Is esp32 not hardware? It is a normal 30 pins esp32 wroom. Nothing more.
I am working with different .ino
The main.ino is splitting the lan and wifi to core 0 and my program to core 1
In network.ino go to handler_wifi_mqtt(void* parameter) function and there you see the call to testEthernet() ( that I put in comment)
I addes a new if => “if (!0){ // false = Wifi of true = Lan” to simulate a testEthernet() wifi return. Then My programm with wifi is working perfectly
If I change the if to “if (!1){ // false = Wifi of true = Lan” to simulate a testEthernet() lan return. Then My programm with lan is working perfectly
Only if I let the function testEthernet() gifs the true/ false return, the wifi restarts.
main.ino:
// Als je de verkeerde Esp gebruikt geeft die een fout
#ifndef ESP32
#error "This code is designed for ESP32 architecture"
#endif
// INCLUDES
#include <WiFi.h>
// MQTT client, see https://github.com/knolleary/pubsubclient
#include <PubSubClient.h>
// JSON serialisation, see https://arduinojson.org/
#include <ArduinoJson.h>
#include <LittleFS.h>
#include <SPI.h>
#include <Ethernet.h>
// Ethernet mac address:
#include "esp_system.h"
#include "esp_mac.h"
// in de ethernet.h heb ik de timeout = 60000 veranderd naar timeout = 6000
// => static int begin(uint8_t *mac, unsigned long timeout = 6000, unsigned long responseTimeout = 4000);
// we moeten anders te lang wachten als we testEthernet() uitvoeren
// spel variablen en definities
#include "Speldeclaraties.h"
// wifi en mqtt instellingen voor verbinding met raspberry pi controller
#include "Wifi_Mqtt_basic.h"
LiquidCrystal_I2C lcdsetup(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
// display achteraan het spel
#define BildinLed 2 // led on esp32 board
#define networkpin 14 // voor netwerk aan => GPIO 14 to Vcc en uit => GPIO 14 to Gnd
bool einde = false; // eindresultaat gevonden
String I2Cadr = ""; // voor ScanI2C devices
bool I2C0x20 = false; // pcfout
bool I2C0x21 = false; // pcfin
bool I2C0x26 = false; // lcdGame
bool I2C0x27 = false; // lcdSetup
bool I2C0x40 = false; // servo board
bool I2C0x65 = false; // touch keypad
// Keep track of time of last wifi startup
unsigned long WifiTimeStamp;
#define __FILENAME__ (strrchr(__FILE__, '\\') ? strrchr(__FILE__, '\\') + 1 : __FILE__)
TaskHandle_t Task1;
// Setup
void setup(){
// Initialise serial connection
delay(100);
Serial.println("");
Serial.println(__FILE__);
Serial.println(__DATE__ " " __TIME__);
pinMode(BildinLed, OUTPUT); // interne led ON = geen wifi verbinding, OFF Wifi verbinding
pinMode(networkpin, INPUT_PULLUP); // network in/uit-schakelen met console werken
digitalWrite(BildinLed, true); // wifiled aan doen
state = Uit; // spel staat nog uit
Serial.print("Opstarten - state = "); Serial.println(state);
initLcdSetup(); // init Lcd display achteraan het spel
ScanI2C (); // scan aanwezigheid van I2C devices
// LcdSetup info tijdens opstart:
writeLcdSetup("filename: ",__FILENAME__);
writeLcdSetup("Versie: ", __DATE__);
if (I2C0x26){ // spel met lcdgame (gedetecteerd in ScanI2C)
Serial.println("init lcdgame ");
initlcdgame(); // init lcdgame display vooraan het spel
lcdgame.backlight();
lcdgame.setCursor(4, 0);
lcdgame.print("Opstart");
lcdsetup.clear();
// lees de networkpin value => netwerk en mqtt aan of uit
if(digitalRead(networkpin)){ // lezen netwerk schakelaar met/zonder console
networkOn = Wifi; // we kijken verder als het wifi of lan wordt
Serial.println ("wifi/lan : netwerk");
else {
networkOn = Geen;
Serial.print ("wifi/lan : ");
Serial.println(nettxt[networkOn] + " netwerk");
if(!readconfigFile()){ // de config file moet altijd gelezen worden,
// ook al hebben we die niet nodg om zonder console te spelen
// staat in escapeBasic.ino
while (true){ // geen file => blijf setup display schrijven
writeLcdSetup("Config file","niet te vinden"); // schrijf op lcdsetup => geen config file
writeLcdSetup("Spel kan niet", "gespeeld worden"); // schrijf op lcdsetup => spel kan niet gespeeld worden
if (networkOn){ // doe dit enkel als er wifi/Lan en mqtt nodig is
// FreeRTOS-taken starten
xTaskCreatePinnedToCore(
handler_wifi_mqtt, // Functie
"Task1", // Naam van de taak
10000, // Stapelgrootte
NULL, // Parameter
1, // Prioriteit
NULL, // Taakhandle
0 // Core 0
if (networkOn){ // werken met console? => wachten tot wifi/lan en mqtt verbonden zijn.
do{ //wacht tot wifi/lan en mqtt verbonden is
delay(1);
} while( networkState != Network_UP_MQTT_UP);
writeLcdSetup("game setup", "StartWaarden");
setupStartWaarden(); // set start met de vraag om alle knoppen op 0 te zetten
// loop
void loop(){
spellichtAanUit(); // zet spel led volgens state aan/uit
if (state > 1 ){ // spelen = state > 1 en niet spelen = state = 0 of 1 => Uit of Straf
if (!einde){ // resultaat nog niet gevonden
state = Running;
speelspel();
else {
if ( !networkOn){ // je mag spelen zonder console
state = Initialising;
einde = false;
writeLcdSetup(nettxt[networkOn] + " netwerk", "Spel staat aan",false); // schrijf lcdSetup dat spel aanligt zonder wifi
else{ // Je mag niet spelen => strafpunten ??
if (state < 2){ // spel is uit of straf
straftest(); // kijk of er nog gestraft is
wifi and ethernet variables:
// de wifi en mqtt gegevens staan in config.txt
char wifiSSID[32]; // SSID of the network to join
char wifiPassword[32]; // Wi-Fi password if required
char remoteMQTTServer[16]; // IP address of remote MQTT server Brewhouse
char remoteMQTTUser[16];
char remoteMQTTPass[16];
// GLOBALS Ethernet
byte mac[] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }; // 16/7: mac wordt opgehaald in ethernet.ino
#define ETHERNET_RESET_PIN 13 // ESP32 pin to reset pin from W5500 is niet meer in gebruik/ 16/7: verplaatst 15 naar 13
#define ETHERNET_CS_PIN 17 // ESP32 tx2 pin to CS pin from W5500 is connected
// GLOBALS Wifi/Lan en MQTT
WiFiClient wifiClient;
EthernetClient ethClient;
// MQTT client based on the chosen network
PubSubClient mqttClient;
// A re-usable buffer to hold MQTT messages to be sent/have been received
char mqttMsg[512];
// The MQTT topic in which to publish a message
char mqttTopic[32];
// Keep track of connection state of both WiFi and MQTT network
enum : byte { Network_DOWN_MQTT_DOWN, Network_STARTING_MQTT_DOWN, Network_UP_MQTT_DOWN, Network_UP_MQTT_STARTED, Network_UP_MQTT_UP } connectionState;
byte networkState = Network_DOWN_MQTT_DOWN;
// Track state of overall puzzle
enum State {Uit, Straf, SetToZero, Initialising, Running, Solved, Autosolve};
State state = Uit; // spel staat uit
// Track Net of type network
String nettxt[3] = {"Geen", "Wifi", "Lan"};
enum : byte {Geen, Wifi, Lan} net;
byte networkOn = Geen; // wifi/lan staat uit
network.ino
// init lcdsetup aan de achterkant
void initLcdSetup(){
Serial.println("initLcdSetup running");
lcdsetup.init(); // initialize the lcdsetup
lcdsetup.backlight();
lcdsetup.clear();
lcdsetup.setCursor(0, 0);
lcdsetup.print("Opstarten");
// Schrijf op lcd Setup display
void writeLcdSetup(String L1, String L2){ // writeLCDSetup zonder wacht definitie
writeLcdSetup( L1, L2, true); // er wordt automatisch 1 sec gewacht
void writeLcdSetup(String L1, String L2, bool wacht){ // writeLCDSetup met wacht definitie
lcdsetup.clear();
lcdsetup.print(L1);
lcdsetup.setCursor(0, 1);
lcdsetup.print(L2);
Serial.println("write LCD: " +L1+" "+L2);
if(wacht){
delay(500); // 16/7: aangepast van 1000 naar 500
// is er data van MQTT
void readMqtt(const JsonDocument& jsonDoc) {
// Act upon command received
// Serial.print("received Mqtt command: ");Serial.println(jsonDoc["command"]); // waarom werkt dit niet !!!
if(jsonDoc["command"] == "SOLVE") {
if (state != Uit){ // solved werkt enkel als de game aanligt
if (state != Solved ){ // werkt niet als die al opgelost is
state = Autosolve;
autosolve();
else if(jsonDoc["command"] == "RESET") {
writeLcdSetup("Console reset", "ontvangen",false); // schrijf schakel uit via console
setupStartWaarden(); // reset alle gegevens van het spel
writeLcdSetup(nettxt[networkOn] + " netwerk", "Spel staat UIT",false); // schrijf schakel uit via console
state = Uit; // spel uitgeschakeld
writeMqtt();
else if(jsonDoc["command"] == "AANUIT") {
if (state == Uit){
writeLcdSetup(nettxt[networkOn] + " netwerk", "Spel staat AAN",false); // schrijf spel klaar via console
state = Initialising; // start een nieuw spel
else {
setupStartWaarden(); // vraag om alle schakelaars eerst op zero te zetten
writeMqtt();
else if(jsonDoc["command"] == "AAN") {
if (state == Uit || state == Initialising){
// setupStartWaarden(); // set nieuwe start waarden
writeMqtt();
else if(jsonDoc["command"] == "UIT") {
writeMqtt();
writeLcdSetup(nettxt[networkOn] + " netwerk", "Spel staat UIT",false); // schrijf spel klaar via console
// * Mqtt and Wifi/Lan handler
void handler_wifi_mqtt(void* parameter){
//void handler_wifi_mqtt(){
// Callback when MQTT message received in topic to which we are subscribed
mqttClient.setCallback([](char* topic, byte* payload, unsigned int length) {
// Create a JSON document from the MQTT message received. Note best practice is NOT to have a reusable
// JSON document, but create a new one each time it is needed. https://arduinojson.org/v6/assistant/
StaticJsonDocument<128> jsonDoc;
deserializeJson(jsonDoc, payload, length);
// Process the contents of the update received
readMqtt(jsonDoc);
// if (!testEthernet()){ // false = Wifi of true = Lan
networkOn = Wifi;
WifiTimeStamp = millis(); // set time voor wifi connectie error
writeLcdSetup("Console setup", "met Wifi",false);
setWifiEvent();
else{
writeLcdSetup("Console setup", "via Lan",false);
networkOn = Lan;
// test loopen herstel wifi/lan en mqtt volgens de networkOn value
for (;;) { // loop forever
if (networkOn){ // mag er wifi en MQTT verbinding gemaakt worden
networkLoop();
vTaskDelay(100 / portTICK_PERIOD_MS);// is hetzelde als een delay van 100ms
// * A robust method that re-establishes connection to Wi-Fi LAN network and MQTT server,
// * in the event of dropped connection/power loss etc.
// * See https://esp32.com/viewtopic.php?t=16109#p61846
void networkLoop() {
switch (networkState) {
// If there is no Wi-Fi connection, in testEthernet there is a Lan connection if possible
case Network_DOWN_MQTT_DOWN:
digitalWrite(BildinLed, true); // wifiled aan doen, geen verbinding
if (networkOn == Wifi){
WifiDown();
networkState = Network_STARTING_MQTT_DOWN;
else {
EthernetDown();
networkState = Network_UP_MQTT_DOWN; // lan connected
// If the Wifi router connection was started
case Network_STARTING_MQTT_DOWN:
// Allow 15 seconds since attempting to join the WiFi
if (millis() - WifiTimeStamp >= 15000) {
// Otherwise, if the WLAN router connection was not established
Serial.println("Failed to start WiFi");
writeLcdSetup("Staat " + String(wifiSSID), "router aan ?",false); // schrijf geen router verbinding
delay(20000);
// Clear the connection for the next attempt
WiFi.disconnect();
// And reset the state machine to its initial state (restart)
// If the Wifi/LAN router connection was established
case Network_UP_MQTT_DOWN:
// And if no MQTT broker connection was established yet
digitalWrite(BildinLed, true); // led aan doen, geen verbinding
setupMqtt(remoteMQTTServer,1883,wifiClient); // voor wifi
else {
setupMqtt(remoteMQTTServer,1883,ethClient); // voor lan
if (!mqttClient.connected()) {
connectToMqtt();
networkState = Network_UP_MQTT_STARTED;
// If the MQTT broker connection was started
case Network_UP_MQTT_STARTED:
if(mqttClient.connected()) {
Serial.println("LAN and MQTT connected");
mqttClient.publish("ToHost", "Hi there");
// Subscribe to topics specifically for this device
snprintf(mqttTopic, 32, "ToDevice/%s", deviceID);
mqttClient.subscribe(mqttTopic);
// Subscribe to topics intended for ALL devices on network
mqttClient.subscribe("ToDevice/All");
// Advance the state machine
networkState = Network_UP_MQTT_UP;
else {
// If both the LAN router and MQTT broker connections were established
case Network_UP_MQTT_UP:
digitalWrite(BildinLed, false); // wifiled uit doen, er is een verbinding
mqttClient.loop();
else{
else { // voor lan
if (Ethernet.linkStatus() == LinkOFF){
Serial.println("ethernet not ok");
delay(2000);
ESP.restart(); // Ethernet not ok => restart esp
else {
mqttClient.loop();
else{
// * Read config file
bool readconfigFile() {
char * path;
String line;
int i;
Serial.println("Mounting config.txt");
if (!LittleFS.begin()) {
Serial.println("LittleFS mount failed");
return false;
// ****************** lees "/config.txt";
path = "/config.txt";
#ifdef DEBUG
Serial.printf("Reading file: %s\n", path);
#endif
File file = LittleFS.open(path, "r");
if (!file) {
#ifdef DEBUG
Serial.println(F("Failed to open file for reading"));
#endif
return false;
while(file.available()) {
line = file.readStringUntil('\n');
// Serial.println(line);
DynamicJsonDocument Doc(400);
DeserializationError error = deserializeJson(Doc, line);
if (error){
Serial.printf("Failed to read file : %s\n", path);
return false;
// als er compiler problemen zijn met Doc["naam"] naar een String var => ga naar de website
// https://arduinojson.org/v6/error/ambiguous-overload-for-operator-equal/
strcpy(wifiSSID, Doc["ssid"]);
strcpy(wifiPassword, Doc["pasw"]);
strcpy(remoteMQTTServer, Doc["mqttip"]);
strcpy(remoteMQTTUser, Doc["mqttuser"]);
strcpy(remoteMQTTPass, Doc["mqttpasw"]);
// Serial.println(wifiSSID);
// Serial.println(wifiPassword);
// Serial.println(remoteMQTTServer);
// Serial.println(remoteMQTTUser);
// Serial.println(remoteMQTTPass);
file.close();
return true;
// * scan all the i2c modules
void ScanI2C (){
// scan I2C address
byte error, address;
int nDevices;
Serial.println("Scanning...");
nDevices = 0;
for(address = 1; address < 127; address++ )
{ Wire.beginTransmission(address);
error = Wire.endTransmission();
if (error == 0)
{ Serial.print("I2C device found at address 0x");
if (address<16) Serial.print("0");
Serial.print(address,HEX);
Serial.println(" !");
String I2Cadr = "0x" + String(address,HEX);
// writeLcdSetup("I2C device ",I2Cadr);
if((address)==32) {Serial.println("PCF found on " + I2Cadr);I2C0x20 = true;}
if((address)==33) {Serial.println("PCF found on " + I2Cadr);I2C0x21 = true;}
if((address)==38) {Serial.println("LcdGame found on " + I2Cadr);I2C0x26 = true;}
if((address)==39) {Serial.println("LcdSetup found on " + I2Cadr);I2C0x27 = true;}
if((address)==64) {Serial.println("Servo board found on " + I2Cadr);I2C0x40 = true;}
if((address)==101){Serial.println("TouchKeypad found on " + I2Cadr);I2C0x65 = true;}
nDevices++;
delay(200);
// else if (error==4)
// { Serial.print("Unknown error at address 0x");
// if (address<16) Serial.print("0");
// Serial.println(address,HEX);
if (nDevices == 0) {Serial.println("No I2C devices found\n");
// writeLcdSetup("No I2C device"," ");
else Serial.println("done\n");
} // end of scan
ethernet.ino
// W5500 reset function // de reset wordt niet gebruikt
void ethernetReset(const uint8_t resetPin) {
// pinMode(resetPin, OUTPUT);
// digitalWrite(resetPin, HIGH);
// delay(250);
// digitalWrite(resetPin, LOW);
// delay(50);
// delay(350);
// W5500 test ethernet timeout is in de library set to 6000 en niet 60000
bool testEthernet() {
// w5500 ethernet verbinding maken
esp_read_mac(mac, ESP_MAC_ETH); // ethernet macadres ophalen
Ethernet.init(ETHERNET_CS_PIN);
ethernetReset(ETHERNET_RESET_PIN);
delay(100);
writeLcdSetup("Ethernet module", "testen",false);
if(Ethernet.begin(mac)){
return true;
// Ethernet.end();
return false;
// W5500 connect to ethernet
void EthernetDown() {
delay(100);
Ethernet.begin(mac, STATIC_IP);
// check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware){
writeLcdSetup("Ethernet module", "niet aangesloten",false); // schrijf lcd setup
delay(10000);
ESP.restart(); // w5500 niet aangesloten => restart esp
// check for Ethernet cable
writeLcdSetup("Ethernet kabel", "niet aangesloten",false); // schrijf lcd setup
delay(10000);
ESP.restart(); // Ethernet kabel niet aangesloten => restart esp
// W5500 instellen mqtt gegevens voor lan
void setupMqtt(const char* hostname, uint16_t port, Client& _connectionClient) {
mqttClient.setClient(_connectionClient);
mqttClient.setServer(hostname, port);
// W5500 verbinden van mqtt gegevens voor lan
void connectToMqtt() {
Serial.print(F("Starting MQTT connection to "));
Serial.print(remoteMQTTServer);
Serial.print(" with port: ");
Serial.println(1883);
// Start the connection
// mqttClient.setKeepAlive(5);
if (mqttClient.connect(deviceID, remoteMQTTUser, remoteMQTTPass)) {
else {
Serial.print(F("MQTT Failed. RC="));
Serial.print(mqttClient.state());
// Otherwise if the MQTT broker connection could not be established
Serial.println(" Retrying...");
writeLcdSetup("Geen MQTT", "Console aan ?",false); // schrijf lcd setup geen MQTT verbinding
delay(10000);
ESP.restart(); // het lukt niet om mqtt te starten => restart esp
wifi.ino
// Set Wifi event function
void setWifiEvent(){
// Examples of different ways to register wifi events
WiFi.onEvent(WiFiEvent);
WiFi.onEvent(WiFiGotIP, WiFiEvent_t::ARDUINO_EVENT_WIFI_STA_GOT_IP);
WiFiEventId_t eventID = WiFi.onEvent([](WiFiEvent_t event, WiFiEventInfo_t info){
Serial.print("WiFi lost connection. Reason: ");
Serial.println(info.wifi_sta_disconnected.reason);
}, WiFiEvent_t::ARDUINO_EVENT_WIFI_STA_DISCONNECTED);
// Wifi is down, start new connection function
void WifiDown(){
unsigned long testtijd;
WiFi.disconnect();
delay(100);
WiFi.mode(WIFI_STA); // Operate only in STA station mode (i.e. client), not also in AP access point mode (i.e. server)
WiFi.persistent(false); // Don't write Wi-Fi credentials to flash
Serial.print("Starting WiFi connection to ");
testtijd = (millis() - WifiTimeStamp)/1000; // hoe lang zoekt men al wifi
writeLcdSetup("Zoekt Wifi", "reeds "+ String(testtijd)+ " sec",false); // schrijf wifi connectie maken zonder wachten
if (!WiFi.config(STATIC_IP, GATEWAY, SUBNET)){
Serial.println("Setting static IP failed");
WiFi.begin(wifiSSID, wifiPassword);
// Wifi event function
void WiFiEvent(WiFiEvent_t event)
Serial.printf("[WiFi-event] event: %d\n", event);
switch (event) {
case ARDUINO_EVENT_WIFI_READY:
Serial.println("WiFi interface ready");
case ARDUINO_EVENT_WIFI_SCAN_DONE:
Serial.println("Completed scan for access points");
case ARDUINO_EVENT_WIFI_STA_START:
Serial.println("WiFi client started");
case ARDUINO_EVENT_WIFI_STA_STOP:
Serial.println("WiFi clients stopped");
case ARDUINO_EVENT_WIFI_STA_CONNECTED:
Serial.println("Connected to access point");
case ARDUINO_EVENT_WIFI_STA_DISCONNECTED:
WiFi.disconnect();
Serial.println("Disconnected from WiFi");
case ARDUINO_EVENT_WIFI_STA_AUTHMODE_CHANGE:
Serial.println("Authentication mode of access point has changed");
case ARDUINO_EVENT_WIFI_STA_GOT_IP:
Serial.print(F("Connected to "));
Serial.print(wifiSSID);
Serial.print(F(", IP:"));
case ARDUINO_EVENT_WIFI_STA_LOST_IP:
Serial.println("Lost IP address and IP address is reset to 0");
case ARDUINO_EVENT_WPS_ER_SUCCESS:
Serial.println("WiFi Protected Setup (WPS): succeeded in enrollee mode");
case ARDUINO_EVENT_WPS_ER_FAILED:
Serial.println("WiFi Protected Setup (WPS): failed in enrollee mode");
case ARDUINO_EVENT_WPS_ER_TIMEOUT:
Serial.println("WiFi Protected Setup (WPS): timeout in enrollee mode");
case ARDUINO_EVENT_WPS_ER_PIN:
Serial.println("WiFi Protected Setup (WPS): pin code in enrollee mode");
case ARDUINO_EVENT_WIFI_AP_START:
Serial.println("WiFi access point started");
case ARDUINO_EVENT_WIFI_AP_STOP:
Serial.println("WiFi access point stopped");
case ARDUINO_EVENT_WIFI_AP_STACONNECTED:
Serial.println("Client connected");
case ARDUINO_EVENT_WIFI_AP_STADISCONNECTED:
Serial.println("Client disconnected");
case ARDUINO_EVENT_WIFI_AP_STAIPASSIGNED:
Serial.println("Assigned IP address to client");
case ARDUINO_EVENT_WIFI_AP_PROBEREQRECVED:
Serial.println("Received probe request");
case ARDUINO_EVENT_WIFI_AP_GOT_IP6:
Serial.println("AP IPv6 is preferred");
case ARDUINO_EVENT_WIFI_STA_GOT_IP6:
Serial.println("STA IPv6 is preferred");
case ARDUINO_EVENT_ETH_GOT_IP6:
Serial.println("Ethernet IPv6 is preferred");
case ARDUINO_EVENT_ETH_START:
Serial.println("Ethernet started");
case ARDUINO_EVENT_ETH_STOP:
Serial.println("Ethernet stopped");
case ARDUINO_EVENT_ETH_CONNECTED:
Serial.println("Ethernet connected");
case ARDUINO_EVENT_ETH_DISCONNECTED:
Serial.println("Ethernet disconnected");
case ARDUINO_EVENT_ETH_GOT_IP:
Serial.println("Obtained IP address");
default: break;
void WiFiGotIP(WiFiEvent_t event, WiFiEventInfo_t info)
Serial.println("WiFi connected");
Serial.print("IP address: ");
Serial.println(IPAddress(info.got_ip.ip_info.ip.addr));
