ESP32 with Rs232 to scale
Hello!
Im newbie and im encountering a strange problem that i cant solve.
Im trying connect a esp32 to a loader with RS232 to TTL converter.
Its a master and slave system, where the esp32 sends a command to the scale and it must return the value that is being weighed.
I simplified the code to be able to test better:
#include <HardwareSerial.h>
#define RXD2 16
#define TXD2 17
  Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
  Serial.println("Iniciando comunicação...");
void enviarComandoSerial2() {
  const char* comando = "01P\r\n";
  Serial2.write(comando);
  Serial.print("Comando Enviado: ");
  Serial.print(comando);
  Serial2.flush();
  enviarComandoSerial2();
  String recebidoSerial2 = "";
  unsigned long startTime = millis();
  while (millis() - startTime < 2000) {
    while (Serial2.available() > 0) {
      char c = Serial2.read();
      recebidoSerial2 += c;
  if (recebidoSerial2.length() > 0) {
    Serial.print("Recebido na Serial2: ");
    Serial.println(recebidoSerial2);
    Serial.println("Nenhuma resposta válida recebida.");
  delay(2000);
The strange thing that happens is that when I connect the RS232 converter to the computer using an RS232 to USB cable, I can see the command being sent by ESP at the cable terminal.
When I connect the scale to the computer via the converter cable, and send the command 01P+Enter, it is possible to see the scale responding to the measured value.
But when I connect the ESP32 + Rs232 Converter to the scale, nothing happens.
Has anyone gone through something similar?
Hi @fiorotti ,
Welcome to the forum..
pretty sure, that will just send 1 byte..
try this..
Serial2.write(comando,strlen(comando));
good luck.. ~q
Serial2.println("01P");
