Hi there, i want to use ESP32S3 as Mass Storage Device. i wrote code using USBMSC library and FATFS file system its recognized by the Windows 10 but cannot format the drive. what is the problem can you help me? thanks in advanced.
#ifndef ARDUINO_USB_MODE
#error This ESP32 SoC has no Native USB interface
#elif ARDUINO_USB_MODE == 1
#warning This sketch should be used when USB is in OTG mode
void setup() {}
void loop() {}
#else
#include "USB.h"
#include "USBMSC.h"
#include "FFat.h"
USBMSC MSC;
FS &fs1 = FFat;
static int32_t onWrite(uint32_t lba, uint32_t offset, uint8_t *buffer, uint32_t bufsize) {
Serial.printf("MSC WRITE: lba: %lu, offset: %lu, bufsize: %lu\n", lba, offset, bufsize);
File file = fs1.open("/mscfile");
if (file) {
file.seek(lba * 512 + offset);
file.write(buffer, bufsize);
file.close();
Serial.println("Failed to open file for writing");
return -1;
return bufsize; bufsize;
static int32_t onRead(uint32_t lba, uint32_t offset, void *buffer, uint32_t bufsize) {
Serial.printf("MSC READ: lba: %lu, offset: %lu, bufsize: %lu\n", lba, offset, bufsize);
if (file) {
file.read((uint8_t*)buffer, bufsize);
file.close();
Serial.println("Failed to open file for reading");
return -1;
return bufsize;
static bool onStartStop(uint8_t power_condition, bool start, bool load_eject) {
Serial.printf("MSC START/STOP: power: %u, start: %u, eject: %u\n", power_condition, start, load_eject);
return true;
static void usbEventCallback(void *arg, esp_event_base_t event_base, int32_t event_id, void *event_data) {
if (event_base == ARDUINO_USB_EVENTS) {
arduino_usb_event_data_t *data = (arduino_usb_event_data_t *)event_data;
switch (event_id) {
case ARDUINO_USB_STARTED_EVENT: Serial.println("USB PLUGGED"); break;
case ARDUINO_USB_STOPPED_EVENT: Serial.println("USB UNPLUGGED"); break;
case ARDUINO_USB_SUSPEND_EVENT: Serial.printf("USB SUSPENDED: remote_wakeup_en: %u\n", data->suspend.remote_wakeup_en); break;
case ARDUINO_USB_RESUME_EVENT: Serial.println("USB RESUMED"); break;
default: break;
void listDir(fs::FS &fs, const char * dirname, uint8_t levels) {
Serial.printf("Listing directory: %s\n", dirname);
File root = fs.open(dirname);
if (!root) {
Serial.println("Failed to open directory");
return;
if (!root.isDirectory()) {
Serial.println("Not a directory");
return;
File file = root.openNextFile();
while (file) {
if (file.isDirectory()) {
Serial.print(" DIR : ");
Serial.println(file.name());
if (levels) {
listDir(fs, file.name(), levels - 1);
Serial.print(" FILE: ");
Serial.print(file.name());
Serial.print(" SIZE: ");
Serial.println(file.size());
Serial.setDebugOutput(true);
if (!FFat.begin(true)) {
Serial.println("Card Mount Failed");
return;
USB.onEvent(usbEventCallback);
MSC.vendorID("ESP32"); //max 8 chars
MSC.productID("USB_MSC"); //max 16 chars
MSC.productRevision("1.0"); //max 4 chars
MSC.onStartStop(onStartStop);
MSC.onRead(onRead);
MSC.onWrite(onWrite);
MSC.mediaPresent(true);
MSC.isWritable(true); // true if writable, false if read-only
MSC.begin(FFat.totalBytes() / 512, 512);
USB.begin();
unsigned long lastTime = 0;
if (millis() - lastTime > 3000)
listDir(fs1, "/", 0);
lastTime = millis();
#endif /* ARDUINO_USB_MODE */```
