The sketch i am trying to compile is the "LvglWidgets-LVGL-7.0.ino" sketch downloaded from Espressifs website. The code is given below (rather a lot of it, sorry).
#include <ArduinoPins.h>
#include <FatReader.h>
#include <FatStructs.h>
#include <SdInfo.h>
#include <SdReader.h>
#include <WaveHC.h>
#include <WavePinDefs.h>
#include <WaveUtil.h>
#include <mcpDac.h>
#include <lvgl.h>
#include <demos/lv_demos.h>
#include <examples/lv_examples.h>
#define LGFX_USE_V1
#include <LovyanGFX.hpp>
#include <lgfx/v1/platforms/esp32s3/Panel_RGB.hpp>
#include <lgfx/v1/platforms/esp32s3/Bus_RGB.hpp>
//#include <U8g2lib.h>
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <FS.h>
//U8G2_SSD1306_128X32_UNIVISION_F_SW_I2C u8g2(U8G2_R0, /* clock=*/ 20, /* data=*/ 19, /* reset=*/ U8X8_PIN_NONE); // Adafruit Feather ESP8266/32u4 Boards + FeatherWing OLED
#include <Adafruit_SSD1306.h>
#include <Adafruit_GFX.h>
#define oled_sda 19
#define oled_scl 20
#define OLED_RESET -1
//新建iic对象以及显示屏对象
TwoWire I2Cone = TwoWire(0);
Adafruit_SSD1306 display = Adafruit_SSD1306(128, 64, &I2Cone,OLED_RESET);
//#include <Arduino_GFX_Library.h>
#define TFT_BL 2
class LGFX : public lgfx::LGFX_Device
public:
lgfx::Bus_RGB _bus_instance;
lgfx::Panel_RGB _panel_instance;
LGFX(void)
auto cfg = _bus_instance.config();
cfg.panel = &_panel_instance;
cfg.pin_d0 = GPIO_NUM_15; // B0
cfg.pin_d1 = GPIO_NUM_7; // B1
cfg.pin_d2 = GPIO_NUM_6; // B2
cfg.pin_d3 = GPIO_NUM_5; // B3
cfg.pin_d4 = GPIO_NUM_4; // B4
cfg.pin_d5 = GPIO_NUM_9; // G0
cfg.pin_d6 = GPIO_NUM_46; // G1
cfg.pin_d7 = GPIO_NUM_3; // G2
cfg.pin_d8 = GPIO_NUM_8; // G3
cfg.pin_d9 = GPIO_NUM_16; // G4
cfg.pin_d10 = GPIO_NUM_1; // G5
cfg.pin_d11 = GPIO_NUM_14; // R0
cfg.pin_d12 = GPIO_NUM_21; // R1
cfg.pin_d13 = GPIO_NUM_47; // R2
cfg.pin_d14 = GPIO_NUM_48; // R3
cfg.pin_d15 = GPIO_NUM_45; // R4
cfg.pin_henable = GPIO_NUM_41;
cfg.pin_vsync = GPIO_NUM_40;
cfg.pin_hsync = GPIO_NUM_39;
cfg.pin_pclk = GPIO_NUM_0;
cfg.freq_write = 15000000;
cfg.hsync_polarity = 0;
cfg.hsync_front_porch = 40;
cfg.hsync_pulse_width = 48;
cfg.hsync_back_porch = 40;
cfg.vsync_polarity = 0;
cfg.vsync_front_porch = 1;
cfg.vsync_pulse_width = 31;
cfg.vsync_back_porch = 13;
cfg.pclk_active_neg = 1;
cfg.de_idle_high = 0;
cfg.pclk_idle_high = 0;
_bus_instance.config(cfg);
auto cfg = _panel_instance.config();
cfg.memory_width = 800;
cfg.memory_height = 480;
cfg.panel_width = 800;
cfg.panel_height = 480;
cfg.offset_x = 0;
cfg.offset_y = 0;
_panel_instance.config(cfg);
_panel_instance.setBus(&_bus_instance);
setPanel(&_panel_instance);
LGFX lcd;
End of Arduino_GFX setting
#include <EEPROM.h>
String e_flag = "B"; //如果想要修改已保存的WIFI信息,改下这个字母就可以
#include <WiFi.h>
#include <Ticker.h> //Call the ticker. H Library
Ticker ticker1;
#include "WiFiMulti.h"
WiFiMulti wifiMulti;
#include "BLEDevice.h" //BLE驱动库
#include "BLEServer.h" //BLE蓝牙服务器库
#include "BLEUtils.h" //BLE实用程序库
#include "BLE2902.h" //特征添加描述符库
#include <BLECharacteristic.h> //BLE特征函数库
BLEAdvertising* pAdvertising = NULL;
BLEServer* pServer = NULL;
BLEService *pService = NULL;
BLECharacteristic* pCharacteristic = NULL;
#define bleServerName "Wizee-Series-7.0" //BLE服务器的名称
#define SERVICE_UUID "6479571c-2e6d-4b34-abe9-c35116712345" //服务的UUID
#define CHARACTERISTIC_UUID "826f072d-f87c-4ae6-a416-6ffdcaa02d73"
bool connected_state = false; //创建设备连接标识符
class MyServerCallbacks: public BLEServerCallbacks //创建连接和断开调用类
void onConnect(BLEServer *pServer)//开始连接函数
connected_state = true; //设备正确连接
void onDisconnect(BLEServer *pServer)//断开连接函数
connected_state = false; //设备连接错误
char CloseData;
int NO_Test_Flag = 0;
int Test_Flag = 0;
int Close_Flag = 0;
#define SERIAL_BAUD 9600
HardwareSerial cardSerial(1);//声明串口1
const char *ssid = "elecrow888"; //你的网络名称
const char *password = "elecrow2014"; //你的网络密码
char buf[100] = {};
int bufindex = 0;
int wifi_close_flag = 0;
char *info[100] = {};
int wifi_flag = 0;
int i = 0;
int home_flag = 0;
int touch_flag = 0;
//7.0
#define SD_MOSI 11
#define SD_MISO 13
#define SD_SCK 12
#define SD_CS 10
unsigned long previousBlinkTime;
int blinkInterval = 15000; //LED闪烁时间间隔
#define I2S_DOUT 17
#define I2S_BCLK 42
#define I2S_LRC 18
#define BUTTON_PIN 38
//UI
#include "ui.h"
static int first_flag = 0;
extern int zero_clean;
extern int goto_widget_flag;
extern int bar_flag;
extern lv_obj_t * ui_MENU;
extern lv_obj_t * ui_TOUCH;
extern lv_obj_t * ui_JIAOZHUN;
extern lv_obj_t * ui_Label2;
static lv_obj_t * ui_Label;//TOUCH界面label
static lv_obj_t * ui_Label3;//TOUCH界面label3
static lv_obj_t * ui_Labe2;//Menu界面进度条label
static lv_obj_t * bar;//Menu界面进度条
SPIClass& spi = SPI;
uint16_t touchCalibration_x0 = 300, touchCalibration_x1 = 3600, touchCalibration_y0 = 300, touchCalibration_y1 = 3600;
uint8_t touchCalibration_rotate = 1, touchCalibration_invert_x = 2, touchCalibration_invert_y = 0;
static int val = 100;
Please config the touch panel in touch.h
#include "touch.h"
#include "Audio.h"
Audio audio;
//String music_url;
//int music_id = 1818615872;
/* Change to your screen resolution */
static uint32_t screenWidth;
static uint32_t screenHeight;
static lv_disp_draw_buf_t draw_buf;
//static lv_color_t *disp_draw_buf;
static lv_color_t disp_draw_buf[800 * 480 / 10];
static lv_disp_drv_t disp_drv;
/* Display flushing */
void my_disp_flush(lv_disp_drv_t *disp, const lv_area_t *area, lv_color_t *color_p)
uint32_t w = (area->x2 - area->x1 + 1);
uint32_t h = (area->y2 - area->y1 + 1);
//lcd.fillScreen(TFT_WHITE);
#if (LV_COLOR_16_SWAP != 0)
lcd.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full);
#else
lcd.pushImageDMA(area->x1, area->y1, w, h,(lgfx::rgb565_t*)&color_p->full);//
#endif
lv_disp_flush_ready(disp);
void my_touchpad_read(lv_indev_drv_t *indev_driver, lv_indev_data_t *data)
if (touch_has_signal())
if (touch_touched())
data->state = LV_INDEV_STATE_PR;
/*Set the coordinates*/
data->point.x = touch_last_x;
data->point.y = touch_last_y;
Serial.print( "Data x " );
Serial.println( data->point.x );
Serial.print( "Data y " );
Serial.println( data->point.y );
else if (touch_released())
data->state = LV_INDEV_STATE_REL;
delay(15);
//读取或保存信息;
void save_or_read_wifi(void) {
EEPROM.begin(1024);
if (get_string(1, 0) == e_flag) { //如果第0位字符为“M”,则表示已储存WIFI信息
Serial.println("已储存信息");
else {
Serial.println("未储存有WIFI信息,将储存wifi信息");
//保存信息
set_string(1, 0, e_flag, 0); //录入"N"字符
Serial.println("完成储存");
Serial.println("即将重启");
ESP.restart();
EEPROM.end();
//用EEPROM的a位保存字符串的长度,字符串的从EEPROM的b位开始保存,str为要保存的字符串,s为是否保存字符串长度
void set_string(int a, int b, String str, int s)
if (s)EEPROM.write(a, str.length()); //EEPROM第a位,写入str字符串的长度
//通过一个for循环,把str所有数据,逐个保存在EEPROM
for (int i = 0; i < str.length(); i++) {
EEPROM.write(b + i, str[i]);
EEPROM.commit(); //执行保存EEPROM
//获取指定EEPROM位置的字符串,a是字符串长度,b是起始位,从EEPROM的b位开始读取
String get_string(int a, int b) {
String data = "";
//通过一个for循环,从EEPROM中逐个取出每一位的值,并连接起来
for (int i = 0; i < a; i++) {
data += char(EEPROM.read(b + i));
return data;
void callback1() //Callback function
if (bar_flag == 6)
if (val > 1)
val--;
lv_bar_set_value(bar, val, LV_ANIM_OFF);
lv_label_set_text_fmt(ui_Labe2, "%d %%", val);
lv_obj_clear_flag(ui_touch, LV_OBJ_FLAG_CLICKABLE);
lv_label_set_text(ui_Labe2, "Loading");
delay(150);
val = 100;
bar_flag = 0; //停止进度条标志
goto_widget_flag = 1; //进入widget标志
//触摸Label控件
void label_xy()
ui_Label = lv_label_create(ui_TOUCH);
lv_obj_enable_style_refresh(true);
lv_obj_set_width(ui_Label, LV_SIZE_CONTENT); /// 1
lv_obj_set_height(ui_Label, LV_SIZE_CONTENT); /// 1
lv_obj_set_x(ui_Label, -55);
lv_obj_set_y(ui_Label, -40);
lv_obj_set_align(ui_Label, LV_ALIGN_CENTER);
lv_obj_set_style_text_color(ui_Label, lv_color_hex(0xFF0000), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_opa(ui_Label, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui_Label, &lv_font_montserrat_24, LV_PART_MAIN | LV_STATE_DEFAULT);
ui_Label3 = lv_label_create(ui_TOUCH);
lv_obj_set_width(ui_Label3, LV_SIZE_CONTENT); /// 1
lv_obj_set_height(ui_Label3, LV_SIZE_CONTENT); /// 1
lv_obj_set_x(ui_Label3, 85);
lv_obj_set_y(ui_Label3, -40);
lv_obj_set_align(ui_Label3, LV_ALIGN_CENTER);
lv_obj_set_style_text_color(ui_Label3, lv_color_hex(0x00FF00), LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_opa(ui_Label3, 255, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_text_font(ui_Label3, &lv_font_montserrat_24, LV_PART_MAIN | LV_STATE_DEFAULT);
//进度条控件
void lv_example_bar(void)
bar = lv_bar_create(ui_MENU);
lv_bar_set_value(bar, 0, LV_ANIM_OFF);
lv_obj_set_width(bar, 480);
lv_obj_set_height(bar, 25);
lv_obj_set_x(bar, 0);
lv_obj_set_y(bar, 175);
lv_obj_set_align(bar, LV_ALIGN_CENTER);
lv_obj_set_style_bg_img_src(bar, &ui_img_bar_800_01_png, LV_PART_MAIN | LV_STATE_DEFAULT);
lv_obj_set_style_bg_img_src(bar, &ui_img_bar_800_02_png, LV_PART_INDICATOR | LV_STATE_DEFAULT);
lv_obj_set_style_outline_color(bar, lv_color_hex(0x2D8812), LV_PART_INDICATOR | LV_STATE_DEFAULT);
lv_obj_set_style_outline_opa(bar, 255, LV_PART_INDICATOR | LV_STATE_DEFAULT);
ui_Labe2 = lv_label_create(bar);//创建标签
lv_obj_set_style_text_color(ui_Labe2, lv_color_hex(0x09BEFB), LV_STATE_DEFAULT);
lv_label_set_text(ui_Labe2, "0%");
lv_obj_center(ui_Labe2);
void Ce_shi() {
char serialData = Serial.read();
switch (serialData) {
case 'R':
Close_Flag = 1;
// WiFi.disconnect();//断开连接
lcd.fillScreen(TFT_BLACK);
Serial.println("红屏");
while (Close_Flag == 1)
lcd.fillScreen(TFT_RED);
CloseData = Serial.read();
if (CloseData == 'I') //Exit
Close_Flag = 0;
Serial.println("退出红屏");
case 'G':
Close_Flag = 1;
Serial.println("绿屏");
lcd.fillScreen(TFT_GREEN);
Close_Flag = 0;
Serial.println("退出绿屏");
case 'B':
Close_Flag = 1;
Serial.println("蓝屏");
lcd.fillScreen(TFT_BLUE);
Close_Flag = 0;
Serial.println("退出蓝屏");
case 'w':
Close_Flag = 1;
Serial.println("白屏");
Close_Flag = 0;
Serial.println("退出白屏");
case 'h':
Close_Flag = 1;
Serial.println("灰屏");
lcd.fillScreen(TFT_DARKGREY);
Close_Flag = 0;
Serial.println("退出灰屏");
case 'S':
Close_Flag = 1;
Serial.println("TF卡初始化");
SPI.begin(SD_SCK, SD_MISO, SD_MOSI, SD_CS);
SD_init();
Close_Flag = 0;
Serial.println("退出TF卡初始化");
case 'T':
Close_Flag = 1;
Serial.println("触摸屏");
touch_flag = 0;
delay(100);
lcd.setCursor(300, 120);
lcd.printf("Please Touch");
Serial.println("TOUCH");
touch_last_x = 200;
touch_last_y = 200;
if (touch_flag < 3)
if (touch_last_x > 0 && touch_last_x < 100 && touch_last_y > 0 && touch_last_y < 100 && touch_flag == 0)
lcd.setCursor(320, 200);
lcd.printf(" ");
lcd.setCursor(320, 250);
lcd.printf(" ");
lcd.printf("x: %i ", touch_last_x);
lcd.printf("y: %i ", touch_last_y);
Serial.print( "Data x :" );
Serial.println( touch_last_x );
Serial.print( "Data y :" );
Serial.println( touch_last_y );
touch_flag = 1;
if (touch_last_x > 700 && touch_last_x < 800 && touch_last_y > 400 && touch_last_y < 480 && touch_flag == 1)
lcd.printf(" ");
lcd.printf(" ");
touch_flag = 3;
delay(100);
Serial.println("OVER");
if (touch_last_x > 0 && touch_last_x < 4000 && touch_last_y > 0 && touch_last_y < 4000)
lcd.printf(" ");
lcd.printf(" ");
Close_Flag = 0;
delay(80);
if (touch_flag == 3)
lcd.printf(" ");
lcd.printf(" ");
Close_Flag = 0;
Serial.println("退出触摸屏");
case 'L':
Close_Flag = 1;
Serial.println("IO口测试");
pinMode(38, OUTPUT);
digitalWrite(38, LOW);
lcd.setCursor(260, 230);
lcd.printf("IO port output testing");
digitalWrite(38, HIGH);//拉高电平开灯
Close_Flag = 0;
Serial.println("退出IO口测试");
case 'i':
Close_Flag = 1;
I2Cone.begin(oled_sda, oled_scl);
//初始化显示屏
display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
//清屏
display.clearDisplay();
//设置字体大小
display.setTextSize(2);
display.setTextColor(INVERSE);
display.setTextColor(WHITE);//开像素点发光
Serial.println("IIC");
lcd.setCursor(280, 230);
lcd.printf("IIC testing");
for(int i =0 ; i<120 ;i+=10)
display.setCursor(120-i,19);
display.print("Elecrow");
display.display();
Close_Flag = 0;
Serial.println("退出IIC");
case 'W':
Close_Flag = 1;
Serial.println("Wifi function testing");
lcd.printf("WiFi testing");
wifi_flag = 0;
Serial.flush();//清空串口缓存
memset(buf, 0, sizeof(buf));
bufindex = 0;
if(Serial.available())
delay(200);
while (Serial.available() && wifi_flag == 0)
buf[bufindex] = CloseData;
bufindex+=1;
if (CloseData == '\n')
buf[bufindex] = '\0';
Serial.printf("buf==");
Serial.println(buf);
info[0] = buf;
info[0] = strtok_r(info[0], "@", &info[1]);
info[1] = strtok_r(info[1], "@", &info[2]);
//sscanf(buf, "@%s@%s\n", wifi_account, wifi_password);
delay(5);
wifi_flag = 1;
if (bufindex >= 128)
bufindex = 0;
if (wifi_flag == 1)
// 输出 SSID 和密码到串口监视器
Serial.print("SSID: ");
Serial.println(info[0]);
Serial.print("Password: ");
Serial.println(info[1]);
WiFi.disconnect();
WiFi.begin(info[0], info[1]);
Serial.println("begining");
while (WiFi.status() != WL_CONNECTED)
delay(100);
memset(buf, 0, 100);
bufindex = 0;
Serial.println("connecting");
if(WiFi.status() != WL_CONNECTED)
Serial.println("WiFi is not connected.");
Serial.println("IP address: ");
lcd.printf("WiFi is not connected.");
}else
Serial.println("WiFi is connected.");
lcd.printf("WiFi is connected");
WiFi.disconnect();
WiFi.mode(WIFI_OFF);
wifi_flag = 2;
bufindex = 0;
wifi_flag = 0;
Close_Flag = 0;
bufindex = 0;
WiFi.disconnect();
Serial.println("Exit Wifi function testing");
case 'U':
Close_Flag = 1;
Serial.println("打开UART1");
lcd.printf("UART1 testing");
// 如果硬件串口有数据
if (Serial.available())
//从硬件串口读出一字节,写入软件串口
Serial.write(Serial.read());
// //如果软件串口有数据
// if (cardSerial.available())
// //从软件串口读出一字节,写入硬件串口
// Serial.write(cardSerial.read());
Close_Flag = 0;
// digitalWrite(25, LOW);
Serial.println("关闭UART1");
case 'P':
Close_Flag = 1;
Serial.println("打开SPEAK");
lcd.printf("SPEAK testing");
WiFi.disconnect();
delay(2000);
// audio.loop();
// EEPROM.begin(1024);
// set_string(1,0,"L",0); //录入"L"字符
// Serial.println("完成储存");
// Serial.println("即将重启");
// ESP.restart();
// EEPROM.end();
// audio.stopSong();
// pinMode(BUTTON_PIN, OUTPUT);
// digitalWrite(BUTTON_PIN, LOW);
delay(50);
Close_Flag = 0;
Serial.println("关闭SPEAK");
case 'V':
Close_Flag = 1;
Serial.println("Bluetooth function");
pAdvertising->start(); //Start broadcasting
pService->start();
if (connected_state == true) //有设备连接
lcd.printf("Bluetooth is connected");
lcd.printf("Bluetooth is not connected");
delay(100);
Close_Flag = 0;
pAdvertising->stop(); //停止广播
pService->stop();
delay(50);
Serial.println("Turn off Bluetooth function");
//Exit软件测试程序
case 'C':
WiFi.disconnect();
NO_Test_Flag = 0;
Test_Flag = 0;
// Wire.end();
// lv_init();
Serial.println("Exit the software test program");
//SD卡初始化
int SD_init()
if (!SD.begin(SD_CS))
Serial.println("Card Mount Failed");
return 1;
uint8_t cardType = SD.cardType();
if (cardType == CARD_NONE)
Serial.println("No TF card attached");
return 1;
uint64_t cardSize = SD.cardSize() / (1024 * 1024);
Serial.printf("TF Card Size: %lluMB\n", cardSize);
listDir(SD, "/", 2);
// listDir(SD, "/", 0);
// createDir(SD, "/mydir");
// removeDir(SD, "/mydir");
// listDir(SD, "/", 2);
// writeFile(SD, "/hello.txt", "Hello ");
// appendFile(SD, "/hello.txt", "World!\n");
// readFile(SD, "/hello.txt");
// Serial.printf("Total space: %lluMB\n", SD.totalBytes() / (1024 * 1024));
// Serial.printf("Used space: %lluMB\n", SD.usedBytes() / (1024 * 1024));
// Serial.println("SD init over.");
return 0;
//遍历SD卡目录
void listDir(fs::FS & fs, const char *dirname, uint8_t levels)
// Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if (!root)
//Serial.println("Failed to open directory");
return;
if (!root.isDirectory())
Serial.println("Not a directory");
return;
File file = root.openNextFile();
i = 0;
while (file)
if (file.isDirectory())
// Serial.print(" DIR : ");
// Serial.println(file.name());
if (levels)
listDir(fs, file.name(), levels - 1);
Serial.print("FILE: ");
Serial.print(file.name());
lcd.setCursor(0, 2 * i);
lcd.printf("FILE:%s", file.name());
Serial.print("SIZE: ");
Serial.println(file.size());
lcd.setCursor(180, 2 * i);
lcd.printf("SIZE:%d", file.size());
i += 16;
// optional
void audio_info(const char *info) {
Serial.print("info "); Serial.println(info);
void audio_id3data(const char *info) { //id3 metadata
Serial.print("id3data "); Serial.println(info);
void audio_eof_mp3(const char *info) { //end of file
Serial.print("eof_mp3 "); Serial.println(info);
void audio_showstation(const char *info) {
Serial.print("station "); Serial.println(info);
void audio_showstreamtitle(const char *info) {
Serial.print("streamtitle "); Serial.println(info);
void audio_bitrate(const char *info) {
Serial.print("bitrate "); Serial.println(info);
void audio_commercial(const char *info) { //duration in sec
Serial.print("commercial "); Serial.println(info);
void audio_icyurl(const char *info) { //homepage
Serial.print("Please search again"); Serial.println(info);
void audio_lasthost(const char *info) { //stream URL played
Serial.print("lasthost "); Serial.println(info);
#define Z_THRESHOLD 350 // Touch pressure threshold for validating touches
#define _RAWERR 20 // Deadband error allowed in successive position samples
void begin_touch_read_write(void) {
digitalWrite(38, HIGH); // Just in case it has been left low
spi.setFrequency(600000);
void end_touch_read_write(void) {
uint16_t getTouchRawZ(void) {
begin_touch_read_write();
// Z sample request
int16_t tz = 0xFFF;
spi.transfer(0xb0); // Start new Z1 conversion
tz += spi.transfer16(0xc0) >> 3; // Read Z1 and start Z2 conversion
tz -= spi.transfer16(0x00) >> 3; // Read Z2
end_touch_read_write();
return (uint16_t)tz;
uint8_t getTouchRaw(uint16_t *x, uint16_t *y) {
uint16_t tmp;
// Start YP sample request for x position, read 4 times and keep last sample
spi.transfer(0xd0); // Start new YP conversion
spi.transfer(0); // Read first 8 bits
spi.transfer(0xd0); // Read last 8 bits and start new YP conversion
tmp = spi.transfer(0); // Read first 8 bits
tmp = tmp << 5;
tmp |= 0x1f & (spi.transfer(0x90) >> 3); // Read last 8 bits and start new XP conversion
*x = tmp;
// Start XP sample request for y position, read 4 times and keep last sample
spi.transfer(0x90); // Read last 8 bits and start new XP conversion
tmp = tmp << 5;
tmp |= 0x1f & (spi.transfer(0) >> 3); // Read last 8 bits
*y = tmp;
return true;
uint8_t validTouch(uint16_t *x, uint16_t *y, uint16_t threshold) {
uint16_t x_tmp, y_tmp, x_tmp2, y_tmp2;
// Wait until pressure stops increasing to debounce pressure
uint16_t z1 = 1;
uint16_t z2 = 0;
while (z1 > z2)
z2 = z1;
z1 = getTouchRawZ();
delay(1);
Serial.print("z1:");
Serial.println(z1);
if (z1 <= threshold) return false;
getTouchRaw(&x_tmp, &y_tmp);
delay(1); // Small delay to the next sample
if (getTouchRawZ() <= threshold) return false;
delay(2); // Small delay to the next sample
getTouchRaw(&x_tmp2, &y_tmp2);
if (abs(x_tmp - x_tmp2) > _RAWERR) return false;
if (abs(y_tmp - y_tmp2) > _RAWERR) return false;
*x = x_tmp;
*y = y_tmp;
return true;
void touch_calibrate()//屏幕校准
uint16_t calData[5];
uint8_t calDataOK = 0;
Serial.println("屏幕校准");
//校准
// lcd.fillScreen(TFT_BLACK);
// lcd.setCursor(20, 0);
// Serial.println("setCursor");
// lcd.setTextFont(2);
// Serial.println("setTextFont");
// lcd.setTextSize(1);
// Serial.println("setTextSize");
// lcd.setTextColor(TFT_WHITE, TFT_BLACK);
// lcd.println("按指示触摸角落");
Serial.println("按指示触摸角落");
// lcd.setTextFont(1);
// lcd.println();
// lcd.setCursor(175, 100);
// lcd.printf("Touch Adjust");
// Serial.println("setTextFont(1)");
lv_timer_handler();
calibrateTouch(calData, TFT_RED, TFT_BLACK, 19);
Serial.println("calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15)");
Serial.println(); Serial.println();
Serial.println("//在setup()中使用此校准代码:");
Serial.print("uint16_t calData[5] = ");
Serial.print("{ ");
for (uint8_t i = 0; i < 5; i++)
Serial.print(calData[i]);
if (i < 4) Serial.print(", ");
Serial.println(" };");
// Serial.print(" tft.setTouch(calData);");
// Serial.println(); Serial.println();
// lcd.println("XZ OK!");
// lcd.println("Calibration code sent to Serial port.");
void calibrateTouch(uint16_t *parameters, uint32_t color_fg, uint32_t color_bg, uint8_t size) {
int16_t values[] = {0, 0, 0, 0, 0, 0, 0, 0};
uint16_t x_tmp, y_tmp;
uint16_t _width = 800;
uint16_t _height = 480;
for (uint8_t i = 0; i < 4; i++) {
lcd.fillRect(0, 0, size + 1, size + 1, color_bg);
lcd.fillRect(0, _height - size - 1, size + 1, size + 1, color_bg);
lcd.fillRect(_width - size - 1, 0, size + 1, size + 1, color_bg);
lcd.fillRect(_width - size - 1, _height - size - 1, size + 1, size + 1, color_bg);
if (i == 5) break; // used to clear the arrows
switch (i) {
case 0: // up left
lcd.drawLine(0, 0, 0, size, color_fg);
lcd.drawLine(0, 0, size, 0, color_fg);
lcd.drawLine(0, 0, size , size, color_fg);
case 1: // bot left
lcd.drawLine(0, _height - size - 1, 0, _height - 1, color_fg);
lcd.drawLine(0, _height - 1, size, _height - 1, color_fg);
lcd.drawLine(size, _height - size - 1, 0, _height - 1 , color_fg);
case 2: // up right
lcd.drawLine(_width - size - 1, 0, _width - 1, 0, color_fg);
lcd.drawLine(_width - size - 1, size, _width - 1, 0, color_fg);
lcd.drawLine(_width - 1, size, _width - 1, 0, color_fg);
case 3: // bot right
lcd.drawLine(_width - size - 1, _height - size - 1, _width - 1, _height - 1, color_fg);
lcd.drawLine(_width - 1, _height - 1 - size, _width - 1, _height - 1, color_fg);
lcd.drawLine(_width - 1 - size, _height - 1, _width - 1, _height - 1, color_fg);
// user has to get the chance to release
if (i > 0) delay(1000);
for (uint8_t j = 0; j < 8; j++) {
while (touch_has_signal())
void setTouch(uint16_t *parameters) {
touchCalibration_x0 = parameters[0];
touchCalibration_x1 = parameters[1];
touchCalibration_y0 = parameters[2];
touchCalibration_y1 = parameters[3];
if (touchCalibration_x0 == 0) touchCalibration_x0 = 1;
if (touchCalibration_x1 == 0) touchCalibration_x1 = 1;
if (touchCalibration_y0 == 0) touchCalibration_y0 = 1;
if (touchCalibration_y1 == 0) touchCalibration_y1 = 1;
touchCalibration_rotate = parameters[4] & 0x01;
touchCalibration_invert_x = parameters[4] & 0x02;
touchCalibration_invert_y = parameters[4] & 0x04;
Serial.println("LVGL Widgets Demo");
//IO口引脚
pinMode(17, OUTPUT);
digitalWrite(17, LOW);
pinMode(18, OUTPUT);
digitalWrite(18, LOW);
pinMode(42, OUTPUT);
digitalWrite(42, LOW);
EEPROM.begin(1024);
pinMode(SD_CS, OUTPUT); digitalWrite(SD_CS, HIGH);
SPI.begin(SD_SCK, SD_MISO, SD_MOSI);
SPI.setFrequency(1000000);
SD.begin(SD_CS);
audio.setPinout(I2S_BCLK, I2S_LRC, I2S_DOUT);
audio.setVolume(15); // 0...21
audio.connecttoFS(SD, "/123.mp3");
while (1)
//检查是否到达时间间隔
if (currentMillis - previousBlinkTime >= blinkInterval) { //如果时间间隔达到了
audio.stopSong();
else if (currentMillis - previousBlinkTime <= 0)
{ // 如果millis时间溢出
previousBlinkTime = currentMillis;
audio.loop();
else {
//保存信息
ESP.restart();
EEPROM.end();
#ifdef TFT_BL
pinMode(TFT_BL, OUTPUT);
digitalWrite(TFT_BL, LOW);
digitalWrite(TFT_BL, HIGH);
#endif
//BLE
BLEDevice::init(bleServerName); //创建BLE并设置名称
pServer = BLEDevice::createServer(); //创建BLE服务器
pServer->setCallbacks(new MyServerCallbacks()); //设置连接和断开调用类
pService = pServer->createService(SERVICE_UUID); //创建BLE服务
pCharacteristic = pService->createCharacteristic( //Create ble feature(Characterristic_UUID)
CHARACTERISTIC_UUID,
BLECharacteristic::PROPERTY_READ | BLECharacteristic::PROPERTY_WRITE | BLECharacteristic::PROPERTY_NOTIFY);
pCharacteristic->setValue("ELECROW");
//开始广播
pAdvertising = BLEDevice::getAdvertising(); //A bleadvertising class pointer padvertising is defined, which points to bledevice:: getadvertising()
pAdvertising->addServiceUUID(SERVICE_UUID);
// Init Display
lcd.begin();
lcd.setTextSize(2);
delay(200);
// lcd.fillScreen(TFT_RED);
// delay(1000);
// lcd.fillScreen(TFT_GREEN);
// delay(1000);
// lcd.fillScreen(TFT_BLUE);
// delay(1000);
// delay(1000);
lv_init();
// Init touch device
touch_init();
screenWidth = lcd.width();
screenHeight = lcd.height();
lv_disp_draw_buf_init(&draw_buf, disp_draw_buf, NULL, screenWidth * screenHeight / 10); //4
/* Initialize the display */
lv_disp_drv_init(&disp_drv);
/* Change the following line to your display resolution */
disp_drv.hor_res = screenWidth;
disp_drv.ver_res = screenHeight;
disp_drv.flush_cb = my_disp_flush;
disp_drv.draw_buf = &draw_buf;
lv_disp_drv_register(&disp_drv);
/* Initialize the (dummy) input device driver */
static lv_indev_drv_t indev_drv;
lv_indev_drv_init(&indev_drv);
indev_drv.type = LV_INDEV_TYPE_POINTER;
indev_drv.read_cb = my_touchpad_read;
lv_indev_drv_register(&indev_drv);
#ifdef TFT_BL
//digitalWrite(TFT_BL, HIGH);
ledcSetup(1, 300, 8);
ledcAttachPin(TFT_BL, 1);
ledcWrite(1, 255); /* Screen brightness can be modified by adjusting this parameter. (0-255) */
#endif
ui_init();//开机UI界面
while (1)
if (goto_widget_flag == 1)//进入widget
if (ticker1.active() == true)
ticker1.detach();
goto_widget_flag = 0;
delay(300);
if (goto_widget_flag == 3)//进入触摸界面,先把进度条线程关闭
ticker1.detach();
if (first_flag == 0 || first_flag == 1)
label_xy();
first_flag = 2;
if (zero_clean == 1)
touch_last_x = 0;
touch_last_y = 0;
zero_clean = 0;
lv_label_set_text(ui_Label, "Touch Adjust:");
lv_label_set_text_fmt(ui_Label3, "%d %d", touch_last_x, touch_last_y); //显示触摸信息
if (goto_widget_flag == 4)//触摸界面返回到Menu界面,使进度条清零重启
val = 100;
delay(100);
ticker1.attach_ms(35, callback1);//每20ms调用callback1
if (goto_widget_flag == 5) //触发校准信号
lv_scr_load_anim(ui_touch_calibrate, LV_SCR_LOAD_ANIM_NONE, 0, 0, false);
lv_timer_handler();
lv_timer_handler();
delay(100);
touch_calibrate();//触摸校准
lv_scr_load_anim(ui_TOUCH, LV_SCR_LOAD_ANIM_NONE, 0, 0, false);
lv_timer_handler();
delay(100);
goto_widget_flag = 3; //进入触摸界面标志
touch_last_x = 0;
touch_last_y = 0;
if (bar_flag == 6)//刚开机进入Menu界面时运行进度条一次,之后就不再运行
if (first_flag == 0)
lv_example_bar();
first_flag = 1;
lv_timer_handler();
lv_demo_widgets();//主UI界面
Serial.println( "Setup done" );
while (NO_Test_Flag == 0)
lv_timer_handler();
if (CloseData == 'b') //Exit
NO_Test_Flag = 1;
Test_Flag = 1;
Serial.println("进入测试程序");
WiFi.disconnect();
//*********************************测试程序***************************************
while (Test_Flag == 1)
Ce_shi();
lv_demo_widgets();
The error message has now become:-
In file included from C:\Users\roger\Documents\Arduino_7inch\Arduino_7inch\LvglWidgets-LVGL-7.0\LvglWidgets-LVGL-7.0.ino:8:
c:\Users\roger\Documents\Arduino\libraries\WaveHC/WaveUtil.h:5:10: fatal error: avr/pgmspace.h: No such file or directory
#include <avr/pgmspace.h>
compilation terminated.
exit status 1
Compilation error: exit status 1`
The file "c:\Users\roger\Documents\Arduino\libraries\WaveHC/WaveUtil.h:" does exist in that directory.
Hoping you can help.
Regards, Roger.
