Hello,
I have been given a JC4880P443 board and thought i’d try to load an empty (nothing in setup or loop) the sketch complies ok and starts to upload then fail as per below any thought please.
Many thanks imk
Sketch uses 287080 bytes (21%) of program storage space. Maximum is 1310720 bytes.
Global variables use 20664 bytes (6%) of dynamic memory, leaving 307016 bytes for local variables. Maximum is 327680 bytes.
esptool v5.1.0
Serial port COM7:
Connecting...
Connected to ESP32-P4 on COM7:
Chip type: ESP32-P4 (revision v1.0)
Features: Dual Core + LP Core, 400MHz
Crystal frequency: 40MHz
USB mode: USB-Serial/JTAG
MAC: 30:ed:a0:e2:34:88
Uploading stub flasher...
Running stub flasher...
Stub flasher running.
Changing baud rate to 512000...
Changed.
Configuring flash size...
Flash will be erased from 0x00002000 to 0x00007fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x00056fff...
Compressed 21120 bytes to 13370...
Writing at 0x00002000 [ ] 0.0% 0/13370 bytes...
Writing at 0x00007280 [==============================] 100.0% 13370/13370 bytes...
A fatal error occurred: Serial data stream stopped: Possible serial noise or corruption.
Hard resetting via RTS pin...
Failed uploading: uploading error: exit status 2
