Hi.First sorry for my poor English.
I would like to connect by wifi to esp8266 as a Server and also esp8266 connects to a Web Site as a client.
But It doesn't work at the same time.
I mean How can I set an esp8266 as a server and client at the same time.
Thanks.
leoncorleone:
Thanks.
You will have to write code that does both function, one to accept requests, the other to send requests.
The Client code, from the Ethernet.h examples:
char server[] = "www.google.com"; // name address for Google (using DNS)
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET /search?q=arduino HTTP/1.1");
client.println("Host: www.google.com");
client.println("Connection: close");
client.println();
else {
// kf you didn't get a connection to the server:
Serial.println("connection failed");
// if there are incoming bytes available
// from the server, read them and print them:
while(client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
while (true);
The Server code is almost the same
EthernetServer server(80);
void setup(){
// configure mac, ip, etc
// listen for incoming clients
if (client) {
Serial.println("new client");
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
Serial.write(c);
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close"); // the connection will be closed after completion of the response
client.println("Refresh: 5"); // refresh the page automatically every 5 sec
client.println();
client.println("<!DOCTYPE HTML>");
client.println("<html>");
// output the value of each analog input pin
for (int analogChannel = 0; analogChannel < 6; analogChannel++) {
int sensorReading = analogRead(analogChannel);
client.print("analog input ");
client.print(analogChannel);
client.print(" is ");
client.print(sensorReading);
client.println("
client.println("</html>");
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
Serial.println("client disconnected");
You would just switch back and forth between these two models. One initiates a connection, by using client.connect("servername"); the other starts the Server() object listening on port 80, EthernetServer server(80);. The connection is accepted by EthernetClient client =server.available();
Both use the Client() object to actually send and receive data.
Once a connection has be established, you use client.print() and client.read() to communicate with the other end.
Chuck.
Hello chucktodd,
Thank you very much for sharing such a great idea. I have tried many times on the switching between the two, unfortunately it does work for only one. may you help please,
My source code is below:
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h> // Built-in
ESP8266WiFiMulti wifiMulti;
const char* host = "v-gro.com";
IPAddress IP(192, 168, 0, 99); // Set your server's fixed IP address here
const char* ssid = "Sovatna";
const char* pass = "Password"; //connect to Access Point
const char* ssids = "SOVATNA";
const char* passs = "Password";//connect to router
int x = 0;
Serial.setTimeout(100);
Serial.println('\n');
Serial.println("done \n");
Serial.println(x);
if(x == 0){
WiFi.begin(ssid, pass);
if(WiFi.status() != WL_CONNECTED){
Serial.println("Not Connection");
delay(100);
}else{
WiFiClient client;
if(!client.connect(IP, 8080)){
Serial.println("local not connection");
}else{
Serial.println("********************************");
Serial.print("Byte sent to the AP: ");
Serial.println(client.print("Anyo\r"));
String data = client.readStringUntil('\r');
Serial.println("From the AP: " + data);
x = 1;
if(x == 1){
WiFi.begin(ssids, passs);
Serial.println("Server not connection");
delay(100);
}else{
Serial.println("wifi connected");
WiFiClient client;
if(!client.connect(host, 80)){
Serial.println("Server failed");
}else{
Serial.println("Connected");
delay(100);
client.stop();
x = 0;
Where is your WiFi.mode(...); statement?
Without such a statement your ESP8266 will be in whatever mode it was in the last time you loaded a program that did include one.
Don
