Hello. It is this page (https://lastminuteengineers.com/esp32-sleep-modes-power-consumption/) I am seeing everything that the ESP32 consumes. It says that without WIFI it consumes 20mA and with Wifi it consumes more than 160mA. My question is: how to turn off Wifi when I'm not connected to it and how to turn it on only when I'm connected?
My code is the following (it works perfectly, with the problem that it sends data even when it is not connected to anything, and that is a waste of energy):
#include <BLEDevice.h>
#include <BLEServer.h>
#include <BLEUtils.h>
#include <BLE2902.h>
BLEServer *pServer = NULL;
BLECharacteristic *pCharacteristic;
bool deviceConnected = false;
bool oldDeviceConnected = false;
float data_0;
int data_1;
int battery;
const int LED = 2;
float txValue = 0;
const int readPin = 32; // Use GPIO number. See ESP32 board pinouts
// See the following for generating UUIDs:
// https://www.uuidgenerator.net/
#define SERVICE_UUID "4fafc201-1fb5-459e-8fcc-c5c9c331914b"
#define CHARACTERISTIC_UUID_TX "beb5483e-36e1-4688-b7f5-ea07361b26a8"
#define CHARACTERISTIC_UUID_RX "6E400002-B5A3-F393-E0A9-E50E24DCCA9E"
class MyServerCallbacks: public BLEServerCallbacks {
void onConnect(BLEServer* pServer) {
deviceConnected = true;
BLEDevice::startAdvertising();
void onDisconnect(BLEServer* pServer) {
class MyCallbacks: public BLECharacteristicCallbacks {
void onWrite(BLECharacteristic *pCharacteristic) {
std::string rxValue = pCharacteristic->getValue();
if (rxValue.length() > 0) {
Serial.println("*********");
Serial.print("Received Value: ");
for (int i = 0; i < rxValue.length(); i++) {
Serial.print(rxValue[i]);
// Do stuff based on the command received from the app
if (rxValue.find("0") != -1) {
Serial.println("Turning ON!");
digitalWrite(LED, HIGH);
else if (rxValue.find("1") != -1) {
Serial.println("Turning OFF!");
digitalWrite(LED, LOW);
void checkToReconnect() //added
// disconnected so advertise
if (!deviceConnected && oldDeviceConnected) {
delay(500); // give the bluetooth stack the chance to get things ready
pServer->startAdvertising(); // restart advertising
Serial.println("Disconnected: start advertising");
oldDeviceConnected = deviceConnected;
// connected so reset boolean control
if (deviceConnected && !oldDeviceConnected) {
// do stuff here on connecting
Serial.println("Reconnected");
pinMode(LED, OUTPUT);
// Create the BLE Device
BLEDevice::init("Adam");
// Create the BLE Server
BLEServer *pServer = BLEDevice::createServer();
pServer->setCallbacks(new MyServerCallbacks());
// Create the BLE Service
BLEService *pService = pServer->createService(SERVICE_UUID);
// Create a BLE Characteristic
pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_TX,
BLECharacteristic::PROPERTY_NOTIFY
// https://www.bluetooth.com/specifications/gatt/viewer?attributeXmlFile=org.bluetooth.descriptor.gatt.client_characteristic_configuration.xml
// Create a BLE Descriptor
pCharacteristic->addDescriptor(new BLE2902());
BLECharacteristic *pCharacteristic = pService->createCharacteristic(
CHARACTERISTIC_UUID_RX,
BLECharacteristic::PROPERTY_WRITE
pCharacteristic->setCallbacks(new MyCallbacks());
// Start the service
pService->start();
// Start advertising
pServer->getAdvertising()->start();
Serial.println("Waiting a client connection to notify...");
checkToReconnect();
// notify changed value
if (deviceConnected) {
txValue = analogRead(readPin) / 3.456; // This could be an actual sensor reading!
//convert float txvalue to string
char data_0[8]; // make sure this is big enuffz
dtostrf(txValue, 1, 2, data_0);
data_1 = 1;
battery = 49;
String str = "";
str += data_0;
str += ",";
str += data_1;
str += ",";
str += battery;
pCharacteristic->setValue((char*)str.c_str());
pCharacteristic->notify();
Serial.println("*** Sent Value: ");
Serial.println(data_0);
Serial.println(data_1);
Serial.println(battery);
Serial.println(" ***");
// bluetooth stack will go into congestion, if too many packets are sent, in 6 hours test i was able to go as low as 3ms
