Hi all,
I am need to generate complementary PWM using MCPWM. The duty cycle needs to be of typically 5us and time period 10us. While search through forum, I found a code for PWM (not complementary). I am trying to change frequency and duty. However the code seems to work sometimes and some times it doesn't. I removed a syn() line form original code posted in ( ESP32 mcPWM) . As I am new to using MCPWM can somebody suggest what needs to be done.
#include "driver/mcpwm.h"
//MCPWM TRY 2
// REF:https://forum.arduino.cc/t/esp32-mcpwm/608899
#define MOSFET 22 //pin to trigger the MOSFET (Output) pin22
mcpwm_gpio_init(MCPWM_UNIT_0, MCPWM0A, MOSFET);
mcpwm_pin_config_t pin_config;
// pin_config.mcpwm_sync0_in_num = GPIO_SYNC0_IN;
mcpwm_config_t pwm_config;
pwm_config.frequency = 100000; //frequency = 110Hz
pwm_config.cmpr_a = 50; //duty cycle of PWMxA = 60.0%
pwm_config.counter_mode = MCPWM_UP_COUNTER;
pwm_config.duty_mode = MCPWM_DUTY_MODE_0;
mcpwm_set_pin(MCPWM_UNIT_0, &pin_config);
mcpwm_init(MCPWM_UNIT_0, MCPWM_TIMER_0, &pwm_config); //Configure PWM0A & PWM0B with above settings
mcpwm_set_duty_type(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A, MCPWM_DUTY_MODE_0);
mcpwm_start(MCPWM_UNIT_0, MCPWM_TIMER_0);
//mcpwm_sync_enable(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_SELECT_SYNC0, 0);
mcpwm_set_duty(MCPWM_UNIT_0, MCPWM_TIMER_0, MCPWM_OPR_A,50);
