ESP32 xTaskCreatePinnedToCore usage in a class
Hi there, straight to the point.
I'm trying to use wificlientsecure to make some https requests, I want these requests to run on the esp32's second core, so they're not blocking the main thread.
But I've run into some problems trying to put the following sketch into a class.
I've removed anything not directly related to my problem, so theres no http requests being done here. It will do some work on the second core, write the result in a shared variable, and set a flag indicating it's done. Main loop thread checks the indicator and reads the result variable when its complete. To hopefully make it thread safe.
ESP32CoreTaskTest.ino
//Global Variables shared between cores
bool taskFinished = false;
int count = 0;
    //Start Serial Output
    Serial.println("");
    xTaskCreatePinnedToCore(
                task,       //Function to implement the task
                "taskname", //Name of the task
                6000,       //Stack size in words
                NULL,       //Task input parameter
                0,          //Priority of the task
                NULL,       //Task handle.
                1);         //Core where the task should run
  if(taskFinished){
    Serial.print("Task#: ");
    Serial.println(count);
  }else{
    Serial.println("Busy");
  delay(100);
void task( void* ){
  while(1){
    count++;      //do some work
    delay(250);   //do some work
    taskFinished = true;
    delay(250);   //Pretend task is done, and not really looping. We should be able to read the task result after the task has finished
This works perfectly, they share memory and wait for tasks to be finished before reading the result.
But I cannot figure out how implement it as a class. So I can use it like this.
Task task = Task();
task.startTask();
while(!task.taskFinished)
   //busy
int result = task.count;
//Dispose the task, keep the result
Obviously the code works, so it must be turned into c++ at some point, but I dont know what that would look like.
My attempt at the code looks like this:
ESP32CoreTaskTest_Class.ino
#include "Task.h"
Task task;
    Serial.println("");
    task = Task();
    task.startTask();
  if(task.taskFinished){
    Serial.println(task.count);
  }else{
  delay(100);
Task.cpp
#include "Task.h"
//Constructor
Task::Task(){
//Member
void Task::startTask(){
            this->worktask, //Function to implement the task
//Task to run
void Task::worktask(void* _this){
  while(1){
Task.h
#ifndef Task_h
#define Task_h
#include "Arduino.h"
class Task {
  public:
    Task(void);
    void startTask(void);
    int count = 0;
  private:
    static void worktask( void* );
#endif
This throws "invalid use of member 'Task::taskFinished' in static member function" as described in the link below.
As its not quite as simple as just making it a static member. :confused:
https://esp32.com/viewtopic.php?t=5027 that I cant quite decipher.
And I did try what was suggested, but I ran into some different compile errors, so I thought I'd go back to my orignal question to myself, and post it here.
What would my original sketch look like, if it was plain c++?
Well, I've figured it out it seems.
Key clue to getting it working was here Calling xTaskCreate on C++ member function? - ESP32 Forum
Here's a working example of using xTaskCreatePinnedToCore inside a class. There's still some work left to do, fx adding proper callbacks and replacing the "work" with an actual https request.
class AsyncHTTPSRequest {
  public:
    int testVar = 0;
    char request[100] = "";
    volatile bool taskFinished = true;
  private:
    const int taskCore = 0;
    const int taskPriority = 1;
    TaskHandle_t Task1;
  public:  AsyncHTTPSRequest(void){
  public: void Start(void)
    //Start Task with input parameter set to "this" class
      this->httpsTask,        //Function to implement the task
      "httpsTask",            //Name of the task
      5000,                   //Stack size in words
      this,                   //Task input parameter
      taskPriority,           //Priority of the task
      &Task1,                 //Task handle.
      taskCore);              //Core where the task should run
  private: static void httpsTask(void *pvParameters)
    AsyncHTTPSRequest *l_pThis = (AsyncHTTPSRequest *) pvParameters;
    // Handle the request here
    delay(1000); //Pretend work
    l_pThis->testVar = 1;
    l_pThis->taskFinished = true;
    delay(50); //Wait a little before killing task
    vTaskDelete( NULL );
AsyncHTTPSRequest req;
  Serial.println("");
  req.Start();
  if(req.taskFinished){
    Serial.print("Done :");Serial.println(req.testVar);   //Task finished, read result variable
    while(1){delay(10);}
  delay(10);
