ESP32 UDP read data
Hi, I'm an old programmer from the 80's Fortran / Cobol been playing around with Nano’s and uno’s and made a few project
I am trying to change my project from using 2 Nano's and RF24's to using 2 ESP32's for the communication, but for 3 weeks now I am struggling to get the data returned from the example UDP sketch into a variable.
I’m sending the word "Heartbeat" every 60 seconds from a PIR connected to an esp32, and the word “Intruder” on detection of movement (using the esp32 UDP client example modified).
My receiving esp32
I’ve modified the UDP server example,
It does return the 2 words as expected and display’s them on the serial monitor.
This line works are expected
Serial.write(packet.data(), packet.length()); // this displays the value!
I now want to check for the word "Intruder" and activate an alarm.
or the word "Heartbeat" and flash an LED
But every way I try to get the result returned into a variable fails.
And I dont understand a lot of the internet explanations of the errors I am receiving..
received == (packet.data(), packet.length()); // this fails
if ((packet.data()) == "Heartbeat") { // it doesn’t like this either
how do I get the packet.data() into a variable please?
#include <analogWrite.h>
#include "WiFi.h"
#include "AsyncUDP.h"
#include <ESP32Tone.h>
const char * ssid = "Paul2";
const char * password = "abcdeabcde";
String header;
const int buzzer = 4;
const int GarR = 2;
const int GarG = 5;
char received[50] = "";
char test[100];
AsyncUDP udp;
IPAddress local_IP(192, 168, 0, 32);
IPAddress gateway(192, 168, 0, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8); //optional
IPAddress secondaryDNS(8, 8, 4, 4); //optional
pinMode(buzzer, OUTPUT);
pinMode(GarR, OUTPUT);
pinMode(GarG, OUTPUT);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
Serial.println("STA Failed to configure");
    Serial.println(received);
if (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("WiFi Failed");
while(1) {
if(udp.listen(1234)) {
Serial.print("UDP Listening on IP: ");
udp.onPacket([](AsyncUDPPacket packet) {
Serial.print("UDP Packet Type: ");
Serial.print(packet.isBroadcast()?"Broadcast":packet.isMulticast()?"Multicast":"Unicast");
Serial.print(", From: ");
Serial.print(packet.remoteIP());
Serial.print(":");
Serial.print(packet.remotePort());
Serial.print(", To: ");
Serial.print(packet.localIP());
Serial.print(":");
Serial.print(packet.localPort());
Serial.print(", Length: ");
Serial.print(packet.length());
Serial.print(", Data: ");
// received == (packet.data()); doesnt like this laks cast ? i dont understand the explanation
// received == (packet.data(), packet.length()); forbids compariton between pointer and intiger mmmm
//received == ((packet.data()); packet not declared in this scope
// if ((packet.data()) == "Heartbeat") packet not declared in this scope
// Serial.println("Heartbeat returned");
    Serial.println("in loop");
    //Serial.println(test);
received = packet.data();
Oh, could you edit your post and enclose your code in code tags. Please?
Sorry I'm new on here , cannot find an edit option, just read how to ad tags, so let me try again.
will this work !
#include "WiFi.h"
String header;
const int GarR = 2;
const int GarG = 5;
char test[100];
AsyncUDP udp;
        while(1) {
            Serial.print(":");
            Serial.print(":");
Hi Thanks for replying, I tried this but it complaint that it laks cast, and I was totally overwhelmed by the explanations when I googled it, Whoosh way over my head lol
It would be much better if I could read those error messages. You can copy and paste those error messages into a post.
Arduino: 1.8.13 (Windows 10), Board: "ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 240MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 921600, None"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\puter\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\puter\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\puter\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10813 -build-path C:\Users\puter\AppData\Local\Temp\arduino_build_51520 -warnings=none -build-cache C:\Users\puter\AppData\Local\Temp\arduino_cache_90732 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\puter\Documents\Arduino\PaulUDPServer\PaulUDPserver\PaulUDPserver.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\puter\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\puter\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\puter\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32:PSRAM=disabled,PartitionScheme=default,CPUFreq=240,FlashMode=qio,FlashFreq=80,FlashSize=4M,UploadSpeed=921600,DebugLevel=none -vid-pid=10C4_EA60 -ide-version=10813 -build-path C:\Users\puter\AppData\Local\Temp\arduino_build_51520 -warnings=none -build-cache C:\Users\puter\AppData\Local\Temp\arduino_cache_90732 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.esptool_py.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\puter\Documents\Arduino\PaulUDPServer\PaulUDPserver\PaulUDPserver.ino
Using board 'esp32' from platform in folder: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
Using core 'esp32' from platform in folder: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6
cmd /c if exist "C:\Users\puter\Documents\Arduino\PaulUDPServer\PaulUDPserver\partitions.csv" copy /y "C:\Users\puter\Documents\Arduino\PaulUDPServer\PaulUDPserver\partitions.csv" "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\partitions.csv"
cmd /c if not exist "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\partitions.csv" copy "C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\tools\partitions\default.csv" "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\partitions.csv"
Detecting libraries used...
"C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\sketch\PaulUDPserver.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for analogWrite.h: [ESP32Servo-master@0.9.0]
ResolveLibrary(analogWrite.h)
-> candidates: [ESP32Servo-master@0.9.0]
"C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src" "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\sketch\PaulUDPserver.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for WiFi.h: [WiFi@1.2.7 WiFi@1.0]
ResolveLibrary(WiFi.h)
-> candidates: [WiFi@1.2.7 WiFi@1.0]
"C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src" "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\sketch\PaulUDPserver.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for AsyncUDP.h: [AsyncUDP@1.0.0]
ResolveLibrary(AsyncUDP.h)
-> candidates: [AsyncUDP@1.0.0]
"C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\AsyncUDP\src" "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\sketch\PaulUDPserver.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: C:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src\ESP32PWM.cpp
Using cached library dependencies for file: C:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src\ESP32Servo.cpp
Using cached library dependencies for file: C:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src\ESP32Tone.cpp
Using cached library dependencies for file: C:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src\analogWrite.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\ETH.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFi.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiAP.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiClient.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiGeneric.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiMulti.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiSTA.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiScan.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiServer.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src\WiFiUdp.cpp
Using cached library dependencies for file: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\AsyncUDP\src\AsyncUDP.cpp
Generating function prototypes...
"C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -c -w -x c++ -E -CC -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\AsyncUDP\src" "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\sketch\PaulUDPserver.ino.cpp" -o "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\preproc\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\puter\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0/bin/xtensa-esp32-elf-g++" -DESP_PLATFORM "-DMBEDTLS_CONFIG_FILE="mbedtls/esp_config.h"" -DHAVE_CONFIG_H -DGCC_NOT_5_2_0=0 -DWITH_POSIX "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/config" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_trace" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/app_update" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/asio" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bootloader_support" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/bt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/coap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/console" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/driver" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/efuse" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-tls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_adc_cal" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_event" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_http_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_ota" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_https_server" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_ringbuf" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp_websocket_client" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/espcoredump" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ethernet" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/expat" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fatfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freemodbus" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/freertos" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/heap" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/idf_test" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/jsmn" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/json" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/libsodium" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/log" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/lwip" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mbedtls" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mdns" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/micro-ecc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/mqtt" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/newlib" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nghttp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/nvs_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/openssl" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protobuf-c" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/protocomm" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/pthread" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/sdmmc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/smartconfig_ack" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/soc" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spi_flash" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/spiffs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcp_transport" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/tcpip_adapter" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/ulp" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/unity" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/vfs" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wear_levelling" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wifi_provisioning" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/wpa_supplicant" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/xtensa-debug-module" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp32-camera" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/esp-face" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6/tools/sdk/include/fb_gfx" -std=gnu++11 -Os -g3 -Wpointer-arith -fexceptions -fstack-protector -ffunction-sections -fdata-sections -fstrict-volatile-bitfields -mlongcalls -nostdlib -w -Wno-error=maybe-uninitialized -Wno-error=unused-function -Wno-error=unused-but-set-variable -Wno-error=unused-variable -Wno-error=deprecated-declarations -Wno-unused-parameter -Wno-unused-but-set-parameter -Wno-missing-field-initializers -Wno-sign-compare -fno-rtti -MMD -c -DF_CPU=240000000L -DARDUINO=10813 -DARDUINO_ESP32_DEV -DARDUINO_ARCH_ESP32 "-DARDUINO_BOARD="ESP32_DEV"" "-DARDUINO_VARIANT="esp32"" -DESP32 -DCORE_DEBUG_LEVEL=0 "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\variants\esp32" "-IC:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master\src" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi\src" "-IC:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\AsyncUDP\src" "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\sketch\PaulUDPserver.ino.cpp" -o "C:\Users\puter\AppData\Local\Temp\arduino_build_51520\sketch\PaulUDPserver.ino.cpp.o"
C:\Users\puter\Documents\Arduino\PaulUDPServer\PaulUDPserver\PaulUDPserver.ino: In lambda function:
PaulUDPserver:74:40: error: comparison between distinct pointer types 'char*' and 'uint8_t* {aka unsigned char*}' lacks a cast [-fpermissive]
          received == (packet.data());   //doesnt like this laks cast ? i dont understand the explanation
Multiple libraries were found for "WiFi.h"
Used: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
Using library ESP32Servo-master at version 0.9.0 in folder: C:\Users\puter\Documents\Arduino\libraries\ESP32Servo-master
Using library WiFi at version 1.0 in folder: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
Using library AsyncUDP at version 1.0.0 in folder: C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\AsyncUDP
exit status 1
I turned on verbose ... would you like the short version ...lol thats a lot of report..
The short version of the error.
It also complains about the multiple versions of wifi.h.. but i've read that this can be ignored
it only shows with other errors.
If i remove the line received == (packet.data()); it compiles with no errors.
Thank you
paul
exit status 1
option enabled in File -> Preferences.
The received data is an array of unit8_t's. If you want to recast the data this might work "String srogopdf = String(packet.data()); "
I dont fully understand , but I copied and paste this in, and it errors with ..
no matching function for call to 'String(uint8_t*)'
do i need to define sprogopdf somewhere maybe?
PaulUDPserver:73:51: error: no matching function for call to 'String(uint8_t*)'
In file included from C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/Arduino.h:146:0,
             from sketch\PaulUDPserver.ino.cpp:1:
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:69:18: note: candidate: String::String(long unsigned int, unsigned char)
     explicit String(unsigned long, unsigned char base = 10);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:69:18: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'long unsigned int' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:68:18: note: candidate: String::String(long int, unsigned char)
     explicit String(long, unsigned char base = 10);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:68:18: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'long int' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:67:18: note: candidate: String::String(unsigned int, unsigned char)
     explicit String(unsigned int, unsigned char base = 10);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:67:18: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'unsigned int' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:66:18: note: candidate: String::String(int, unsigned char)
     explicit String(int, unsigned char base = 10);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:66:18: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'int' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:65:18: note: candidate: String::String(unsigned char, unsigned char)
     explicit String(unsigned char, unsigned char base = 10);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:65:18: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'unsigned char' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:64:18: note: candidate: String::String(char)
     explicit String(char c);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:64:18: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'char' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:62:9: note: candidate: String::String(StringSumHelper&&)
     String(StringSumHelper &&rval);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:62:9: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:51: error: conversion from 'uint8_t* {aka unsigned char*}' to 'StringSumHelper' is ambiguous
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:358:9: note: candidate: StringSumHelper::StringSumHelper(long unsigned int)
     StringSumHelper(unsigned long num) :
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:358:9: note: conversion of argument 1 would be ill-formed:
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:355:9: note: candidate: StringSumHelper::StringSumHelper(long int)
     StringSumHelper(long num) :
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:355:9: note: conversion of argument 1 would be ill-formed:
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:352:9: note: candidate: StringSumHelper::StringSumHelper(unsigned int)
     StringSumHelper(unsigned int num) :
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:352:9: note: conversion of argument 1 would be ill-formed:
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:349:9: note: candidate: StringSumHelper::StringSumHelper(int)
     StringSumHelper(int num) :
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:349:9: note: conversion of argument 1 would be ill-formed:
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:346:9: note: candidate: StringSumHelper::StringSumHelper(unsigned char)
     StringSumHelper(unsigned char num) :
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:346:9: note: conversion of argument 1 would be ill-formed:
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:343:9: note: candidate: StringSumHelper::StringSumHelper(char)
     StringSumHelper(char c) :
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:343:9: note: conversion of argument 1 would be ill-formed:
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:340:9: note: candidate: StringSumHelper::StringSumHelper(const char*)
     StringSumHelper(const char *p) :
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:340:9: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid conversion from 'uint8_t* {aka unsigned char*}' to 'const char*' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:61:9: note: candidate: String::String(String&&)
     String(String &&rval);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:61:9: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid user-defined conversion from 'uint8_t* {aka unsigned char*}' to 'String&&' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:57:9: note: candidate is: String::String(const char*)
     String(const char *cstr = "");
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:57:9: note: conversion of argument 1 would be ill-formed:
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:57:9: note: initializing argument 1 of 'String::String(const char*)'
PaulUDPserver:73:51: error: conversion to non-const reference type 'class String&&' from rvalue of type 'String' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:58:9: note: candidate: String::String(const String&)
     String(const String &str);
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:58:9: note: conversion of argument 1 would be ill-formed:
PaulUDPserver:73:49: error: invalid user-defined conversion from 'uint8_t* {aka unsigned char*}' to 'const String&' [-fpermissive]
C:\Users\puter\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\cores\esp32/WString.h:57:9: note: candidate: String::String(const char*)
exit status 1
cool. search the internet for "convert uint8_t to string"
Thank you !
I found
He got a bit slated for using the string command lol.
But i translated it to be
received = (char*)(packet.data());
And this seems to work fine, as am only using a short bit of code and short strings this should be fine for my use.
I will play around with it a bit more tomorrow after work.But it seems to be working like this.
Your a star !
Thank you very much for your support..
Greatly appreciated..
Paul
I'd be highly suspect of that "solution". From AsyncUDP.cpp:
uint8_t * AsyncUDPPacket::data()
    return _data;
So, the returned pointer points to an array of uint8_t. But, since a UDP packet doesn't have to contain ASCII, the array won't be null-terminated. That's why you need the length() function. So, the String object you generate will probably contain garbage characters past the end of the array up to the first null. You're flirting with a memory problem.
I'd do something like the following. It compiles but is untested. Also, for brevity, I left out all the stuff that's not necessary to demonstrate the technique ... WiFi connection, etc.
#include "Arduino.h"
#include "AsyncUDP.h"
AsyncUDP udp;
void processPacket(AsyncUDPPacket &packet);
bool comparePacketString(AsyncUDPPacket &packet, const char *str);
const uint16_t udpPort = 1234;
  if (udp.listen(udpPort)) {
    udp.onPacket(processPacket);
    Serial.println("Failed to initiate UDP Packet Listening");
void processPacket(AsyncUDPPacket &packet) {
  if (comparePacketString(packet, "Intruder")) {
    Serial.println("Intruder");
  } else if (comparePacketString(packet, "Heartbeat")) {
    Serial.println("Heartbeat");
bool comparePacketString(AsyncUDPPacket &packet, const char *str) {
  size_t len = strlen(str);
  if (packet.length() < len) {
    return false;
  if (memcmp(str, packet.data(), len) == 0) {
    return true;
  return false;
But, this whole topic begs the question … why are you bothering to send a multi-byte ASCII string just to convey so little information. Why don't you encode the state into a single-byte value and send just that? For example, "Heartbeat" = 1 and "Intruder" = 2.
ooo that code looks much slimmed down, I think I get the gist of whats happening though, you have gone a bit techno lol..
Your example looks like what I needed when I started the project rather than the sample I modified..
looking at the way I had it, i hit a problem that I hadn't anticipated, reading the packet.data() always returned Heartbeat when checked.
It persists. I originally wrote this with RF24 and Arduino nano.
I used words rather than 0,1 mainly as I am a noobe and this made my code a bit easier reading, as i had a transmitter in my garage and on 3 different garden gates around the bungalow.
But the garage is detached around the back and I sleep in the front and the range was struggling despite upgrading the aerials.
I had a play the other week with an esp8266 and a webhook, and got it working to notify my mobile when the laser stopped at work.
Next i decided to replace my little home alarm with esp32, but all the video examples used a server running html on a esp32 server unit, which I couldn't get my head round how to make a esp32 talk to another esp32.. all the other TCP project examples seem to connect direct from esp32 to esp32 which gave me the same range problems.. then I fount the UDP master and slave examples, and I thought I understood enough of those to achieve, until i hit a block with this packet.data()..
There is a lot in the code I showed you that I will eventually trim out, like the lines printing the ip addresses, as I've started with an example, I am not sure to start whats safe for me to remove lol
This language is a huge learning curve from the days of basic and cobol, I've spent many hours but still feel i haven't learned much of the basics.
Any how thank you again, I hope fully will get an hour or two this evening to give this a try .
Paul
Thank you for that bit of magic code.
I don't fully understand it but I sort of get the gist of it, enough to play around and get it to do what I want.Thank you for your help with this.
Paul
#include "WiFi.h"
#include <ESP32Tone.h>
const char * ssid = "Paul2";
const char * password = "abcdeabcde";
const int buzzer = 4;
const int GarR = 2;  // garage Red LED  (RGB LED's)
const int GarG = 5;  // garage Green LED
const int GatR = 18;  // Gate Red LED
const int GatG = 19;  // Gate Green LED
AsyncUDP udp;
IPAddress local_IP(192, 168, 0, 32);
IPAddress gateway(192, 168, 0, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8);   //optional
IPAddress secondaryDNS(8, 8, 4, 4); //optional
  pinMode(buzzer, OUTPUT);
  pinMode(GarR, OUTPUT);
  pinMode(GarG, OUTPUT);
  pinMode(GatR, OUTPUT);
  pinMode(GatG, OUTPUT);
    WiFi.mode(WIFI_STA);
    WiFi.begin(ssid, password);
    if (!WiFi.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS)) {
    Serial.println("STA Failed to configure");
//        if(udp.listen(1234)) {
//        Serial.print("UDP Listening on IP: ");
//        Serial.println(WiFi.localIP());
    if (comparePacketString(packet, "GarageDetect")) {
      Serial.println("GarageDetect");
        digitalWrite(GarR,HIGH);
          delay(100);
          digitalWrite(GarR,LOW);
          tone(buzzer, 3000,  300);
  } else if (comparePacketString(packet, "GarageLive")) {
      Serial.println("GarageLive");
        digitalWrite(GarG,HIGH);
          delay(100);
          digitalWrite(GarG,LOW);
    if (comparePacketString(packet, "GateDetect")) {
      Serial.println("GateDetect");
        digitalWrite(GatR,HIGH);
          delay(100);
          digitalWrite(GatR,LOW);
  } else if (comparePacketString(packet, "GateLive")) {
      Serial.println("GateLive");
        digitalWrite(GatG,HIGH);
          delay(100);
          digitalWrite(GatG,LOW);
    return false;
    return true;
  return false;
I am still puzzled how this all continues to work despite no code in the loop section.. but it works, thank you .
