ESP32 - Wifi and ESP-NOW
I have a problem that I would like help with.
I have been stuck on this for over a week and I can't seem to solve it. I have two ESP32 components, one a transmitter and the other a receiver. Each is connected to a separate breadboard.
The reciver ESP32 is placed on a breadboard along with additional components, including a buzzer, an LED, and a servo motor, and the transmitter ESP32 with buttons and LED. When the RSSI value between the receiver and the transmitter reaches a certain threshold (e.g., -50 dBm), the LED, buzzer, and servo motor on the reciver breadboard will be activated.
The system status will be controlled using physical buttons located on the transmitter’s breadboard and using the app, In addition, the RSSI value will appear in the app and in the serial monitor.
My problem:
I want the default behavior to be ESP-NOW mode when the ESP32 is not connected to a hotspot. Once the ESP32 connects to a hotspot, it should switch to using WIFI for RSSI calculations. When the device disconnects from the hotspot, it should revert back to
ESP-NOW mode for RSSI calculations.
Currently what is happening is that I am able to control the system using the buttons when I am disconnected from WIFI and I am able to control the system using the app when I am connected to WIFI. However, for RSSI the situation is different. When I am connected to the app I get correct RSSI values ​​but when I disconnect from WIFI I get completely incorrect RSSI values. I would really appreciate help.
:Transmitter
#define BLYNK_TEMPLATE_ID "--"
#define BLYNK_TEMPLATE_NAME "--"
#define BLYNK_AUTH_TOKEN "---"
#include <esp_now.h>
#include <WiFi.h>
#include <BlynkSimpleEsp32.h>
// WiFi Credentials
char ssid[] = "--";
char pass[] = "--";
// ESP-NOW Receiver MAC Address
const uint8_t receiverMacAddress[] = {0x20, 0x43, 0xA8, 0x63, 0x35, 0xA8};
// Hardware Pins
#define BUTTON1_PIN 15
#define BUTTON2_PIN 23
#define LED1_PIN 4
#define LED2_PIN 19
// RSSI Settings
#define WINDOW_SIZE 7
#define RSSI_TIMEOUT 2000   // ms
#define CONTROL_SEND_INTERVAL 30 // ms
#define RSSI_SEND_INTERVAL 100 // ms
// Kalman Filter Parameters
const float Q = 0.01;  // Process noise
const float R = 2.0;   // Measurement noise
struct PacketData {
  byte activeButton;
struct PacketData2 {
  int rssiValue;
// Global Variables
float kalmanRSSI = -70; // Initial reasonable value
float kalmanP = 1;
int latestRSSI = -70;
unsigned long lastPacketTime = 0;
bool rssiTimeout = false;
PacketData data;
PacketData2 data2;
bool lastButton1State = false;
bool lastButton2State = false;
bool button1Active = false;
bool button2Active = false;
bool blynkConnected = false;
unsigned long lastBlynkUpdate = 0;
bool wifiConnected = false;
// Moving Average Filter
float applyMovingAverage(float newValue) {
    static float buffer[WINDOW_SIZE] = {0};
    static byte index = 0;
    static float sum = 0;
    sum -= buffer[index];
    buffer[index] = newValue;
    sum += buffer[index];
    index = (index + 1) % WINDOW_SIZE;
    return sum / WINDOW_SIZE;
// Improved Kalman Filter with timeout handling
float kalmanUpdate(float measurement) {
    // Check for timeout
    if(millis() - lastPacketTime > RSSI_TIMEOUT) {
        rssiTimeout = true;
        return kalmanRSSI; // Return last good value
    // Validate measurement (-100dBm to 0dBm)
    if(measurement > 0 || measurement < -100) return kalmanRSSI;
    kalmanP = kalmanP + Q;
    float K = kalmanP / (kalmanP + R);
    kalmanRSSI = kalmanRSSI + K * (measurement - kalmanRSSI);
    kalmanP = (1 - K) * kalmanP;
    return constrain(kalmanRSSI, -100, 0);
void OnDataRecv(const esp_now_recv_info_t *info, const uint8_t *incomingData, int len) {
    // Get RSSI from ESP-NOW packet metadata
    latestRSSI = info->rx_ctrl->rssi;
    lastPacketTime = millis();
    // Apply processing chain
    float smoothed = applyMovingAverage(latestRSSI);
    kalmanRSSI = kalmanUpdate(smoothed);
    // Send to Blynk if connected
    if(blynkConnected && millis() - lastBlynkUpdate >= 500) {
        lastBlynkUpdate = millis();
        Blynk.virtualWrite(V1, kalmanRSSI);
    // Debug output
    Serial.printf("RSSI: %.2f dBm\n", kalmanRSSI);
BLYNK_CONNECTED() {
    blynkConnected = true;
    Blynk.syncVirtual(V0);
    Blynk.virtualWrite(V0, button1Active ? 1 : 0);
BLYNK_DISCONNECTED() {
BLYNK_WRITE(V0) {
    int buttonState = param.asInt();
    if(buttonState == 1 && !button1Active) {
        button1Active = true;
        data.activeButton = 1;
        digitalWrite(LED1_PIN, HIGH);
        digitalWrite(LED2_PIN, LOW);
        Serial.println("🔴 System ON (from Blynk)");
    else if(buttonState == 0 && !button2Active) {
        button2Active = true;
        data.activeButton = 2;
        digitalWrite(LED1_PIN, LOW);
        digitalWrite(LED2_PIN, HIGH);
        Serial.println("🟢 System OFF (from Blynk)");
void maintainWiFiConnection() {
    static unsigned long lastCheck = 0;
    if(millis() - lastCheck >= 10000) { // Check every 10 seconds
        lastCheck = millis();
        if(WiFi.status() != WL_CONNECTED) {
            WiFi.disconnect();
            WiFi.begin(ssid, pass);
        } else if(!wifiConnected) {
            wifiConnected = true;
            Serial.println("WiFi reconnected");
    // Initialize hardware
    pinMode(BUTTON1_PIN, INPUT_PULLUP);
    pinMode(BUTTON2_PIN, INPUT_PULLUP);
    pinMode(LED1_PIN, OUTPUT);
    pinMode(LED2_PIN, OUTPUT);
    // Start WiFi in STA mode only
    WiFi.mode(WIFI_STA);
    Serial.println("Connecting to WiFi...");
    // Initialize ESP-NOW
    if(esp_now_init() != ESP_OK) {
        Serial.println("ESP-NOW Init Failed");
        ESP.restart();
    esp_now_peer_info_t peerInfo;
    memset(&peerInfo, 0, sizeof(peerInfo));
    memcpy(peerInfo.peer_addr, receiverMacAddress, 6);
    peerInfo.channel = 0;
    peerInfo.encrypt = false;
    if(esp_now_add_peer(&peerInfo) != ESP_OK) {
        Serial.println("Failed to add peer");
        ESP.restart();
    esp_now_register_recv_cb(OnDataRecv);
    // Initialize Blynk with separate connection handling
    Blynk.config(BLYNK_AUTH_TOKEN);
    Blynk.connect(1000); // Shorter timeout
    blynkConnected = Blynk.connected();
    Serial.println("System Ready");
    // Handle Blynk connection separately
    static unsigned long lastBlynkReconnect = 0;
    if(!blynkConnected && millis() - lastBlynkReconnect > 5000) {
        lastBlynkReconnect = millis();
        if(WiFi.status() == WL_CONNECTED) {
            if(blynkConnected) Serial.println("Reconnected to Blynk");
    if(blynkConnected) {
        Blynk.run();
    // Maintain WiFi connection
    maintainWiFiConnection();
    // Button handling
    bool currentButton1State = !digitalRead(BUTTON1_PIN);
    if(currentButton1State && !lastButton1State) {
        Serial.println("🔴 System ON (Physical Button)");
            Blynk.virtualWrite(V0, 1);
        delay(100); // Simple debounce
    lastButton1State = currentButton1State;
    bool currentButton2State = !digitalRead(BUTTON2_PIN);
    if(currentButton2State && !lastButton2State) {
        Serial.println("🟢 System OFF (Physical Button)");
            Blynk.virtualWrite(V0, 0);
    lastButton2State = currentButton2State;
    // Non-blocking control packet send
    static unsigned long lastControlSend = 0;
    if(millis() - lastControlSend >= CONTROL_SEND_INTERVAL) {
        esp_err_t result = esp_now_send(receiverMacAddress, (uint8_t *)&data, sizeof(data));
        lastControlSend = millis();
    // Non-blocking RSSI packet send
    static unsigned long lastRSSISend = 0;
    if(millis() - lastRSSISend >= RSSI_SEND_INTERVAL) {
        data2.rssiValue = latestRSSI;
        esp_now_send(receiverMacAddress, (uint8_t *)&data2, sizeof(data2));
        lastRSSISend = millis();
    // Handle RSSI timeout
    if(!rssiTimeout && millis() - lastPacketTime > RSSI_TIMEOUT) {
        rssiTimeout = true;
        Serial.println("Warning: RSSI timeout - no recent packets");
Reciver:
#include <ESP32Servo.h>
#include <WiFi.h>
#include <esp_wifi.h>
uint8_t transmitterMacAddress[] = {0x20, 0x43, 0xA8, 0x63, 0x62, 0x2C};
#define SERVO_PIN 26
#define RED_LED_PIN 32
#define GREEN_LED_PIN 25
#define BUZZER_PIN 27
Servo servo;
bool systemActive = false;
bool buzzerActive = false;
unsigned long lastBuzzerTime = 0;
int buzzerFreq = 1000;
bool increasing = true;
volatile int latestRSSI = 0;
struct PacketData {
  byte activeButton;
PacketData receivedData;
  int rssiValue;
PacketData2 data2;
void promiscuousRxCB(void *buf, wifi_promiscuous_pkt_type_t type) {
    if (type == WIFI_PKT_MGMT) {
        wifi_promiscuous_pkt_t *pkt = (wifi_promiscuous_pkt_t *)buf;
        latestRSSI = pkt->rx_ctrl.rssi;
void updateSiren() {
  if (buzzerActive) {
    if (currentMillis - lastBuzzerTime >= 50) {
      lastBuzzerTime = currentMillis;
      buzzerFreq += increasing ? 100 : -100;
      if (buzzerFreq >= 3000) increasing = false;
      if (buzzerFreq <= 1000) increasing = true;
      tone(BUZZER_PIN, buzzerFreq);
    noTone(BUZZER_PIN);
  memcpy(&receivedData, incomingData, sizeof(receivedData));
  Serial.print("Received button state: ");
  Serial.println(receivedData.activeButton);
  if (receivedData.activeButton == 1 && !systemActive) {
    activateSystem();
    Serial.println("Activating system");
  } else if (receivedData.activeButton == 2 && systemActive) {
    deactivateSystem();
    Serial.println("Deactivating system");
  pinMode(RED_LED_PIN, OUTPUT);
  pinMode(GREEN_LED_PIN, OUTPUT);
  pinMode(BUZZER_PIN, OUTPUT);
  digitalWrite(GREEN_LED_PIN, HIGH);
  digitalWrite(RED_LED_PIN, LOW);
  noTone(BUZZER_PIN);
  WiFi.disconnect();
  if (esp_now_init() != ESP_OK) {
    Serial.println("❌ ESP-NOW Init Failed");
    ESP.restart();
  memcpy(peerInfo.peer_addr, transmitterMacAddress, 6);
  if (esp_now_add_peer(&peerInfo) != ESP_OK) {
    Serial.println("❌ Failed to add peer");
    ESP.restart();
  esp_wifi_set_promiscuous(true);
  esp_wifi_set_promiscuous_rx_cb(&promiscuousRxCB);
  servo.attach(SERVO_PIN);
  servo.write(0);  // Initialize servo to 0° position when system starts
  delay(500);      // Give servo time to reach position
  servo.detach();
  Serial.println("✅ Receiver Ready");
void activateSystem() {
  systemActive = true;
  servo.write(0);  // Move to 90° when system is activated
  servo.detach();
  digitalWrite(RED_LED_PIN, HIGH);
  digitalWrite(GREEN_LED_PIN, LOW);
  buzzerActive = true;
void deactivateSystem() {
  servo.write(90);   // Return to 0° when system is deactivated
  servo.detach();
  noTone(BUZZER_PIN);
    esp_err_t result = esp_now_send(transmitterMacAddress, (uint8_t *)&data2, sizeof(data2));
    updateSiren();
    delay(30);
Is this just an intellectual exercise, or are you trying to solve a problem? If it's the latter, let's go back to giving us a problem statement.
This is a problem I encountered. Like I said when I am connected to the app (WIFI) i get correct RSSI values ​​​​but when I disconnect from WIFI I get completely incorrect RSSI. I would really appreciate help fixing this problem
