cn2MmvTs1hPJ98\n" \
"rV1/Qf1pMOowDgYDVR0PAQH/BAQDAgGGMBIGA1UdEwEB/wQIMAYBAf8CAQAwHQYD\n" \
"VR0lBBYwFAYIKwYBBQUHAwEGCCsGAQUFBwMCMCIGA1UdIAQbMBkwDQYLKwYBBAGy\n" \
"MQECAhowCAYGZ4EMAQIBMFAGA1UdHwRJMEcwRaBDoEGGP2h0dHA6Ly9jcmwudXNl\n" \
"cnRydXN0LmNvbS9VU0VSVHJ1c3RSU0FDZXJ0aWZpY2F0aW9uQXV0aG9yaXR5LmNy\n" \
"bDB2BggrBgEFBQcBAQRqMGgwPwYIKwYBBQUHMAKGM2h0dHA6Ly9jcnQudXNlcnRy\n" \
"dXN0LmNvbS9VU0VSVHJ1c3RSU0FBZGRUcnVzdENBLmNydDAlBggrBgEFBQcwAYYZ\n" \
"aHR0cDovL29jc3AudXNlcnRydXN0LmNvbTANBgkqhkiG9w0BAQwFAAOCAgEAWGf9\n" \
"crJq13xhlhl+2UNG0SZ9yFP6ZrBrLafTqlb3OojQO3LJUP33WbKqaPWMcwO7lWUX\n" \
"zi8c3ZgTopHJ7qFAbjyY1lzzsiI8Le4bpOHeICQW8owRc5E69vrOJAKHypPstLbI\n" \
"FhfFcvwnQPYT/pOmnVHvPCvYd1ebjGU6NSU2t7WKY28HJ5OxYI2A25bUeo8tqxyI\n" \
"yW5+1mUfr13KFj8oRtygNeX56eXVlogMT8a3d2dIhCe2H7Bo26y/d7CQuKLJHDJd\n" \
"ArolQ4FCR7vY4Y8MDEZf7kYzawMUgtN+zY+vkNaOJH1AQrRqahfGlZfh8jjNp+20\n" \
"J0CT33KpuMZmYzc4ZCIwojvxuch7yPspOqsactIGEk72gtQjbz7Dk+XYtsDe3CMW\n" \
"1hMwt6CaDixVBgBwAc/qOR2A24j3pSC4W/0xJmmPLQphgzpHphNULB7j7UTKvGof\n" \
"KA5R2d4On3XNDgOVyvnFqSot/kGkoUeuDcL5OWYzSlvhhChZbH2UF3bkRYKtcCD9\n" \
"0m9jqNf6oDP6N8v3smWe2lBvP+Sn845dWDKXcCMu5/3EFZucJ48y7RetWIExKREa\n" \
"m9T8bJUox04FB6b9HbwZ4ui3uRGKLXASUoWNjDNKD/yZkuBjcNqllEdjB+dYxzFf\n" \
"BT02Vf6Dsuimrdfp5gJ0iHRc2jTbkNJtUQoj1iM=\n" \
"-----END CERTIFICATE-----\n";
// Not sure if WiFiClientSecure checks the validity date of the certificate.
// Setting clock just to be sure...
void setClock() {
  configTime(0, 0, "pool.ntp.org", "time.nist.gov");
  Serial.print(F("Waiting for NTP time sync: "));
  time_t nowSecs = time(nullptr);
  while (nowSecs < 8 * 3600 * 2) {
    Serial.print(F("."));
    yield();
  struct tm timeinfo;
  gmtime_r(&nowSecs, &timeinfo);
  Serial.print(F("Current time: "));
  Serial.print(asctime(&timeinfo));
WiFiMulti WiFiMulti;
  // Serial.setDebugOutput(true);
  WiFi.mode(WIFI_STA);
  WiFiMulti.addAP("2GFelicidade", "MiraMaria");
  // wait for WiFi connection
  Serial.print("Waiting for WiFi to connect...");
  while ((WiFiMulti.run() != WL_CONNECTED)) {
    Serial.print(".");
  Serial.println(" connected");
  setClock();
  WiFiClientSecure *client = new WiFiClientSecure;
  if(client) {
    client -> setCACert(rootCACertificate);
      // Add a scoping block for HTTPClient https to make sure it is destroyed before WiFiClientSecure *client is
      HTTPClient https;
      Serial.print("[HTTPS] begin...\n");
      if (https.begin(*client, "https://jigsaw.w3.org/HTTP/connection.html")) {  // HTTPS
        Serial.print("[HTTPS] GET...\n");
        // start connection and send HTTP header
        int httpCode = https.GET();
        // httpCode will be negative on error
        if (httpCode > 0) {
          // HTTP header has been send and Server response header has been handled
          Serial.printf("[HTTPS] GET... code: %d\n", httpCode);
          // file found at server
          if (httpCode == HTTP_CODE_OK || httpCode == HTTP_CODE_MOVED_PERMANENTLY) {
            String payload = https.getString();
            Serial.println(payload);
          Serial.printf("[HTTPS] GET... failed, error: %s\n", https.errorToString(httpCode).c_str());
        https.end();
        Serial.printf("[HTTPS] Unable to connect\n");
      // End extra scoping block
    delete client;
    Serial.println("Unable to create client");
  Serial.println("Waiting 10s before the next round...");
  delay(10000);
@davyguilherme
are you using an Arduino Nano ESP32 or another ESP32 board?
Maybe your certificate has expired and needs to be updated.
I'm using node mcu with esp32 chip
I'll request for this topic to be moved to a more appropriate section, since this one is strictly related to Nano ESP32 and we collect feedback on things that might not work with this specific board
As already mentioned... you are using the wrong certificate for the page you are requesting.
The certificate you set up was generated by "USERTrust RSA Certification Authority" while the resource you request is hosted on a server that uses a certificate generated by the certification authority "Baltimore CyberTrust Root"
You can edit the root certificate like this::
const char* rootCACertificate = R"string_literal(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)string_literal";
@ubidefeo I think this problem may also be encountered by owners of the Nano@esp32 board, or not?
I moved your topic to a more appropriate forum category @davyguilherme.
The Nano ESP32 category you chose is only used for discussions directly related to the Arduino Nano ESP32 board.
In the future, please take the time to pick the forum category that best suits the subject of your question. There is an "About the _____ category" topic at the top of each category that explains its purpose.
Thanks in advance for your cooperation.
thanks a lot! now it is working!
guys, despite it worked with the exemple url [Connection Header], it still doesn't work with the real domain i'm trying to make a get request. I don't know if I'm picking the SSL certificate in the wrong place again..
here is the code with the real domain i need to make it work [https://dguilherme.dev]:
#include <WiFi.h>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=
)string_literal";
void setClock() {
    yield();
  struct tm timeinfo;
    Serial.print(".");
  setClock();
  if(client) {
      HTTPClient https;
      if (https.begin(*client, "https://dguilherme.dev")) {  // HTTPS
        if (httpCode > 0) {
        https.end();
    delete client;
  delay(10000);
Each domain has its own certificate.
You can't expect to put a certificate from another domain and it will work
oh sorry! i was doing some tests and ended up posting the code with one of the other tree certificates that seems to be available in Firefox. I will attach a print of this.
I'm trying this variable with the only one certificate that chrome allows me to download, and the variable looks like this: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)string_literal";
but it still doesn`t work.
