ESP32 with HC-SR04 output weird distance
Hi, I'm learning to code and though of using a HC-SR04 with an ESP32 S2 mini (Lolin S2 Mini). I'm simply trying to make it work.
the problem is that the serial monitor output the same "range" of distance regarding of what is it front of it.
Raw duration: 2835 microseconds
Distance: 48.62 cm, 19.14 inches
Raw duration: 2883 microseconds
Distance: 49.44 cm, 19.47 inches
Raw duration: 3002 microseconds
Distance: 51.48 cm, 20.27 inches
Raw duration: 2873 microseconds
Distance: 49.27 cm, 19.40 inches
What am I missing?
Here's my code so far:
#define TRIG_PIN 5   // ESP32 pin GPIO connected to Ultrasonic Sensor's TRIG pin
#define ECHO_PIN 18  // ESP32 pin GPIO connected to Ultrasonic Sensor's ECHO pin
  Serial.begin(115200);       // Begin serial port with a higher baud rate for better precision
  pinMode(TRIG_PIN, OUTPUT);  // Configure the trigger pin to output mode
  pinMode(ECHO_PIN, INPUT);   // Configure the echo pin to input mode
  long duration_us;
  float distance_cm, distance_inch;
  // Clear the trigger pin
  digitalWrite(TRIG_PIN, LOW);
  delayMicroseconds(2);
  // Generate 10-microsecond pulse to TRIG pin
  digitalWrite(TRIG_PIN, HIGH);
  delayMicroseconds(10);
  // Measure duration of pulse from ECHO pin
  duration_us = pulseIn(ECHO_PIN, HIGH);
  // Debug: Print the raw duration
  Serial.print("Raw duration: ");
  Serial.print(duration_us);
  Serial.println(" microseconds");
  // Check if the duration is within expected range
  if (duration_us > 0) {
    // Calculate the distance in cm and inches
    distance_cm = duration_us * 0.0343 / 2;
    distance_inch = distance_cm * 0.393701;
    // Print the calculated distances
    Serial.print("Distance: ");
    Serial.print(distance_cm);
    Serial.print(" cm, ");
    Serial.print(distance_inch);
    Serial.println(" inches");
    Serial.println("Out of range");
  delay(3000);  // Wait before taking another measurement
thank you!
You failed to include a time limit for your function call. And you failed to test for ZERO being returned, meaning no echo in the allotted time. By not including a time-out time, you automatically get a one second time-out period.
Thanks for your help!
I added a delay for duration_us, a delay before other mesurements and a check if the echo is received but I'm not sure if the logic is sound for that last one. It still return the same range of distance.
Trigger pulse sent.
Echo pulse received.
Distance: 53.18 cm, 20.94 inches
Trigger pulse sent.
Distance: 50.51 cm, 19.88 inches
  long duration_us;
  // Debug: The trigger pulse was sent
  Serial.println("Trigger pulse sent.");
  duration_us = pulseIn(ECHO_PIN, HIGH, 300000); // 30 ms timeout
  // Debug: Check if echo was received
    Serial.println("Echo pulse received.");
    Serial.println("No echo received or out of range.");
  delay(5000);  // Wait before taking another measurement
I suggest you cross-check the sensor with an Arduino UNO. A full connection diagram and code is available here: Ultrasonic Sensor Arduino Interfacing - The Engineering Projects
Please try and see if the same problem persists. If yes, I believe, it's a dead sensor.
Thank you for the suggestion, I took my old Duemilanove and hook it up with the code you provided. Plugged in 3.3v I had the same behavior, once plugged it in the 5v I got the right results. My Lolin S2 only output to 3.3v so I wont be able to use the sensor with that board unless I find another source of power.
Thank again for the help.
Vbus outputs 5V
However you will need a voltage divider on the Echo input
It worked! Thank you Jim!
Now have fun!
