ESP32 LittleFS_Time with ftp showing blank directory
I've tried adding SimpleFTPServer to this example, which I've modified to create and leave some files and directories.
but when I access the unit via ftp (Filezilla) I just see an empty root directory.
Other ESP32 circuits I can FTP with no issues.
Can anyone help?
code below
#include "FS.h"
//#include "SPIFFS.h"
#include "LittleFS.h"
#include <time.h>
#include <WiFi.h>
#define SPIFFS LittleFS
/* This examples uses "quick re-define" of SPIFFS to run
   an existing sketch with LittleFS instead of SPIFFS
   You only need to format LittleFS the first time you run a
   test or else use the LittleFS plugin to create a partition
   https://github.com/lorol/arduino-esp32littlefs-plugin */
#define FORMAT_LITTLEFS_IF_FAILED true
#include <SimpleFTPServer.h>
FtpServer ftpSrv;  //set #define FTP_DEBUG in ESP8266FtpServer.h to see ftp verbose on serial
const char *ssid = "xxx";
const char *password = "xxx";
/* Configuration of NTP */
#define MY_NTP_SERVER "pool.ntp.org"
long timezone = 1;
byte daysavetime = 1;
void listDir(fs::FS &fs, const char *dirname, uint8_t levels) {
  Serial.printf("Listing directory: %s\n", dirname);
  File root = fs.open(dirname);
  if (!root) {
    Serial.println("Failed to open directory");
    return;
  if (!root.isDirectory()) {
    Serial.println("Not a directory");
    return;
  File file = root.openNextFile();
  while (file) {
    if (file.isDirectory()) {
      Serial.print("  DIR : ");
      Serial.print(file.name());
      time_t t = file.getLastWrite();
      struct tm *tmstruct = localtime(&t);
      Serial.printf(
        "  LAST WRITE: %d-%02d-%02d %02d:%02d:%02d\n", (tmstruct->tm_year) + 1900, (tmstruct->tm_mon) + 1, tmstruct->tm_mday, tmstruct->tm_hour,
        tmstruct->tm_min, tmstruct->tm_sec);
      if (levels) {
        listDir(fs, file.path(), levels - 1);
      Serial.print("  FILE: ");
      Serial.print("  SIZE: ");
      Serial.print(file.size());
      Serial.printf(
void createDir(fs::FS &fs, const char *path) {
  Serial.printf("Creating Dir: %s\n", path);
  if (fs.mkdir(path)) {
    Serial.println("Dir created");
    Serial.println("mkdir failed");
void removeDir(fs::FS &fs, const char *path) {
  Serial.printf("Removing Dir: %s\n", path);
  if (fs.rmdir(path)) {
    Serial.println("Dir removed");
    Serial.println("rmdir failed");
void readFile(fs::FS &fs, const char *path) {
  Serial.printf("Reading file: %s\n", path);
  File file = fs.open(path);
  if (!file) {
    Serial.println("Failed to open file for reading");
    return;
  Serial.print("Read from file: ");
  while (file.available()) {
    Serial.write(file.read());
  file.close();
void writeFile(fs::FS &fs, const char *path, const char *message) {
  Serial.printf("Writing file: %s\n", path);
  File file = fs.open(path, FILE_WRITE);
  if (!file) {
    Serial.println("Failed to open file for writing");
    return;
  if (file.print(message)) {
    Serial.println("File written");
    Serial.println("Write failed");
  file.close();
void appendFile(fs::FS &fs, const char *path, const char *message) {
  Serial.printf("Appending to file: %s\n", path);
  File file = fs.open(path, FILE_APPEND);
  if (!file) {
    Serial.println("Failed to open file for appending");
    return;
    Serial.println("Message appended");
    Serial.println("Append failed");
  file.close();
void renameFile(fs::FS &fs, const char *path1, const char *path2) {
  Serial.printf("Renaming file %s to %s\n", path1, path2);
  if (fs.rename(path1, path2)) {
    Serial.println("File renamed");
    Serial.println("Rename failed");
void deleteFile(fs::FS &fs, const char *path) {
  Serial.printf("Deleting file: %s\n", path);
  if (fs.remove(path)) {
    Serial.println("File deleted");
    Serial.println("Delete failed");
void _callback(FtpOperation ftpOperation, unsigned int freeSpace, unsigned int totalSpace) {
  switch (ftpOperation) {
    case FTP_CONNECT:
      Serial.println(F("FTP: Connected!"));
    case FTP_DISCONNECT:
      Serial.println(F("FTP: Disconnected!"));
    case FTP_FREE_SPACE_CHANGE:
      Serial.printf("FTP: Free space change, free %u of %u!\n", freeSpace, totalSpace);
    default:
void _transferCallback(FtpTransferOperation ftpOperation, const char *name, unsigned int transferredSize) {
    case FTP_UPLOAD_START:
      Serial.println(F("FTP: Upload start!"));
    case FTP_UPLOAD:
      Serial.printf("FTP: Upload of file %s byte %u\n", name, transferredSize);
    case FTP_TRANSFER_STOP:
      Serial.println(F("FTP: Finish transfer!"));
    case FTP_TRANSFER_ERROR:
      Serial.println(F("FTP: Transfer error!"));
    default:
  /* FTP_UPLOAD_START = 0,
   * FTP_UPLOAD = 1,
   * FTP_DOWNLOAD_START = 2,
   * FTP_DOWNLOAD = 3,
   * FTP_TRANSFER_STOP = 4,
   * FTP_DOWNLOAD_STOP = 4,
   * FTP_UPLOAD_STOP = 4,
   * FTP_TRANSFER_ERROR = 5,
   * FTP_DOWNLOAD_ERROR = 5,
   * FTP_UPLOAD_ERROR = 5
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  Serial.println("Contacting Time Server");
  configTime(0, 0, MY_NTP_SERVER);  // --> Here is the IMPORTANT ONE LINER needed in your sketch!
  while (time(nullptr) < 1600000000) {  // wait for the first time sync
    Serial.print("w");
  //configTime(3600 * timezone, daysavetime * 3600, "time.nist.gov", "0.pool.ntp.org", "1.pool.ntp.org");
  struct tm tmstruct;
  delay(2000);
  tmstruct.tm_year = 0;
  getLocalTime(&tmstruct, 5000);
  Serial.printf(
    "\nNow is : %d-%02d-%02d %02d:%02d:%02d\n", (tmstruct.tm_year) + 1900, (tmstruct.tm_mon) + 1, tmstruct.tm_mday, tmstruct.tm_hour, tmstruct.tm_min,
    tmstruct.tm_sec);
  Serial.println("");
  if (!SPIFFS.begin(FORMAT_LITTLEFS_IF_FAILED)) {
    Serial.println("LittleFS Mount Failed");
    return;
  Serial.println("----list 1----");
  listDir(SPIFFS, "/", 2);
  //delete old files
  deleteFile(SPIFFS, "/hello.txt");
  deleteFile(SPIFFS, "/hello2.txt");
  deleteFile(SPIFFS, "/mydir/hello2.txt");
  Serial.println("----remove old dir----");
  removeDir(SPIFFS, "/mydir");
  Serial.println("----create a new dir----");
  createDir(SPIFFS, "/mynewdir");
  Serial.println("----create and work with file----");
  writeFile(SPIFFS, "/hello.txt", "Hello this is a longer file");
  writeFile(SPIFFS, "/mynewdir/hello.txt", "Hello ");
  appendFile(SPIFFS, "/mynewdir/hello.txt", "World!\n");
  Serial.println("----list 2----");
  Serial.println("Test complete");
  /////FTP Setup, ensure SPIFFS is started before ftp;  /////////
  ftpSrv.begin("user", "password");  //username, password for ftp.   (default 21, 50009 for PASV)
  ftpSrv.setCallback(_callback);
  ftpSrv.setTransferCallback(_transferCallback);
  ftpSrv.handleFTP();  //make sure in loop you call handleFTP()!!
there is also from the example ci.json tab
  "requires_any": [
    "CONFIG_SOC_WIFI_SUPPORTED=y",
    "CONFIG_ESP_WIFI_REMOTE_ENABLED=y"
the serial moonitor shows all behaving correctly,
10:27:17.033 -> IP address:
10:27:17.033 -> 192.168.1.57
10:27:17.033 -> Contacting Time Server
10:27:17.033 -> w
10:27:20.011 -> Now is : 2025-03-30 09:27:16
10:27:20.011 ->
10:27:20.011 -> ----list 1----
10:27:20.011 -> Listing directory: /
10:27:20.011 ->   FILE: hello.txt  SIZE: 27  LAST WRITE: 2025-03-30 09:02:57
10:27:20.049 ->   DIR : mydir  LAST WRITE: 1969-12-31 23:59:59
10:27:20.049 -> Listing directory: /mydir
10:27:20.049 ->   FILE: hello.txt  SIZE: 13  LAST WRITE: 2025-03-30 09:00:11
10:27:20.083 ->   DIR : mynewdir  LAST WRITE: 1969-12-31 23:59:59
10:27:20.083 -> Listing directory: /mynewdir
10:27:20.083 ->   FILE: hello.txt  SIZE: 13  LAST WRITE: 2025-03-30 09:02:57
10:27:20.118 -> Deleting file: /hello.txt
10:27:20.118 -> File deleted
10:27:20.118 -> Deleting file: /hello2.txt
10:27:20.118 -> Delete failed
10:27:20.118 -> Deleting file: /mydir/hello2.txt
10:27:20.118 -> ----remove old dir----
10:27:20.118 -> Removing Dir: /mydir
10:27:20.118 -> rmdir failed
10:27:20.160 -> ----create a new dir----
10:27:20.160 -> Creating Dir: /mynewdir
10:27:20.160 -> Dir created
10:27:20.160 -> ----create and work with file----
10:27:20.160 -> Writing file: /hello.txt
10:27:20.160 -> File written
10:27:20.160 -> Writing file: /mynewdir/hello.txt
10:27:20.195 -> Appending to file: /mynewdir/hello.txt
10:27:20.195 -> Message appended
10:27:20.195 -> ----list 2----
10:27:20.195 -> Listing directory: /
10:27:20.236 ->   FILE: hello.txt  SIZE: 27  LAST WRITE: 2025-03-30 09:27:17
10:27:20.236 ->   DIR : mydir  LAST WRITE: 1969-12-31 23:59:59
10:27:20.236 -> Listing directory: /mydir
10:27:20.236 ->   FILE: hello.txt  SIZE: 13  LAST WRITE: 2025-03-30 09:00:11
10:27:20.273 ->   DIR : mynewdir  LAST WRITE: 1969-12-31 23:59:59
10:27:20.273 -> Listing directory: /mynewdir
10:27:20.273 ->   FILE: hello.txt  SIZE: 13  LAST WRITE: 2025-03-30 09:27:17
10:27:20.313 -> Test complete
10:28:46.945 -> FTP: Connected!
10:33:48.060 -> FTP: Disconnected!
I see the same results if I use SPIFFS.
