Hi. I am trying to do this project i stumble from github. I have run the program onto my ESP32, but after zeroing, the serial monitor shows the value that i needed but the stepper motor does not rotate according to the value on the serial monitor. The stepper motor does not rotate at all. Can someone explain why this is happening? Below is the coding that i imported onto my ESP32
#include <WiFi.h> //1.2.7
#include <HTTPClient.h>
#include <AccelStepper.h> // 1.64.0
#include <ESP32Time.h> // 2.0.0
#include <Sgp4.h> //https://github.com/Hopperpop/Sgp4-Library
#include "soc/soc.h" // to disable ESP32 brownout detector
#include "soc/rtc_cntl_reg.h" // to disable ESP32 brownout detector
#include <HardwareSerial.h>
#include "time.h"
#include <SerLCD.h> // 1.0.9
#include <math.h>
#include <strings.h>
#include "secrets.h"
// Replace with your network credentials
const char *ssid = SECRET_SSID;
const char *password = SECRET_PASS;
char satnames[20][30] = {"A-SEANSAT-PG1"}; // Names of satellites.
char satURL[20][40] = {"/NORAD/elements/gp.php?CATNR=57985"}; // URL of Celestrak TLEs for satellites (In same order as names).
char TLE1[20][70];
char TLE2[20][70];
long upcomingPasses[20];
int numSats = 1; // Number of satellites to track.
float minPassElevation = 10.0;
float myLat = 1.9344;
float myLong = 103.358729;
float myAlt = 27; // Your latitude, longitude and altitude.
const int timeZone = -5;
// pins:
// EL motor: 26, 18, 19, 23 Limit: 32
// AZ motor: 22, 21, 17 ,16 Limit: 27
// Azimuth stepper pins //
#define AZmotorPin1 22 // IN1 on the ULN2003 driver
#define AZmotorPin2 21 // IN2 on the ULN2003 driver
#define AZmotorPin3 17 // IN3 on the ULN2003 driver
#define AZmotorPin4 16 // IN4 on the ULN2003 driver
#define AZLimit 27
// Elevation stepper pins //
#define ELmotorPin1 26
#define ELmotorPin2 18
#define ELmotorPin3 19
#define ELmotorPin4 23
#define ELLimit 32
float oneTurn = 4096; // stepper steps/turn
int SAT;
int nextSat;
int AZstart;
long passEnd;
int satVIS;
int year;
int mon;
int day;
int hr;
int minute;
double sec;
int today;
long nextpassEpoch;
long nextpassEndEpoch;
long passDuration;
char satname[] = " ";
int passStatus = 0;
HardwareSerial LCD(2);
Sgp4 sat;
int satAZsteps;
int satELsteps;
int turns = 0;
#define MotorInterfaceType 8 // Define the AccelStepper interface type; 4 wire motor in half step mode:
AccelStepper stepperAZ = AccelStepper(MotorInterfaceType, AZmotorPin1, AZmotorPin3, AZmotorPin2, AZmotorPin4);
AccelStepper stepperEL = AccelStepper(MotorInterfaceType, ELmotorPin1, ELmotorPin3, ELmotorPin2, ELmotorPin4);
ESP32Time rtc(0);
unsigned long timeNow = 0;
const char *ntpServer = "pool.ntp.org";
unsigned long getTime()
time_t now;
struct tm timeinfo;
if (!getLocalTime(&timeinfo))
// Serial.println("Failed to obtain time");
return (0);
time(&now);
return now;
int nextSatPass(long _nextpassEpoch[20])
for (int i = 0; i < numSats; ++i)
if (_nextpassEpoch[0] - timeNow >= _nextpassEpoch[i] - timeNow)
_nextpassEpoch[0] = _nextpassEpoch[i];
nextSat = i;
return nextSat;
void initMotors()
// Setup stepper movements //
stepperEL.setMaxSpeed(1000);
stepperEL.setCurrentPosition(0); // Elevation stepper starts at -227 steps (20 degrees above horizon).
stepperEL.setAcceleration(100);
stepperAZ.setMaxSpeed(300);
stepperAZ.setCurrentPosition(0); // Azimuth stepper starts at 0.
stepperAZ.setAcceleration(100);
unsigned long startTime = millis();
unsigned long currentTime;
// Zero //
stepperAZ.runToNewPosition(-600);
while (true)
currentTime = millis();
if (currentTime - startTime > 40 * 1000)
Serial.print("Zeroing timed out");
while (true)
if (digitalRead(AZLimit) == LOW)
stepperAZ.runToNewPosition(-200);
if (stepperAZ.distanceToGo() == 0)
{ // if motor moved to the maximum position
stepperAZ.setCurrentPosition(0); // reset position to 0
stepperAZ.moveTo(2000); // move the motor to maximum position again
stepperAZ.run();
digitalWrite(AZmotorPin1, LOW);
digitalWrite(AZmotorPin2, LOW);
digitalWrite(AZmotorPin3, LOW);
digitalWrite(AZmotorPin4, LOW);
stepperEL.runToNewPosition(-100);
while (true)
Serial.println("Zeroing timed out");
while (true)
if (digitalRead(ELLimit) == LOW)
stepperEL.runToNewPosition(-80);
if (stepperEL.distanceToGo() == 0)
stepperEL.setCurrentPosition(0); // reset position to 0
stepperEL.moveTo(1000); // move the motor to maximum position again
stepperEL.run();
digitalWrite(ELmotorPin1, LOW);
digitalWrite(ELmotorPin2, LOW);
digitalWrite(ELmotorPin3, LOW);
digitalWrite(ELmotorPin4, LOW);
void clearLCD()
LCD.write(0xFE); // send the special command
LCD.write(0x01); // send the set cursor command
SerLCD lcd;
pinMode(ELLimit, INPUT_PULLUP); // init pins for limit switches
pinMode(AZLimit, INPUT_PULLUP);
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); // disable brownout detector
LCD.begin(9600, SERIAL_8N1, 20, 25); // Rx pin not used
lcd.begin(LCD);
// Connect to Wi-Fi network
clearLCD();
lcd.print("Connecting to WiFi...");
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED)
delay(2000);
Serial.println("Connecting to WiFi...");
Serial.println("Connected to WiFi!");
// Get Unix timestamp
clearLCD();
LCD.write("Fetching time...");
while (timeNow == 0)
configTime(0, 0, ntpServer);
timeNow = getTime();
Serial.println("unixtime: " + String(timeNow));
rtc.setTime(timeNow);
Serial.println("Zeroing");
clearLCD();
lcd.print("Zeroing...");
initMotors();
// Fetch TLE
clearLCD();
LCD.write("Fetching TLEs");
HTTPClient http;
sat.site(myLat, myLong, myAlt); // set location latitude[°], longitude[°] and altitude[m]
for (SAT = 0; SAT < numSats; SAT++)
Serial.println("Request #: " + String(SAT) + " For: " + String(satnames[SAT]));
http.begin("https://celestrak.org/" + String(satURL[SAT]));
int httpCode = http.GET();
String TLE;
if (httpCode == HTTP_CODE_OK)
TLE = http.getString();
TLE.substring(26, 96).toCharArray(TLE1[SAT], 70);
TLE.substring(97, 167).toCharArray(TLE2[SAT], 70);
Serial.println(TLE1[SAT]);
Serial.println(TLE2[SAT]);
sat.init(satname, TLE1[SAT], TLE2[SAT]); // initialize satellite parameters
upcomingPasses[SAT] = Predict(timeNow, minPassElevation); // find next pass and store it array
Serial.println("Failed to fetch TLE data for " + String(satnames[SAT]));
delay(100);
http.end();
nextSat = nextSatPass(upcomingPasses); // find earliest pass and track that sat
Serial.println("Next satellite: " + String(nextSat));
sat.init(satname, TLE1[nextSat], TLE2[nextSat]);
Predict(timeNow, 0.0);
String printHHmmss(unsigned long _secondsIn)
unsigned int _hour = floor(_secondsIn / 60 / 60);
unsigned int _minute = floor((_secondsIn / 60) % 60);
unsigned int _seconds = _secondsIn % 60;
char _DateAndTimeString[20]; // 19 digits plus the null char
sprintf(_DateAndTimeString, "%02d:%02d:%02d", _hour, _minute, _seconds);
return _DateAndTimeString;
timeNow = rtc.getEpoch();
sat.findsat(timeNow);
satAZsteps = -round(sat.satAz * oneTurn / 360); // Convert degrees to stepper steps
satELsteps = -round(sat.satEl * oneTurn / 360);
invjday(sat.satJd, timeZone, true, year, mon, day, hr, minute, sec);
Serial.println("\nLocal time: " + String(day) + '/' + String(mon) + '/' + String(year) + ' ' + String(hr) + ':' + String(minute) + ':' + String(sec));
Serial.println("azimuth = " + String(sat.satAz) + " elevation = " + String(sat.satEl) + " distance = " + String(sat.satDist));
Serial.println("latitude = " + String(sat.satLat) + " longitude = " + String(sat.satLon) + " altitude = " + String(sat.satAlt));
Serial.println("AZsteps = " + String(satAZsteps));
if (nextpassEpoch - timeNow < 300 && nextpassEpoch + 5 - timeNow > 0)
Serial.println("Status: Pre-pass");
Serial.println("Next satellite is #: " + String(satnames[nextSat]) + " in: " + String(nextpassEpoch - timeNow));
clearLCD();
lcd.print(satnames[nextSat]);
lcd.print(" " + printHHmmss(nextpassEpoch - timeNow));
lcd.setCursor(0, 1);
lcd.print("AZ:" + String(int(sat.satAz)) + " EL:" + String(int(sat.satEl)));
prepass();
else if (sat.satVis != -2)
Serial.println("Status: In pass");
clearLCD();
unsigned int timeToLOS = nextpassEndEpoch - timeNow;
unsigned int _minute = floor((timeToLOS / 60) % 60);
unsigned int _seconds = timeToLOS % 60;
char DateAndTimeString[20]; // 19 digits plus the null char
sprintf(DateAndTimeString, "%02d:%02d", _minute, _seconds);
lcd.print(" LOS");
lcd.print(DateAndTimeString);
inPass();
else if (timeNow - passEnd < 60)
Serial.println("Status: Post-pass");
clearLCD();
lcd.print("Post-pass:" + String(passEnd + 60 - timeNow));
postpass();
else if (sat.satVis == -2)
Serial.println("Status: Standby");
Serial.println("Next satellite is: " + String(satnames[nextSat]) + " in: " + String(nextpassEpoch - timeNow));
clearLCD();
standby();
void standby()
// Azimuth //
stepperAZ.runToNewPosition(0);
// ELEVATION //
stepperEL.runToNewPosition(-280); // Standby at 20 degrees above horizon
void prepass()
// Pass is less than 300 seconds (5 mins) away, move antenna to start location and wait.
if (AZstart < 360 && AZstart > 180)
AZstart = AZstart - 360; // Goes to start counter-clockwise if closer.
stepperAZ.runToNewPosition(-AZstart * oneTurn / 360);
stepperEL.runToNewPosition(0);
void inPass()
// Handle zero crossings
if (AZstart > 0)
satAZsteps = satAZsteps - oneTurn;
if (satAZsteps - stepperAZ.currentPosition() > 100)
stepperAZ.setCurrentPosition(stepperAZ.currentPosition() + oneTurn);
turns--;
if (satAZsteps - stepperAZ.currentPosition() < -100)
stepperAZ.setCurrentPosition(stepperAZ.currentPosition() - oneTurn);
turns++;
// Update stepper position
stepperAZ.runToNewPosition(satAZsteps);
stepperEL.runToNewPosition(satELsteps);
passEnd = timeNow;
passStatus = 1;
void postpass()
Serial.println("Post pass time left: " + String(passEnd + 60 - timeNow));
if (timeNow - passEnd > 30)
if (turns > 0)
turns--;
if (turns < 0)
turns++;
if (passStatus == 1 && timeNow - passEnd > 50)
upcomingPasses[SAT] = Predict(timeNow + 200, minPassElevation); // + 200 seconds so next pass is for sure not the one just ending.
Serial.println("Next pass for Satellite #: " + String(SAT) + " in: " + String(upcomingPasses[SAT] - timeNow));
passStatus = 0;
