Esp32 Problem with http for google spreadsheet
I like to write / read from a google spreadsheet with an ESP32. Hence, I followed the instructions on:
ESP32 Data Logging to Google Sheets with Google Scripts (iotdesignpro.com).
Setting up the google spreadsheet worked fine. Whenever I execute the URL
https://script.google.com/macros/s/A****g/exec?sensor=35&date=1103 in a browser I get a new line in the spreadsheet as mentioned in the example.
In the next step I followed the example for the arduino code.
#include <WiFi.h>        //Wifi library
#include "esp_wpa2.h"    //wpa2 library for connections to Enterprise networks
#include <HTTPClient.h>  //Http Client to write and sent datato google spreadsheet
//const char* ssid_home = "FRITZ!Box****";
//const char* password_home = "0***5";
void connecthome(){
  Serial.print("Connect to Wifi at home ");
  WiFi.begin(ssid_home, password_home);
    Serial.print(".");
  Serial.println("");
  Serial.println("Home-WiFi connected");
  Serial.println("IP address: ");
  delay(10);
  // Set WiFi to station mode and disconnect from an AP if it was previously connected
  WiFi.mode(WIFI_STA);
  WiFi.disconnect();
  delay(100);
  Serial.println("Setup done");
  // Scan for all available networks
  int n = WiFi.scanNetworks();
  Serial.println("scan done");
  if (n == 0) {
      Serial.println("no networks found");
        connecthome();
        Serial.println("Connect to Home Network");
  String urlFinal = "https://script.google.com/macros/s/A***g/exec?sensor=35&date=1103";
  Serial.print("POST data to spreadsheet:");
  Serial.println(urlFinal);
  HTTPClient http;
  http.begin(urlFinal.c_str());
  http.setFollowRedirects(HTTPC_STRICT_FOLLOW_REDIRECTS);
  int httpCode = http.GET();
  Serial.print("HTTP Status Code: ");
  Serial.println(httpCode);
Excuting the code on the ESP32 I get the output
POST data to spreadsheet:h**3
HTTP Status Code: 200
but no line appears in the spreadsheet. I also tried different networks, but the result is the same. Has anyone an idea, what could be wrong.
Thanks for that, Axel
PS:
1: The connection to the network seems to be a bit strange. But in the full code IU automatically choose between two networks. I just deleted this part in this example as this is working fine.
2: In the replay there is the url, but I had to delete them as I'm not allowed to have so many links.
You might want to print out what Google returns to you.
