Hello, I've mixed SimpleTime and DeepSleep TimerWakeUp examples and created the below program that prints time from the internal RTC every 20 secs. The time is printed correctly when I first start the ESP32, but after the first sleep cycle, the time is off by 2 hrs and stays off consistently. I couldn't figure out the problem. Can someone please help?
My Code:
#include <WiFi.h>
#include "time.h"
#include "WiFi_credentials.h"
const char* ntpServer = "pool.ntp.org";
const long gmtOffset_sec = 3600;
const int daylightOffset_sec = 3600;
#define uS_TO_S_FACTOR 1000000ULL /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 20 /* Time ESP32 will go to sleep (in seconds) */
enum states_main {RST , TIME};
RTC_DATA_ATTR uint8_t state = RST;
void printLocalTime()
struct tm timeinfo;
if(!getLocalTime(&timeinfo)){
Serial.println("Failed to obtain time");
return;
Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
void sleep(){
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) +
" Seconds");
Serial.println("Going to sleep now");
Serial.println("---------------------------------------------");
Serial.println(" ");
Serial.flush();
esp_deep_sleep_start();
delay(100);
switch(state) {
case RST:
Serial.println("In RESET");
//connect to WiFi
Serial.printf("Connecting to %s ", ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println(" CONNECTED");
//init and get the time
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
printLocalTime();
//disconnect WiFi as it's no longer needed
WiFi.disconnect(true);
WiFi.mode(WIFI_OFF);
state = TIME;
sleep();
case TIME:
Serial.println("In TIME");
printLocalTime();
sleep();
Output from the Serial Terminal
In RESET
Connecting to WiFi ... CONNECTED
Tuesday, August 17 2021 19:04:33
Setup ESP32 to sleep for every 20 Seconds
Going to sleep now
ets Jun 8 2016 00:22:57
rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:10944
load:0x40080400,len:6388
entry 0x400806b4
In TIME
Tuesday, August 17 2021 17:04:53
Going to sleep now
ho 0 tail 12 room 4
entry 0x400806b4
In TIME
Tuesday, August 17 2021 17:05:14
Going to sleep now
ho 0 tail 12 room 4
entry 0x400806b4
In TIME
Tuesday, August 17 2021 17:05:34
Going to sleep now
ho 0 tail 12 room 4
entry 0x400806b4
In TIME
Tuesday, August 17 2021 17:05:54
Going to sleep now
As we can see the correct time was 19:04:33 but after the first deep sleep cycle, it got changed to 17:04:53 instead of 19:04:53. Can someone please tell me why this is happening?
