Hi Community!
I’m new to the whole arduino thing and crafted myself a water-pressure sensor for my deep well (~ 22m)
This is the sensor.
Everything works fine and quite accurat (a calibrated the sensor with a small test station i built), but after some time (i think its about 36-48hours) the webserver page is no more reachable. After reset it works well again for this period of time.
Could it be that the reading is too fast for ADC/ analog pin? Should i increase the “delay” what would be a recommendation?
What the programm should do:
- read the anlog signal and build an average (after 10 readings)
- output this data via WIFI on a webserver with a static IP
- output this data on the serial monitor (just for checking with laptop etc.)
- output also the WIFI signal strength
And this is my code - PLEASE - I’m no Coder or programmer, I read and copied a lot from different tutorials and other projects and adopted to my project as best as i could
// Library für WiFi-Verbindung
#include <ESP8266WiFi.h>
#include <ESP8266WebServer.h>
#include <WiFiClient.h>
#include <SPI.h>
IPAddress staticIP(10, 0, 0, 85); // statische IP des NodeMCU ESP8266
IPAddress gateway(10, 0, 0, 138); // IP-Adresse des Router
IPAddress subnet(255, 255, 255, 0); // Subnetzmaske des Netzwerkes
IPAddress dns(8, 8, 8, 8); // DNS Server
// Daten des WiFi-Netzwerks
const char* ssid = "my_SSID";
const char* password = "my_PW";
const char* deviceName = "Brunnen";
// Port des Web Servers auf 80 setzen
WiFiServer server(80);
// Variable für den HTTP Request
String header;
//Glättung
const int numReadings = 10;
int readings[numReadings]; // the readings from the analog input
int readIndex = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
int inputPin = A0;
int Analog = 0;
// initialize all the readings to 0:
for (int thisReading = 0; thisReading < numReadings; thisReading++) {
readings[thisReading] = 0;
// Mit dem WiFi-Netzwerk verbinden
Serial.print("Connecting to WiFi");
WiFi.disconnect(); //Prevent connecting to wifi based on previous configuration
WiFi.hostname(deviceName); // DHCP Hostname (useful for finding device for static lease)
WiFi.config(staticIP, gateway, subnet, dns);
WiFi.begin(ssid, password);
WiFi.mode(WIFI_STA); //WiFi mode station (connect to wifi router only)
//auf Verbindung mit WiFi_Netzwerk warten
Serial.print(".");
// Lokale IP-Adresse im Seriellen Monitor ausgeben und Server starten
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
server.begin();
// listen for incoming clients
WiFiClient client = server.available();
if (client) {
Serial.println("new client");
// an http request ends with a blank line
bool currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
// Der Server sendet nun eine Antwort an den Client
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 20"); // refresh the page automatically every 15 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// subtract the last reading:
total = total - readings[readIndex];
// read from the sensor:
readings[readIndex] = analogRead(inputPin);
// add the reading to the total:
total = total + readings[readIndex];
// advance to the next position in the array:
readIndex = readIndex + 1;
// if we're at the end of the array...
if (readIndex >= numReadings) {
// ...wrap around to the beginning:
readIndex = 0;
// calculate the average:
average = total / numReadings;
Serial.print("Indexnummer: ");
Serial.println(readIndex);
Analog = analogRead(inputPin);
Serial.print("Analoger Wert: ");
Serial.println(Analog);
Serial.print("Summe analoger Werte: ");
Serial.println(total);
Serial.print("Durchschnitt: ");
Serial.println(average); // Ausgabe am seriellen Monitor
delay(2); // delay in between reads for stability
long rssi = WiFi.RSSI();
Serial.print("RSSI:");
Serial.println(rssi);
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 1; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.println(average); // send it to the computer as ASCII digits
client.println("
client.println("RSSI:");
client.print(rssi);
client.println("</html>");
if (c == '\n') {
// you're starting a new line
} else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(10);
// close the connection:
client.stop();
Serial.println("client disconnected");
Would you help me with your suggestions and/ or instructions to get the webserver stable?
Kind regards
VR1
