ESP32 Long Time Working Problem
Good day, I want to make a gateway connecting to ethernet via esp32 using mqtt, but my device stops working after 12 hours when I use the code below, and when I manually reset it, it keeps working again. What can I do to keep it running for a long time?
Note: I tried setting a static IP but it stopped working again after 12 hours.
The versions I used;
https://dl.espressif.com/dl/package_esp32_index.json
Arduino == 1.18.13
UIPEthernet == 2.0.9
MQTT == 2.5.0
Arduino IDLE Card Selection == Node32s
Card Link == Buy ESP32-WROOM-32U Wifi Bluetooth Development Module with Affordable Price - Direnc.net®
#include <UIPEthernet.h>
#include <MQTT.h>
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
EthernetClient net;
MQTTClient client;
unsigned long lastMillis = 0;
#define mqttServer IPAddress(1,1,1,1)
const char* mqttUser = "test";
const char* mqttPassword = "test";
void messageReceived(String &topic, String &payload) {
  Serial.println("incoming: " + topic + " - " + payload);
  if (Ethernet.begin(mac) == 0) {
    Serial.println("Failed to configure Ethernet using DHCP");
    for (;;)
  Ethernet.begin(mac, Ethernet.localIP());
  client.begin(mqttServer, net);
  client.onMessage(messageReceived);
  connect();
void connect() {
  Serial.print("connecting...");
  while (!client.connect("ESP32", mqttUser, mqttPassword)) {
  Serial.println("\nconnected!");
 client.subscribe("esp/data");
   client.loop();
  client.publish("esp/data",  "Hello Word");
       if (!client.connected()){
      connect();
Is your issue WiFi or MQTT?
I am using pubsubclient.
You do realize that the above code runs faster then the MQTT Broker is comfortable with receiving information from a publisher? MQTT is rated for 1 message every .1 seconds. Could be a cause of issue. Suggest you read up on MQTT.
void connectToWiFi()
  int TryCount = 0;
  //log_i( "connect to wifi" );
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
} // void connectToWiFi()
That's my WiFi connection routine.
void connectToMQTT()
  MQTTclient.setKeepAlive( 90 ); // needs be made before connecting
  byte mac[5];
  WiFi.macAddress(mac);
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
  while ( !MQTTclient.connected() )
    // boolean connect(const char* id, const char* user, const char* pass, const char* willTopic, uint8_t willQos, boolean willRetain, const char* willMessage);
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password, NULL , 1, true, NULL );
    vTaskDelay( 250 );
  MQTTclient.setCallback( mqttCallback );
  MQTTclient.subscribe( topicOK );
} // void connectToMQTT()
That's my MQTT connection routine.
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  // setting must be set before a mqtt connection is made
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status %s WiFi status %s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
    vTaskDelay( 250 ); //task runs approx every 250 mS
  vTaskDelete ( NULL );
This is the task that makes the initial WiFi and MQTT connection and maintains the connections. Notice the, MQTTclient.setKeepAlive( 90 );, line of code.
I forgot to add, actually I am sending 1 data in 1 second.
i will try your solution.
I'm trying to connect via ethernet not wifi. :frowning:
I noted. Still you'll need something to check on and maintain the connection, right?
I keep the data from mqtt in my database for seconds, when the flow stops, when I look at the time frame of the last incoming data, I noticed that it takes an average of 12 hours and the data does not transfer for a longer time.
I don't think the problem is with the mqtt library. I have been investigating this issue for 4 days. I have read that those who use the pubsubclient library also have the same problem.
How long did you run esp32 for a long time?
One of the 8 ESP32's connected to the MQTT Broker publishing and subscribing has been connected continuously for 8ish months. The other 7 ESP32's have been connected for similar lengths of time. Right now ESP32 9 is being worked on so its continuous MQTT connection will vary depending upon code testing and changes.
If you don't mind, can you share the code with me and are all connections over wifi ?
Here is the code to my solar powered weather station that has had its MQTT connection for 8+ months continous:
   Project, use solar cells to generate power
   2/2/2020
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include "freertos/timers.h"
#include "freertos/event_groups.h"
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <ESP32Time.h>
#define evtDoMQTTwd          ( 1 << 1 )
EventGroupHandle_t eg; // variable for the event group handle
WiFiClient   wifiClient;
PubSubClient MQTTclient(mqtt_server, mqtt_port, wifiClient);
ESP32Time    rtc;
Adafruit_BME680 bme( GPIO_NUM_5 );
   This semaphore is used to stop or prevent a publish from happening during client.loop()
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_mqttOK; // protects the int mqttOK
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int     payloadSize = 300;
bool          TimeSet = false;
struct        stu_message
  char        payload [payloadSize] = {'\0'};
  String      topic ;
} x_message;
int mqttOK = 0; // stores a count value that is used to cause an esp reset
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  // clear locations
  memset( x_message.payload, '\0', payloadSize );
  x_message.topic = ""; //clear string buffer
  x_message.topic = topic;
  int i = 0;
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    case SYSTEM_EVENT_STA_CONNECTED:
    case SYSTEM_EVENT_STA_DISCONNECTED:
      log_i("Disconnected from WiFi access point");
    case SYSTEM_EVENT_AP_STADISCONNECTED:
      log_i("WiFi client disconnected");
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  x_message.topic.reserve( payloadSize );
  xQ_Message  = xQueueCreate( 1, sizeof(stu_message) );
  sema_mqttOK = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  eg = xEventGroupCreate(); // get an event group handle
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 20000, NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( fDoBME, "fDoBME", 20000, NULL, 3, NULL, 1 ); // assigned to core
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 10000, NULL, 4, NULL, 1 ); // assign all to core 1, WiFi in use.
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 3000, NULL, 3, NULL, 1 ); // assign all to core 1
} //void setup()
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 85000; // get another reading when = UpdateTimeTrigger
  int maxNonMQTTresponse = 3;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 60000; //delay for mS
  for (;;)
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    xSemaphoreTake( sema_mqttOK, portMAX_DELAY ); // update mqttOK
    mqttOK++;
    if ( mqttOK >= maxNonMQTTresponse )
      log_i( "mqtt watchdog rest" );
      vTaskDelay( 200 );
      ESP.restart();
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
  vTaskDelete( NULL );
} //void fmqttWatchDog( void * paramater )
  byte mac[5];
  WiFi.macAddress(mac); // get mac address
    vTaskDelay( 250 );
  log_i("MQTT Connected");
void fDoBME ( void *pvParameters )
  if (!bme.begin()) {
    log_i("Could not find a valid BME680 sensor, check wiring!");
    while (1);
  // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
  const TickType_t xFrequency = 1000 * 15;
  //wait for a mqtt connection
    vTaskDelay( 250 );
  String bmeInfo = "";
  bmeInfo.reserve( 100 );
  int Count = 0;
  for ( ;; )
    bmeInfo.concat( String((bme.readTemperature() * 1.8f) + 32.0f, 4) ); // (Celsius x 1.8) + 32
    bmeInfo.concat( "," );
    bmeInfo.concat( String( bme.readPressure() / 133.3223684f,4) ); //mmHg
    bmeInfo.concat( String(bme.readHumidity(),3) );
    bmeInfo.concat( String(bme.readGas()) );
    MQTTclient.publish( topicOutside, bmeInfo.c_str() );
    xEventGroupSetBits( eg, evtDoMQTTwd );
    Count++;
    log_i( "Tick from line 142 count is %d", Count );
    bmeInfo = "";
  } // for loop
} // void fDoBME ( void *pvParameters )
    Important to not set vTaskDelay to less then 10. Errors begin to develop with the MQTT and network connection.
    makes the initial wifi/mqtt connection and works to keeps those connections open.
  for (;;)
      MQTTclient.loop();
    else {
        connectToWiFi();
      connectToMQTT();
  int TryCount = 0;
    TryCount++;
    WiFi.disconnect();
    vTaskDelay( 4000 );
      ESP.restart();
void fparseMQTT( void *pvParameters )
  struct stu_message px_message;
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      mqttOK = 0;
      if ( !TimeSet)
        if ( String(px_message.topic) == topicOK )
          String temp = "";
          temp        = px_message.payload[0];
          temp        += px_message.payload[1];
          temp        += px_message.payload[2];
          temp        += px_message.payload[3];
          int year    =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[5];
          temp        += px_message.payload[6];
          int month   =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[8];
          temp        += px_message.payload[9];
          int day     =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[11];
          temp        += px_message.payload[12];
          int hour    =  temp.toInt();
          temp        = "";
          temp        = px_message.payload[14];
          temp        += px_message.payload[15];
          int min     =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "%s   rtc  %s ", px_message.payload, rtc.getTime() );
          TimeSet     = true;
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void loop() {}
The code is for ESP32's and uses WiFi.
Thanks for the code, it may take time for me to understand, I'll implement it according to my own code. I will report the results to you. :slight_smile:
I guess after a while esp is resetting itself, is it true?
If the MQTT connection has an issue, the ESP32 will reset its self, as per my code. That has happened 3 or 4 times, when I reset the MQTT Broker, over the last 8 months.
When the MQTT client gets a connection to the broker a token is generated that is held by the client. If the MQTT Broker is reset then all the tokens become invalid. So the network connection and the MQTT connection will show good but the MQTT Broker will refuse the connection because the token is invalid.
So when I reset the MQTT Broker, all the ESP32's I have setup will reset themselves, and get a new token. That way I don't have to climb into my attic, or climb the pole in the backyard, to reset the ESP32's.
I guess the problem is esp's memory, reset is like the only option, thank you for your suggestion.
